Need a power supply
Freecom 500 gb hard drive model number sspafg need a power supply i know its 12 volt but is it 12 volt 2amp dont know
  • joecoolvette
    joecoolvette Nov 05, 2012
    Suggest you just buy a new external enclosure, due to; A) Ease of access. Sold all over the place. B) Non-ease of access for the AC adapter that plugs into the Freecom II. (Availability ) C) Compare price. D) Just remove the harddrive, and install it in the external enclosure. Do not know if your Freecom II has a laptop sized harddrive inside, or a desktop size harddrive. Do not know if it is an IDE (PATA), or SATA harddrive inside, either. You will know once you open the Freecom II case. 2.5 external enclosure for a laptop size harddrive, (It's 2-1/2 inches across in Width. { 2.5 } ), or 3.5 external enclosure for a desktop sized harddrive. Label on harddrive will state SATA, or look manufacturer ID number up online. 12 Volts at 2 Amperes sounds about right. 12 Volts x 2 Amps = 24 Watts. Harddrive will use about 10 to 15 Watts, and you need to allow extra Wattage. (Harddrive has a motor inside. Spindle Motor )http://www.tigerdirect.com/applications/...http://www.tigerdirect.com/applications/... Also Freecom II, model number sspafg, does me no good. Post back in a Comment. Regards, joecoolvette
  • joecoolvette
    joecoolvette Nov 06, 2012
    Always go with the voltage. Has to be 12 Volts. The Amperage can be 'fudged' a bit.
    Top Expert:
  • 9,472 Answers
I use the adjustable power supplies you can get at Radio Shack.
Posted on Nov 06, 2012
thalal
SOURCE: Power Supply
Use HP D530 power supply to run SSF desktop which can run on 12v dC current. Just by using one 6000VA in series
Posted on Jan 03, 2008
Sunil Panem
  • 80 Answers
SOURCE: help my second hard drive dont show up
Hi
Make sure it is connected properly.
Then go to Disk Management by typing "diskmgmt.msc" in the Run window.
Then check in Disk Management if there is any unassigned or any uninitialised partition there.
If you find one, right click on it and then select either "Format" or "Initialise".
Posted on Mar 05, 2008
  • 75 Answers
SOURCE: Freecom 400 GB external hard
hi there,
sounds like you have a hardware problem...you should look into trying this drive on another system to see if the same thing is happening without the drive software ...and if it works try to recover all your data from this drive as soon as possible...hardware problems are most time intermittent ... so they work now then say after a while they stop...
Posted on Apr 13, 2008
antiochpc
  • 1314 Answers
SOURCE: replacing power supply HP M8120N
Here is the link for the upgrade and service guide.
This one is just as easy as 1) removing the side panel; 2) Remove the four screws that hold the power supply into position; 3) Remove the power supply cables from the motherboard (NOTE: If the media bay reader is in the way, you remove the front bezel by pressing the release tabs on the bezel and it will swing open. Remove the one screw securing the bay in position, then slide it forward so you can reach the power cable to the motherboard.); 4) Remove the power supply cables from the hard drives, cd rom drives, and other peripherals inside the PC. 5) Remove power supply...sometimes there is a button to push and it will slide out, sometimes not. 6) Replace power supply, then reverse procedures.
Thanks and please take a moment to rate as fixya.
Posted on Dec 07, 2008
Bat1956
  • 585 Answers
SOURCE: No 12 volt power output from my acerpower 1000 motherboard
This seems to have a motherboard none too dissimilar to that of a laptop. It's hard enough to get information on a typical desktop motherboard, and those for laptops are even more obscure. You are not however dead in the water yet. The power supplies usually have fuses on the board, they are usually either blue or green, sometimes have a little "hourglass" on them. You can check them with an ohmmeter. If you're lucky, there's one blown from an earlier fan or drive problem. Hope you can find it and a replacement.
Posted on May 25, 2009
I need the dc power supply for SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Your solution is a 12 volt 1.5amp chord. With a negative outside/ positive inside plug tip polarity. Simple Tech model and part number: SYS1298-1812-W2
Jan 08, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
I have a simpletech 120 GB external USB hard drive with NO power supply. Do you know what the power rating is (ac or dc, how many volts, amperage...) or where I can get a new power supply for it? -Thanks
12VDC, 1.5A external power adapter Well that is what this page says, it's not your 120GB drive but unsure if it's no the same model maybe. However all external HDD that need a power supply should be needing 12 volts, as they are just internal drives mounted in a shell and some simple circuitry to power and connect it.
May 22, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
No signs of electrical power. The vertical orange light is off. 12 Volt power supply is OK, I checked its output voltage. What else can be done?
open the unit if not under warrenty look for a small clear 2.5 amp fuse it may need replacement you will have to look close as they dont like you find such things.
Oct 07, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Need a new power supply for my MDL WD32001032-001
go to radio shack and tell them you need a 12 volt 2 amp universal power supply.
take your external power supply with you you will need to match up the adapter plug up to it.
when you find the plug have them assist you in making sure the center tap is positive,
and the outside is negative.
cheers
Jun 22, 2010 | Western Digital My Book Essential Edition...
I can't find my adaptor/power supply cable. can
Most are 12V for the FreeAgent drives, like the power inside your pc.
Oct 12, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Power supply details for Maxtor 500 gb, external hard drive and ? manual
The PSU for my Maxtor 500Gb 9NZ2A4-500 drive is 12V DC, 2A rating, 2.1mm "plug" with centre "hole" as positive.
Regards, kbsguru
Nov 06, 2008 | Maxtor Hard Drive
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
