Slower function of laptop - Computers & Internet
  • 27,725 Answers
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
if you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of speeding up a computer
If youre not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs
This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have.
Delete the files using Disk Cleanup
If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup.
It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need.
Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup.
In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation.
Disk Cleanup proceeds to remove all unnecessary files from your computer.
Watch the demo (1:00)
this should speed up your computer
hope this helps
Posted on Nov 06, 2012
What would cause a fax machine to get progressively slower to react to commands?
You are probably right about something chewing up memory. I would check to see if there are any system updates that can be applied as these usually fix these types of errors.
Oct 28, 2014 | Ricoh Aficio Mp 301spf B&w Copier
Troy bilt xp self propelled not switching gears
Check transmission fluid. Ensure belt is good or replace. Check belt tensioner if installed.
Apr 21, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Compressor turns slow when motor is running
If the AC is functioning normally, and there is no belt squealing, there is nothing wrong. All accessories run at different speeds depending on the pulley size. The AC will run a lot slower than the Alternator since it has to run slower in order to function properly.
Feb 04, 2012 | 2002 Ford Mustang
Is it okay to have advanced system care, avast and threat fire at the same time?
no it's not.if you have two antivirus at the same time it may cause your PC hang or it can cause of slower functioning of your PC.
Sep 23, 2011 | Samsung N150 (36725723009) Netbook
Microsoft ISATAP Adapter This device is not working properly because Windows cannot load the drivers required for this device.
ISATAP is Microsoft trying to allow IPv6 to function over an IPv4 infrastructure, however, it was released extremely prematurely, and as a result, doesn't like to work, or install. According to Microsoft, your computer should continue to function without ISATAP functioning,and the error message may be ignored. However, if you believe that this may be causing you some problems, then you may navigate to the device manager ( Start > Control Panel > Hardware and Sound > Device Manager ) from this window, see if you can find ISATAP adapter and 4TO6 adapter, right-click these, and select "Disable" NOTE: this may cause Internet Explorer and Windows Mail to run slower and have a few errors.
I hope this helps!
May 08, 2011 | Microsoft Computers & Internet
Cpu heat
Overheating is a common problem with laptops, and usually a bit of preventative maintenance is all it takes to keep it alive. The bearings on those fans are pretty durable, however dust (and especially pet hair) can build up and slow it down. The motor may still be good, its just that the fan blades are stuck.
Blow some air in the vent OPPOSITE the direction of normal air flow (In most cases it sucks from the bottom and blows out the back/side) and if you see dust bunnies, your doing good. Be THROUGH! Especially if you smoke in your house, this causes the dust to become brown and sticky. = )
Good Luck!
Oct 27, 2008 | Computers & Internet
Images blurred on toshiba satellite laptop
Many times this is caused by a dial-up accelerator program. These function by reducing the quality of the picture, resulting in smaller files and thus faster internet because there is less data to transfer. But the resulting pictures are often very poor quality.
If there is an accelerator, there will be a way to reduce the degree of compression or to disable it completely. You will have slower internet but better pictures.
Oct 01, 2008 | Toshiba Satellite P100 Notebook
Cpu heat
buy a notebook cooler to minimize the heat of your laptop
like this
cheers
CHARCOIS
Aug 30, 2008 | Computers & Internet
Se k750i slow functions
well you should downgrade back to the original firmware or you can try and delete some of the larger files on your system.
Jan 01, 2008 | Sony Ericsson K750i Cellular Phone
Computers & Internet Logo
David Payne
David Payne
