Question about HP Slate 500 8.9 Tablet
Turning on hp slate 500 without power switch - HP Slate 500 8.9 Tablet
  • joecoolvette
    joecoolvette Nov 06, 2012
    You would have to open it, and jump the two wires going to the Power On switch, BRIEFLY. (The Power On switch is a Momentary Contact Switch)
I hope you found a solution months ago, but just in case:
My switch also broke a while back, and this is a common problem with the slate 500 due to the construction of the switch.
This should help:
http://forum.tabletpcreview.com/hp-slate/41309-my-power-switch-just-broke-2.html
My solution: remove what's left of the plastic switch (if anything) then use a long thin thing (LTT) (about 2 cm long) in the hole where the switch was. I use a squashed paper clip - someone else had a mini screwdriver, someone else the toothpick on their pen knife.
Put the LTT straight at the top of the switch hole and pull down, the same way you used to pull down on the power switch, then let go. The indicator light under the switch hole will blink 3 times quickly if you've successfully tripped the switch.
All the best!
Posted on Feb 28, 2013
  • 1 more comment
  • joecoolvette
    joecoolvette Feb 28, 2013
    Excellent Rob C, glad you posted! With no reply from poster, the subject just seemed to have died. I was going for disassembly of the unit next, lol! No I don't have a guide, or manual. About time someone made directions though. Should come apart like an All-In-One Desktop PC. I was going to use the TouchSmart All-In-One Display Disassembly instructions,http://www.hp.com/hpinfo/globalcitizensh... ,and a video on disassembling the HP TouchSmart IQ770, for a start,http://www.youtube.com/watch?v=vpMrlAMSo... I figure you come in from the back, just like the all-in-ones. Would have posted to send it in of course, if it was still under warranty, or this is an HP fix for free. Post back in a Comment. Regards, joecoolvette
  • Rob C Mar 04, 2013
    The slate 500 comes apart with some difficulty - you have to level off the bezel all around (a plastic strip around the outside of the unit). I managed to break mine outting it back togather, so it's held together with tape and switched on with a paper clip.:-( Time for a replacement!
  • joecoolvette
    joecoolvette Mar 04, 2013
    So is the indication there is no screws, hence no Screw Covers; and the bezel is popped off? Just as you would per se for a laptop? (Using the newer design of no screws/Screw Covers) Then remove screws from a metal Screen Frame, going around the LCD screen; and remove LCD screen to access the hardware components? Not trying to bother you Rob, just a curious 'computer geek'.
How do I restore factory settings on a HP Slate 21?
Hi there. the HP Slate is an ANDROID Device and it`s not possible to use Windows on it.
First switch on brain (or learn to read) then buy anything.
lG Gue.
Oct 17, 2014 | HP Slate 21-k100 All-in-One Desktop 1.66...
How can a get the screen on hp slate2 turn sideways
The power switch of the Slate 2 is a 2-way switch.
The user can slide the switch towards the lock symbol to lock display from auto rotating. So move the switch away from the lock symbol.
HP Slate 2 Tablet PC Disable Display Auto Rotate
Sep 24, 2014 | Computers & Internet
Hp slate plus 4200ca plus broken screen wont power up
Probably a crack on the motherboard but if you are lucky, maybe a broken switch. Strip it down to find out.
Mar 11, 2014 | HP Computers & Internet
Power won't charge
If the power adapter is functional and the computer is running well with the adapter plugged into the wall; then the power cell has died. Most of the batteries have 6 cells inside and only one cell shorts and the entire battery will fail to work or take a charge.
Feb 21, 2014 | HEWLETT-PACKARD Hewlett Packard HP Slate...
We want to connect our hp slate 7 to our Sony Bravia TV??
The Slate doesn't have any sort of video output. The only thing you may be able to do is run a DLNA server on the device that you can connect to watch videos.
If you're not sure how to setup your Bravia you can find instructions here:
http://www.youtube.com/watch?v=Zt9iPGJFiRs
Sep 26, 2013 | HP / Hewlett Packard 64GB Slate 500 Tablet...
HP Slate 500 won't turn on
It's not the power button. It's something else.It's dropped so there are a lot of problems inside the computer. Get it serviced. If the technician says that you need a new motherboard, then buy a new computer instead because motherboards are expensive.
David
Apr 09, 2013 | HP Slate 500 8.9 Tablet
Hp slate 500 Stylus stopped working
sounds like a short somewhere in laptop 1 easy thing to try turn off laptop no hibernate mode on the back there is a ram cover should see a little pic of a ram stick unscrew the screws reinsert ram if you able to take out put back in put screws back in turn on no difference
ok take out cd drive the screw for that is close to where the ram cover is has a little cd pic unscrew that screw gently but firmly tug or pry cd drive out look at the connector on the back see if they look like they got hot darkness colorl look inside cd bay with flash light look all around especially at the connetion for cd drive look for discoloration and smell inside and smell the back of the cd drive if it smells burnt needs to be taken apart for further inspection i rebuild laptops main killer is dust could just need a good cleaning basicly take it all apart and clean
Feb 26, 2013 | HP Slate 500 8.9 Tablet
HP Slate 500 8.9 Tablet Logo
966 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
