My hot point washing machine is beeping during its cycle. What is the cause of this?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Could you please describe the problem you are having a little better?
Posted on Nov 05, 2012
SOURCE: beeping
Thanks! I found this online, which shows how to run tests on the washer to see what might be wrong, which helped, too. Now if i can just find a few muscly people to help me move the dryer from atop the washer.
http://forum.appliancepartspros.com/attachments/washer-repair/42d1194897506-error-code-01-wfk2401test.pdf
from this page:
http://forum.appliancepartspros.com/washer-repair/2385-error-code-01-a.html
Posted on Nov 26, 2007
SOURCE: Washing Machine stopped through cycle and now will not turn on
Unplug!!! NOW! I drained the water using a common garden hose, fill the hose with water and have some device turning it off like a trigger nozzle on the low end. Detach from the supply and put the supply end in the center of the tub under the softener dispenser. take the trigger nozzle off and watch the water drain without cups and buckets. Then wring out the clothes and put them aside, use the hose trick again for remaining water. Now get under the washer and detach and reattach the brown and white lead input to the rinse cycle motor. She is made in France so be gentle. Plug the machine in and set the machine down and turn it on. Push the >> button until you reach the spin cycle if it starts you have fixed it!! Put the clothes back in open a bottle of wine and try again.
Posted on Nov 05, 2007
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Posted on Jan 05, 2007
  • 291 Answers
SOURCE: washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Posted on Feb 16, 2010
  • 3 Answers
SOURCE: maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Posted on Jan 08, 2011
When going to wash with my GW11 it stops during the was cycle and the cold and hot water light blink and the machine beeps
Hi just read your posting.Now, when the hot and cold lights flash at the same time it means that you are not getting enough or no hot or cold water.Remove the cold and hot inlet hoses from the machine end and put the ends into a bucket.Now turn the taps on to see if you have water coming out the hot and cold hose and if the water pressure is adequate.Try a cold fill on the wash cycle and see how it goes.please reply and let me know if there is water coming out of the hoses at a good pressure and also what water temp do you select on the wash cycle.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Machine stops during the wash cycle.
Hi this is abhishek,welcome to fixya
over weight normally doesnt cause machine to stop during the wash cycle,,iit is actually tub gettiing stuck or a timer problem...
thank uy........
May 03, 2009 | Bosch Logixx WFR 2867 Front Load Washer
My gw712 washing machine no longer empty's the tub during the rinse or the spin cycle. It produces a single beep every second, I have followed the manual and I still have the same problem
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 17, 2009 | Washing Machines
I can't change the default wash cycle without it switching
Jan 28, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washing mchine stops during cycle and starts beeping
See if you are overfilling you machine or the load is out of balance. Even try running the machine empty
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore oasis he beeping during cycle
"HC" indicates hot and cold hoses switched.
Aug 23, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Beep with a display saying EFO
Dear novscorp,
According to the error code chart (a loose insert included with the operating instructions) EF0 means two things: Error 1. Over sudsing  or  Error 2. Hot water does not enter.
For over sudsing, it lists the possible causes as: a high efficiency detergent was not used (the detergent brand will have "he" on it for high efficiency) or too much detergent was added.  The solution lists: Use only a high efficiency detergent.  Follow manufacturer's recommendation for dosage.  Amount may need to be adjusted for water temperature, water hardness, load size and soil level.
For the 2nd error, hot water does not enter, it lists the possible causes as hot water hose is connected to the wrong faucet or hot water faucet is not turned on.  The solution lists: Connect hot water hose to hot water faucet and hot inlet on washer.  Be sure hot water facet is fully opened.
On a personal note, I received the same error when I mixed my detergent directly in with my color safe bleach.  It just caused a lot of suds in the machine.  One rinse cycle solved it.
Hope this helps, Ellenk4
Aug 18, 2008 | Kenmore Energy Star 44092 Front Load...
Washer won't stop beeping and can not change cycle selections
what light is flashing when it beeps. You might have to check and see if you are getting water to both Hot and Cold on the machine. Or your door might be closed all the way
Jul 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi ZWF16581W Washing Machine
I believe there is a setting where you can turn the beeping alarm off completely. Read the manual and you should find it.
Mar 04, 2008 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
