3 parsels send to 5 instead 7 Fitzgerald. CRT
As above
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Can you provide a brand, model number and a clear explanation of the problem--what is the set doing or not?
Posted on Nov 05, 2012
Because I like this zenith 27 inch TV large black TV
im sorry I cannot deliver any thing. I was just helping fix things that was broke and saving people money because most things can be fixed at home very cheap instead of paying 300 dollars for a repair on a 2 dollar part. sorry if I could I would for sure.
Sep 26, 2014 | Zenith C27A24T 27" TV
Hello, I have a philips 107e61 ,17" crt monitor and it has a problem with the VGA cable. The image appeares and disappeares when I move the jack or the cable. It seems that the wires inside the VGA jack...
Standard VGA (with DDC VESA) pins are H-Sync = 13 and V-Sync = 14. R G B are 1, 2, and 3 respectively. Ground is 5, Red Shield 6, Green Shield 7, Blue Shield 8, 5V 9 (if there is a pin in the connector), Sync Return 10. 4, 11, 12 are ID Bits 2, 0 and 1 respectively, 15 ID Bit 3 (or clock pulse). If your connector does not have anything in 9 and 15, then it is not have DDC VESA.
May 29, 2014 | HP L1502 15" LCD Monitor
Need instructions for farberware food processor FMP 300
Hi I couldn't locate that instruction guide anywhere, so here is their customer service number instead, call them to have them send you one. Telephone: 800 809-7166
Days: Monday through Friday
Hours: 7:00 a.m. through 5:00 p.m. Pacific time
Hope that helps you
Jun 11, 2012 | Food Processors
I need help on typing in exponents like (6.02*10^23) (8.65*10^4)
6 . 0 2 EE 2 3 * 8 . 6 5 EE 4 =
The EE (enter exponent) key is located just above the 7 key. If you want a negative exponent, make sure you use the +/- key located just to the right of the decimal point key instead of the - key.
Aug 30, 2011 | Texas Instruments TI-30XA Calculator
Vga cable color code of 17" monitor of samsung SyncMaster can u send color code pichear
1 - Red
2 - Green
3 - Blue
4 - NC
5 - DDC Return
6 - GND (R)
7 - GND (G)
8 - GND (B)
9 - NC
10 - GND-Sync/Self raster
11 - NC
12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
The wire colours in the actual cable are:
Red (foil wrapped with 1 bare ground wire)
Green (foil wrapped with 1 bare ground wire)
Blue (foil wrapped with 1 bare ground wire)
Transparent (foil wrapped with 1 bare ground wire)
All the above go to the corresponding Gun Color, the Bare wire goes the one GND pin.
Purple
Yellow
Black
Orange
White
Bare braided outer ground wire. Combine ALL earths to a single point.
You will have to open up the unit, to see what colors are used for the 5 - DDC Return 10 - GND-Sync/Self raster 12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
Settings they are marked on the motherboard.
Aug 03, 2010 | SAMTRON 55V 15" CRT Monitor
Belt diagram for a 2002 ford taurus ses
You normally can find the diagram on a sticker on the underside of the hood directly above the alternator on a 3.0 OHV motor 2002 Ford Taurus. I copied one from the Internet and taped it above the headlight on my car so it was easier to view and use. If you send me an email address I can post an image to you that shows the routing diagram or you can use this:
http://www.daycoproducts.com/daycoweb.nsf/DaycoSerpentineBeltGuide.pdf
V6 182 3.0L FI (VIN S)
Multiple Accessory, w/A.C. illust. 5-7 (page 86)
V6 182 3.0L FI (VIN U) (OHV 3.0)
Multiple Accessory illust. 7-12 (page 87)
V6 182 3.0L FI Flex (VIN 2)
Jun 27, 2010 | 2002 Ford Taurus
Lg crt monior display cable wire circuit diagram
Pin Signal 1 Red Video 2 Green Video 3 Blue Video 4 Monitor ID - Bit 2 5 Ground 6 Red Ground 7 Green Ground 8 Blue Ground 9 [KEY] 10 Sync Ground 11 Monitor ID - Bit 1 12 Monitor ID - Bit 0 13 Horizontal Sync 14 Vertical Sync 15 N/C (Reserved)
Feb 11, 2010 | Computers & Internet
How do I use keyboard to print off a copy of the desktop icons?
Shouldn't be any different except the key may say PrtScn or Print screen on the Microsoft keyboard.
Mar 19, 2009 | Computers & Internet
It takes 5 to 7 minutes to turn on my Magnavox HD TV
IFyou feel confident and can locate switch mode power supply with back removed.
Try warming switchmode power supply before turning TV on.
If TV turns on normaly then there are some small capcitors that are a common cause of this fault.
Otherwise look for DRY or CRACKED solder jointson PCB
BUT DON'T do any of the above if your are not confident send it to a TV repaiman.
Sep 11, 2008 | Philips Magnavox MS2530C 25" TV
Vertical line running through video channels 1-4
Interchange the video channels 1-4 and 5-7. Now check white vertical line in video port 5-7. Suppose you get problem remove cable television cable from tv during another two port running. These type problem occurs only when RF disturbance from cable television or video ochannel ports cable wire ground problem. I found there is no problem in tv. External source only the problem. I hope above details give you the better solution.
Aug 23, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
