Question about Refrigerators
Rattle noise with KitchenAid Fridge
A have a KitchenAid Fridge Model # KBFA25ERSS01 for a little over a year. It makes this very loud rattling noise, drives us crazy. Had a tech. come in during warranty period to fix it. He spent about 15 minutes and replaced a part. Sound went away for a while but now is back. Thought I might try fixing it myself but unfortunately through out the paper work and don't know the part. I know it was located somewhere inside at top. Any help would be much appreciated.
  • Anonymous May 22, 2009
    We have the same issue. Anybody know how to fix it?
davidpsr
  • 222 Answers
SOURCE: intermittent rattling noise in refrigerator
Do you have an ice maker? That noise could be the ice maker trying unsuccessfully to dump ice, usually caused by a defective heater to loosen the ice cubes prior to dumping them into the container.
Possibly even if your ice maker appears to be functioning normally, it may be attempting to dump ice several times before the ice is actually ejected and if you don't use a lot of ice, you'd never notice it.
Hope this helps.
Posted on Jun 27, 2009
SOURCE: Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Posted on Aug 11, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
aborcass
  • 2651 Answers
SOURCE: Rattling noise during high speed spin
sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Posted on Oct 21, 2008
SOURCE: constant rattling noise during operation
possibly the "stirrer" motor - this is in the top and turns a metal reflecting ring to disperse the microwaves around the oven more evenly. About $70 on GE site for my oven.
Posted on Oct 24, 2008
KitchenAid KBFA25ERSS01 I replaced the water
if its computerized make sure someone didnt turn icemaker off check to make sure its in all the way
Oct 27, 2013 | KitchenAid KBFS25EVMS Stainless Steel...
Ge refrigerator noise
Hi. I cant solve your problem but I will tell you what I did. If its the same problem I I had ( there was like a light rattle that seemed to come from the back of the freezer side. It wasnt constant but sort of like a little rattle here and a little rattle there every few seconds. Not very loud but very anoying. It sort of sounded like a cardboard tag floping in the wind and hitting something.) I thought it was the fan but that was not the problem. I had to call GE a few times. When the service guy came the fridge was silent and the guy said nothing was wrong. An hour after he left it started again but this time I made a video recording and placed the microphone at the rear of the fridge. GE admited something was wrong. The service guy said he could not fix it so they gave me a new fridge. This one is ok but the water wont dispence.
Jul 30, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
My TBX22PRYRWW refrigerator rattles continually
OK MY FRIDGE IS DOING THE SAME THING WHAT DID YOU FIND OUT!
Mar 06, 2010 | GE Refrigerators
Kitchenaid refrigerator / freezer knocking noise
Hmmm. Makes sure it is not the fan inside the freezer. The compressor is not capable of loud noise since it is sealed and sits on rubber mount. The knocking might be due to the fan blade hitting ice build up. You should not see any frost in a freezer. If there is frost, you can defrost completely then set the fridge to a lower setting.
Feb 11, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Kitchenaid Household stand mixer. Model no.
it is hard to tell you exactly what it could be, but a common problem is after a while the transmission gasket does deteriorate and will begin to leak oil.the gasket is part number4162324. the rattling noise inside your unit is most likely cause by a chipped gear inside, this can happen when the unit is put under heavy loads, such as dough. this problem could get worse as there may be fragments inside that will damage it more.hope this helps
Thanks
Oct 04, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
When we plugged in our kitchenaid beverage center for the first time it is really, really noisy. It has a loud motor noise with a rattle? is this normal, will it go away when it is cooled down?
Did you lay it on it's side? If you did the oil in the compressor may have made it's way down the system. And when you plug in a fridge with no oil in the compressor it will make alot of noise and could damage the compressor. They say if you lay a fridge on it's side you should have it standing up for 24 hours before plugging in so the oil can make it's way back down to the compressor.
Sep 05, 2009 | KitchenAid Architect Series II KBCS24S 24"...
(orignal game boy) no sound from speaker but rattling
i guess your speakers are not recognizing the ''treble'' sounds !
this case, the only solution is buying a new speaker =/
Jul 30, 2009 | Nintendo Game Boy Advance SP Console
Frig makes a very loud booming noise/ratteling what is the cause?
The noise is coming from the compressor and is a result of a broken support spring inside the compressor. When the unit shuts down, the inner casing rattles against the outer casing because the spring is not there to keep them apart. The only fix is to replace the compressor but otherwise it is just bothersome.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Refrigerators
Servis frost free fridge /freezer
not sure if it happens with this brand but I know others have a problem with ice build up that can interfere with the fan. If you can remove the back panel in the freezer section and take a look. If not try defrosting it for a couple of hours to see if it makes a difference.
Sgt 48
Jun 07, 2008 | KitchenAid KTRS22EM Top Freezer...
Refrigerators Logo
495 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
