Question about Miele Washing Machines
Miele stuck main wash - Miele Washing Machines
    Top Expert:
  • Miele Master
  • 9,472 Answers
Unplug the unit for 30 mins.
Posted on Nov 05, 2012
2 Suggested Answers
  • 70 Answers
SOURCE: miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Posted on Apr 01, 2010
Testimonial: "thanks, you confirmed what we sort of expected"
Service manual for Miele washing machine?
Which Miele washing machine do you have?
Nov 25, 2015 | Miele Washing Machines
Our miele w911 washing machine keeps stopping in the main wash cycle - red light above the tap symbol. What does it mean?
check that the water flow solenoid is operational and not blocking of the spray rinse requriement
Mar 23, 2015 | Miele Washing Machines
I have a Miele W1918 washer that is getting stuck in the main wash cycle.
All washing machines have a pressure switch , it is a rubber tube leading into the outer drum and up to the switch, located up on the frame top rail under the lid, if this tube becomes blocked with dried detergent suds it wont function, gently pull of the rubber tube from the switch and suck and blow through if you can or push a piece of flexible electric wire through it then blow it again and reconnect and test.
DONT pull the tube out of the drum or you could have a leak, that\'s why I said GENTLY.
Good luck
Mar 11, 2014 | Miele Washing Machines
Miele washing machine 6065 stuck on main wash programme , unable to clear or reset . any ideas ?
Switch off machine for some time maybe overnight. Press and hold on panel buttons to drain off voltage. when powered hold on start/stop/pause button. If the program does not reset it be fault in the memory or the processor.
Jan 23, 2013 | Washing Machines
Miele 6065
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jan 23, 2013 | Miele Washing Machines
Miele premier novo, the main wash light flashing
Hi
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Jan 10, 2010 | Miele Novotronic W1918A Front Load Washer
Miele transit rods stuck
My husband was able to pull it out .
Feb 27, 2008 | Miele Washing Machines
Washing Machines Logo
157 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
