I can't get it to charge right or sync at all?
So u will probably have to send it to apple or the place u bought it if there is no other problem.
Posted on Nov 05, 2012
My eclipse cld (2 gb) hooked up to my old computer just fine but now i got a new computer it only hooks up to charge but wont open up so i can put more music on it how do i fix this
I am not familiar with your model, but most can sync with Windows media player. (Connect it first) then If you open media player and click the sync tab on the right side, you can add tracks to your device and then click sync when you are ready.
Dec 18, 2011 | Eclipse CLD2 MP3 Player
Hello, When i try and use the Wii remotes [after charging in the Wii charger dock] all the blue lights at the bottom of the controller flash and then nothing...........also when the controllers are in...
The flashing lights likely means the controllers are not synced to the Wii. Syncing them to the Wii is really easy, luckily
Generally, you can find the sync button under the battery cover on accessories, which should be a small red button. Look around your remote for it.
After you find your sync button on your remote, find the one on the Wii. It is above the SD slot, and you will have to pull open the cover to see it, which is the little rectangular cover on the front of the Wii right underneath the power and reset buttons. The sync button is the little red one.
Once you've found both buttons, hold them both down at the same time for about 3 seconds, then let go and the two should sync with each other. You only need to do this once and you should be fine.
Apr 20, 2011 | Video Game Consoles & Games
I have 3 wii remotes was using one that had batteries it died so i replaced all remotes with new batteries and now none of them will sync or work they just turn off right away
After replacing the batteries, you may have to do a hard sync by pressing the sync button beside the SD slot on the Wii and the sync button on the back of the Wiimote underneath the battery cover. Both buttons are a kind of dark reddish-brown colour.
Mar 25, 2011 | Nintendo Wii Console
The white wireless contoller from an older white x box 360 does not connect with the black kinnect x box 360 we just purchased.. i was told they were compatible why doesnt the white controller work with...
There is a sync button next to the Play and Charge port on the controller, all you have to do is press both the sync button on the Xbox and the controller and it should connect. On the nonslim Xbox 360's the sync button is right next to the infared sensor and the memory card slots. On the slim Xbox 360 the sync button will be right next to the usb ports on the front of the Xbox 360 console. When you successfully start the sync the led's for the controller's and console's lights will spin and be ready for you to press the sync button on the other device.
(PS, you have to have both the console and the controller on for this to work; PPS, By controller on I mean having it searching)
Feb 24, 2011 | Microsoft Xbox 360 Controller
MY CONTROLLER WONT CNNCT TO MY XBOX EVEN WEN I SYNC IT . ITS BRAND NEW.
You might have to replace the batteries in the controller, as if the battery life is low the controller will have issues syncing to the xbox 360. Just in cause, To sync the controller to the xbox 360, you must turn on the controller using the xbox guide button and then press the Wireless Sync button right next to the Controller Charging Port. Then you must press the sync button on the xbox 360. You must do this semi-quickly, or the sync process will not complete.
Lastly, You also might have a faulty controller, I suggest you go back to the store you got it from and see if they will replace the faulty controller.
Jan 20, 2011 | Microsoft Xbox 360 Controller
How to edit my contacts on my iphone
On your iphone touch contacts, then touch the contact you want, then touch edit at the top right of screen. Edit your info and then touch done at the top right of screen. Next open up itunes and then plug your USB cord up to the iphone and computer ports and wait for the ipod to show up under the devices on the left side of the screen. Then click on the ipod icon that shows up under devices at the left of the screen. Click on the info tab at the far right on top. Make sure the box is checked that says "Sync Address Book Contacts" Underneath that heading click on sync all contacts. Then click on Sync at the bottom right of the screen. Give the system a few minutes to do its thing and it will tell you on the computer screen when it is done syncing.
Jan 26, 2010 | Apple iPhone Smartphone
My Zune 4gb won't sync with my software and will not charge
I had a similar problem with my 30GB Zune. The first normal solution is to make sure that the USB port is providing enough power to the Zune to charge it by trying a different port or computer, but since your other Zune charges it is likely not the problem.
Other possibly solutions are performing a hard reset on the Zune (hold back and up until it resets), or allowing the zone to completely discharge and try again. In my case, none of these solutions worked and I was forced to send my Zune in for a new battery, which Microsoft was willing to replace for free.
Jul 29, 2009 | Microsoft Zune JS8-00001 Digital Media...
Palm TX travel charger problem
It is an issue with the slot on the device, however you can charge the device using the Sync cable, it is the safest way to charge the device.
Dec 01, 2008 | Palm TX Handheld
Can I use Firewire to charge?
Unfortunately, the iPod nano only ships with a USB 2.0 cable, which alienates many Mac users who only have USB 1.1 and Firewire ports. Although Apple offers no official support, you can both charge and sync your iPod nano, albeit slowly, using USB 1.1. Or, you can charge your iPod nano, but not sync, using Firewire.
Sep 29, 2005 | Apple iPod nano
USB Sync Cable
I dont' think so. No other PDA does - it would be quite a drain on the USB port. It isn't like powering the tiny LED in an optical mouse.
Sep 13, 2005 | Dell Axim X5 Pocket PC
27 people viewed this question
 Grubhead
Grubhead
