Question about Dryers
This is a beko washing machine worked fine till other day and I had to drain it manually was full and I can not change setting just locked on spin end and no spin light is up for some reason , when I
    Problem Solver:
  • 8 Answers
Try to reset is by tapping on start button for more then 30 second if doesnt help pull up the elec plug and leave it more then 2 hours!!
Posted on Nov 05, 2012
2 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: clothes washing machine
Fist off the unit is operating ok it was designed to only spin after the water is let out. by you opening the lid and closing it you have paused the machine (opening the lid) and started it back up This function is also built in the timer to pause the machine then go into spin.. The timer sounds like it has a dead spot in it. is this the only place in the cycle it does this ???? or does it stick and not advance say in the Agitate portion of the cycle?? there is a small timer motor on the timer that advances it it could be going out l. If you check that out with no luck the part # for the timer is 3954449 is is about $102.00 at www.sears.com it is $109.00 at www.apdepot.com the little drive motor on the timer is not a replaceable part the whole timer will have to be replaced
Hope this Fixes Ya
Posted on Feb 16, 2008
Beko WMB71442w i have recently moved house and my
you need to take your drain hose off at the exit end it sounds like this end under has a bung in it so remove it ???
Nov 03, 2013 | Frigidaire ATF6000ES Front Load Washer
My beko 1613 washing machine wont drain, and how do i operate the dial
Hi if your beko 1613 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below. At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
Mar 10, 2012 | Beko Washing Machines
My beko washing machine is stuck on the end spin cycle and stops and starts a spin in short bursts.it has water in it and wont move on from this.
Hi jennyandeddy,
Most likely your washing machine is trying to drain, but cannot, and as such cannot start to spin.
Please follow my Tip below, for detailed directions on how to access, drain & clean your Drain Pump Filter (Please Note: Your Filter compartment is located at the Bottom Right):
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 13, 2011 | Washing Machines
Washing machine won't rinse, drain or spin
COULD BE THE PUMP MOTOR GONE BUT FIRST CHECK THE FLUF FILTER IF FITTED
Dec 30, 2009 | Washing Machines
Beko eco care WMA 10W: The washing is always very
eko eco care wma10w is making loud noise when on full spin, have looked at belt seems to be fine
Nov 19, 2009 | Washing Machines
Beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Jul 01, 2009 | Washing Machines
Washing machine wont spin (beko 1512 s)
Hi if your beko 1512 s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
you might find this test video helpful but only do it if you have checked the motor
Mar 19, 2009 | Washing Machines
Beko wma 510 washing machien leaving clothes un rinsed and wet.
Find out where your filter is & clean it out thoroughly, refit.
May 10, 2008 | Washing Machines
Dryers Logo
124 people viewed this question
Top Dryers Experts
