Zanussi aquacycle zwf 1632w won't start,
Doesn't allow the selection of any program lights flash & beeps 3 times when any buttons are pressed have cleared the filter didn't help any suggestions
SOURCE: Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
Posted on Jun 16, 2007
abhishek33
  • 1239 Answers
SOURCE: zanussi zwf 1632 w
hi follow this Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by handStep 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
thank u.......................
Posted on Sep 12, 2008
Nic61
  • 1073 Answers
SOURCE: Zanussi ZWF 1631W
Try to pull out the power-cable from the contact. Wait for at least 30 seconds then reconect it again.
Sometimes that can help but not always. If that dosent help you need to let a profesional repairshop fix your machine.
Good luck
Posted on Nov 21, 2008
  • 106 Answers
SOURCE: zanussi aquacycle 1000 start pause button
Try some WD40 on the door lock on machine (not on the door) & open and close a few times. Of course the mains plug should be off the wall socket.
Posted on Feb 28, 2009
  • 207 Answers
SOURCE: my zanussi 1600 aquacycle will was but not drain
it sounds like have a bad water pump
Posted on Feb 24, 2010
I have a zanussi 1600 aquacycle. We had a power cut then the machine wouldn't empty so I emptied it manually and now the door won't lock to start any programmes. Any suggestions??
turm the power off
then press in the two buttons on the left hand side while pressing them turn power back on turn selector to one oclock{if you have buttons to select programs press it } you should see the lights come on and move to different programs this is a test program to take it off test turn to off then turn anti clock wise
Feb 03, 2015 | Zanussi Washing Machines
My machine does part cycle than all lights flash than when restart it will start washing but want go throw the cycles ie rinse spin drain
Teh make and model of the machine is important here, because WHICH lights flash and the number of times they flash is an error code taht we can look up if you tell us the make and model. However, from what you have said so far, this likely to be a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom)
Jul 06, 2011 | Washing Machines
Hi Machine will no start..At first all lights flashing and now just start and reset button flashing.. Start button flashes 3 times reset button flashes 5 times. Can you help. Cheers
I have a zanussi zwf1432w aquacycle.
Hi Machine will no start.Starts to fill,Stops and goes straight to drain.There is no blockages in filter or pipes,Have checked all,Even pipe from drum to filter.
Can you help.
Cheers
Apr 05, 2011 | Washing Machines
Hi, I have a Zanussi Timeline 1400 front loader and after it has completed a wash, it will not do another wash for some time. If you select a program it will think about it and then say it is complete with...
Try this..
Reading Error Codes
1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up.
Jan 30, 2011 | Zanussi ZWF1450W Front Load Washer
Zanussi aquacycle 1000 start pause button
Feb 28, 2009 | Zanussi IZ12 Front Load Washer
Our washing machine (Zanussi ZWF 1632 W) flashes 5 times
This is a motor problem the end light flashing 5 times indicates error E50. The motor has either got wet or has just failed i would suggest trying to dry it 1st but i would suspect the motor has gone down to earth usually having to replace it. The part no. DST1246179079 Motor aprox £195 but shop around you may find it cheeper.
Dec 11, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi zwf 1432 w washing machine
pcb as the signs were that the pcb was stuck in a programme and unable to change. Anyway, long story short, to fix it:
Take the lid off the washing machine (2 screws at the back) *unplug first
Locate the pcb, unscrew and lift above the washing machine with all wires in tact.
Locate the wires that are coming out of the back of the "program" board, it should be 2 blue wires.
Follow these back to the pcb and unplug
plug in washing machine
Turn on washing machine
Only the on/off light should come on
Whilst on, and being careful, plug back in the wires you unplugged
VOILA, fixed washing machine!!
Right, have to go, got a weeks worth of washing to do!!!!
Feb 24, 2008 | Zanussi ZWF1430W Front Load Washer
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Mar 20, 2007 | Zanussi F1245W Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
