Question about Tag Heuer Kirium Quartz WL111E.BA0700 Wrist Watch
The seconds hand ticks at 4 secs a time
My Tag Kirium's seconds hand is ticking at 4 seconds a time. Its still managing to keep the time accurately however i am worried that this may effect the watch in the long run or be a signal from the watch that all is not well. Has any one had a simular problem? Or know what this may mean for my time piece? Gavin
Don't whatever you do allow the watch to be sent to Tag, as they are very likely to state that the watch needs a service at a cost of £125 after having your watch for 8 weeks (they charge £40 for a new battery which is bad enough) . This they do all the time and seems a bit if a scam. They state that the internals need cleaning by their specialists. Lets just think about this. A hermetically sealed watch to 200 meters has got dirty inside! They said this to me and so I asked for the watch back. They had removed the back of the watch, so I had a look inside and in the intervening weeks the run down battery had corroded. Luckily the terminals are gold and resistant, so I replaced the insulating disk which had corroded with a disc of thin plastic from a water bottle label and bought a battery for £1.36 and all has been dandy ever since. If you are concerned to do the same, an independent watch specialist will change the battery and repressurise for between £25-35
Posted on Nov 19, 2007
    Sniper:
  • 51 Answers
This is a feature that let's you know the battery is low on power. Take it to a Qualified Watchmaker for replacment.This watch must must be pressure tested to insure that it remain water tight Don
Posted on May 22, 2007
My omega deville ladies prestige quartz is losing time. There is no second hand on the watch and the minute hand seems to tick every 10 secs or so. It has just had a new battery replaced by omega...
Yes. The minute hand ticking every 10 seconds is normal. Losing time is either battery or a movement malfunction. Only a trained watchmaker (or presumably Omega) can determine which. Take it back to Omega
Oct 10, 2012 | Omega De Ville Prestige Quartz Small...
MINUTE HAND TICKING EVERY 4 SECONDS INSTEAD OF EVERY SECOND
If its a quatz movement - could it be that your battery needs replacing? This is a feature of my Tag 6000 so I assume yours is the same.
Aug 26, 2010 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Second hand stops, then ticks four ticks very fast then stops,
It may be that the battery is getting near the end of its life.
May 05, 2010 | Tag Heuer WAH1112.BT0714 Formula 1 watch
I reset the date and now the second hand ticks at
This is END OF BATTERY LIFE warning. Replace the battery and everything will be fine. Rate me plz.
Mar 04, 2010 | Tag Heuer Watches
My tag professional ticks over every 4
Your battery is running low and should be changed soon.
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
Feb 17, 2010 | Watches
Second hand moves in 4 second increments
when watch act like this most of the time required new battery
any expert watchmaker well change it ,, and if you are in chicago
we do change battery on tag.
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Sep 23, 2009 | Tag Heuer Kirium (CL1212.BA0705)...
Second hand not sweeping but jumps at 5 secs intervals. Appears to be keeping accurate time.
When the second hand moves in short jumps rather than a smooth sweep or a second-by-second hop, it means that the battery is about to run out. Usually, with a week or two the watch will stop working altogether. You should go and have it changed as soon as possible.
Aug 02, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Seconds hand starts ticking then stops
Your band may be too loose. This is the model that moves when worn correct?
May 12, 2009 | Tag Heuer Automatic Chronograph Series...
Second hand movement
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
Mar 07, 2009 | Tag Heuer cj1110.ba0576 Wristwatch
Tag watch second hand skips
Yes it's the battery. Please make sure to take it to someone QUALIFIED This watch requires that all the gaskets be replaced and pressure tested at the time you have the battery replaced
Donald McPherson
www.finewatchmaking.com
Nov 30, 2007 | Tag Heuer WK1111BA0317 wristwatch
Tag Heuer Kirium Quartz WL111E.BA0700 Wrist Watch Logo
322 people viewed this question
Top Tag Heuer Watches Experts
Arturs Kalnins
Arturs Kalnins
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
