Question about Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls
Water collecting in wash drum when not operating
Noticed water collecting in wash drum when washer has not been run in several days q month or so ago. Today after when I got home, I notied more water than usual, but washer had not been used for about 8 days. If I were guessing it is as leaky water mixing solinoid, but I am not sure. What I did is to place the machine in spin cycle and it pumped out the water and then I used it as normal. The machine seems to work fine, but worried the water problem may get worse and if it over fills the drum, then it will leak out on the floor and cause damage to the house. My wife and and I are gone quite a bit, so if it gets worse, this could happen. What are your thoughts?
    Top Expert:
  • Electrolux Master
  • 9,472 Answers
You are correct. One of the solenoids on the water valve is not shutting completely and will need to be replaced before it sticks wide open and cause a flood. Here is the part to order. To replace the valve, remove the screws on the top panel, slide it back and lift it off. There you will have access to the valve replacement.
Posted on Nov 05, 2012
SOURCE: Front loader washing machine - noisy spin cycle
I HAVE AELECTROLUX EW 903 FE FRONT LOAD WASHING MACHINE IT WASH PROGRAM IS NOT WORKING PLS SUGGEST A SOLUTION
Posted on Mar 23, 2008
kjmac
  • 97 Answers
SOURCE: drum stuck fast
hiya
sounds like the drum bearings may have seized, or they are worn and the belt has come off and wrapped around the drum pulley. a few things you can check are:-
does the inner drum have any up and down movement to it?
does the belt appear to be on ok? (you will need to remove the lid to see)
have you noticed any black marks on the clothes recently?
hope this helps
please dont forget to rate the helpfuness of this reply, thanks kj
Posted on Aug 03, 2008
Fix it Matt
  • 14 Answers
SOURCE: New Electrolux FL washer - will not fill with water
There are three main possibilities here. Firstly there may be a blockage that is stopping the water from flowing. Secondly there may be an item stuck in the pump chamber. Lastly the pump itself may be seized up. On machines that have their waste pipe connected under the kitchen sink it is always worth checking that the plumbing is not blocked with fat or lint at this junction. Check for kinking of the waste hose, this may of course release itself if you pull the machine forward. As for blockages and obstructions inside the machine itself it would be difficult to give any real guidance as there are so many models. If the pump is seized or defective the solution is nearly always the replacement of the whole pump.
Posted on May 03, 2009
  • 53 Answers
SOURCE: washing machine drum out of balance when spinning.
mine is also making noise during the spin cycle. Just paid $95AUD for the repairman to tell me it needs news bearings and that will be a further $300!
Posted on Feb 25, 2010
BIKER T
  • 909 Answers
SOURCE: Hi, I have an Electrolux
Im taking it that you have a squirrel cage motor.(motor without bruhes) Locate the capacitor and replace it. Most of the time its the capacitor that has malfunctioned and that will stop the spin cycle. If you have a soft start.(an electronic control), then check the brushes. Possibly need someone to help as the motor will need to be removed to gain access to the brushes. Check length. must be at least 25 mm.(otherwise not enough tension). Make sure power is pulled out when doing this repair.
Posted on Sep 05, 2010
Severe vibration/noise during spin cycle. What could the problem be and how do I fix it?
if the machine was run severely out of balance (rugs) you'll need to get a look in the back up near the top with a good flashlight , this involves unhooking power and hoses and turning it around , you may have broken a drum suspension link , this device (three) keeps the drum from contacting the shell , if its true and its allowed to run this way you will brake off water hoses on bottom of drum and water will runout on floor
Feb 09, 2016 | Bosch Washing Machines
My washer keeps spitting out dirt
Try cleaning filter at front of machine , just take it out and rince it under a tap
Mar 15, 2015 | Kenmore 500 3.5 cu. ft. Top-Load Washing...
How to get rid of the stale smell from the atf8000 front loader washing machine
first things first we need to purchase a cleaning tablet from local grocery store called affresh tablets in your laundry detergent aisle ,
then clean out filter sump assymbly in bottom corner of washer som washers have an axcess panel in the bottom righ or left hand corber uncrew filter cap and drain in to bucket or a shop vac .
clean debris out of filter and reinstall the filter screw cap in tightly ..
check your console for a clean cycle option in your wash cycles an select put one affresh tablet inside of washer drum and run cycle..
if you dont have a clean cycle thats ok select your hotest water wash cycle or sanitary cycle put one affresh tablet inside washer drum and run cycle ...
after cycle completes always leave waher door cracked open when washer is not in use ,,, reccomend running an affresh cycle once every month or if u notice stagnant water smell the more often you wash with hot water the less chances of smell
Jan 24, 2011 | Washing Machines
The washer started making a noise about a month ago, kind of like change rattling in the bottom of the machine. Today the machine leaked water all over the laundry room and down the hall. It didn't come...
sounds like the water pump, is leaking or the rubber hose from the drum to the pump. its very hard for money to get thru the filter holes, of the drum to the pump
Dec 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Duet Water in drum when washer isn't running
Water fill valve ..Also.try outlet pipe not too low, water could be comming from sink back into machine...
Sep 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water drains during wash cycle. I have used this washer for many years without a problem. About two months ago I noticed that the water level in the drum was going down during the wash cycle. Last week I...
Take the drain hose out of the drain pipe and put it into a sink to test the machine
If that works make sure that the drain hose is being allowed to breath (ie let air into the main drain pipe so that the machine does not set up a syphon).
Jul 16, 2009 | Whirlpool Washing Machines
Water is collects in drum after a few hours after cycle is complete
no your inlet water valve is defective, youll need to repalce it, part number 8181694. in the mean time just turn off water in beween usages.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire washing machine collects water behinf door seal
your washer is a great washer BUT you Have to wipe the silly gasket all the time and leave the door open to let it vent and dry I deal with this all the time and no they dont tell you this when you buy them (they Should) but they want the sale then its your baby.I do warranty work for all the name brands and I see this on all of them good luck
Dec 17, 2007 | Frigidaire Affinity ATF7000ES Front Load...
6 months old. Now no water will fill drum! Works as normal but no water!
Hurlewan Your washer is still under manufacturer's warranty which is one full year. If it has Kenmore's name on it you do not need proof of purchase. The only thing you need is your mother-in-law's home phone number at time of purchase because Sears keeps all their records based on phone numbers. Good luck, Gendos post back....
Jun 27, 2007 | Kenmore 43142 Front Load Washer
Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls Logo
465 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
