Question about Kingston DataTraveler Mini Fun G2 4GB USB 2.0 Flash Drive
I have a 4GB Kingston DataTraveler that display a 0 bytes capacity, how to repair it?
  • Norman Bersalote Feb 18, 2013
    My kingston usb 4Gig was reformatted twice using the low level format, after that when i try to insert in the usb port, the drive will refresh always and once i selected the drive the message will appear will be "No disk inserted"
  • Brian Sullivan
    Brian Sullivan Feb 18, 2013
    which operating system ? W 7 First, please disconnect all USB devices and then perform the following steps Click Start button, type devmgmt.msc in the Search bar and press Enter. Click Continue if necessary.In Device Manager, double click to expand Universal Serial Bus controllers, right click on the Host Controller, click Uninstall and click OK.Repeat the step 2 to uninstall all items under Universal Serial Bus controllers.Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
  • Kingston Master
  • 27,725 Answers
Click start control panel administrate tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not
do anything while the chkdsk utility is in progress any input may damage this drive
i have found the best results ticking in one box the returning after it has finished then ticking the other box
it might take some time depending on the size of your disk but be patient
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved
this may vary depending on your operating system
if you need more help with this post a reply
hope it helps
Posted on Nov 05, 2012
SOURCE: my 8gb kingston datatraveler apears good but cant open at all
may be toomuch virus
Posted on Apr 17, 2010
jncojr
  • 47 Answers
SOURCE: Describe your kingston usb repair tool Problem
Plug it into the computer, go to My Computer, right-click your USB drive and format it with the files system as FAT.
Posted on Mar 14, 2010
  • 244 Answers
SOURCE: sandisk 4gb won't open, shows 0 bytes free and 0
if it's new, you may need to format it. on desktop, click on 'my computer' and see if it's listed on the removable device list, right click on it and choose 'format'. then run it. once it's formatted, it should work! check your set-up settings (should tell you which F key to push to enter set-up when you boot-up the computer). there should be 'navigation' choices at the bottom of the screen. if your OS isn't set to 'plug and play', then change it to 'plug and play'- that allows peripherals to be detected, and installed by the OS. so check it out!
good luck!
Posted on Oct 02, 2009
  • 10406 Answers
SOURCE: My computer won't recognise my 4gb kingston
Try the stick in a different USB port on your computer.
Try the stick in some other computer.
If it does not work, it could be defective -- take it back to where you bought it, and get them to demonstrate that it works in one of their computers, or get them to replace it.
Posted on Apr 10, 2010
allanhunt
  • 135 Answers
SOURCE: KINGSTON FLASH DRIVE NOT RECOGNISED BY MY MAC
The drive letter of your Kingston flash drive is already used by another storage device. You may need to change the drive letter of your flash drive by going to the disk management.
Posted on Apr 04, 2010
Kingston Datatraveler G3 8GB VID=04F2 PID=B026 Can't Format, 0 byte yongkowidjaya@ymail.com
click start click on my computer you should see your usb drive
right click then select format
another way is to control panel administrative tools computer management disk management right click on your drive select format
Oct 24, 2013 | Kingston Computers & Internet
Where can I get instruction on how to use your 4GB DataTraveler - G3 - USB 2.0 ?
Hello Gwolk,
The Kingston 4GB DataTraveler Generation 3 (G3) USB 2.0 is a durable 4GB flash memory drive for use with both Macintosh and PC computers. It may be used to transfer files from one platform to another, or to carry files and small applications on a continuing basis. Having no moving parts, flash drives are exceptionally durable and reliable for years of use.Simple - just plug into any USB port
Aug 16, 2011 | Kingston Digital 4GB DATATRAVELER C10...
The USB flash drive doesnot shows the file system option and shows 0 of 0 bytes free.
There will be 3 reasons of this problems.
If you not not connects this drive properly to system it will show drive property 00 bytes. If you has set up password for this drive then this problem will appeared OR drive is damaged & stopped working. If you trying to connect memory card then change your card reader.
If this flash drive in warranty period then go to authorized service center & give it for replacement.
Thanks.
Happy to help you.
Apr 30, 2010 | Kingston 4GB Secure Digital High Capacity...
I can not format my usb and the total capasity
Format the Data Traveler:
Warning! All data will be lost.
1. Insert the DataTraveler into a USB port.
2. Right click the Start button via the Windows Start menu and slect Explore.
3. Locate and right click the Kingston removable drive.
4. Select Format from the pop-up menu.
Note: Always use standard FAT for drives 2GB and smaller. Always use FAT32 for drives 4GB and larger.
5. Click the Start button. A format Removable Disk Warning will come up. Choose OK if you want to format your drive. After the drive has been formated you will receive a Format Complete box. Click the OK button.
Hope that helps.
Jan 12, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston Datatraveler 2GB Failure
Try formatting the drive. Should be a problem with the file system.
Jul 26, 2009 | Kingston Technologies 512MB DataTraveler I...
My ped drive kingston datatraveller 4gb doesnot work in win98
I think you will find that the card works fine but your computer doesnt recognise the card reader properly. Windows 98 does not properly recognise most usb devices but Windows 98SE does although I am not sure if it will recognise usb2 properly.
Jun 04, 2009 | Kingston 4GB Secure Digital High Capacity...
Files in my kingston pendrive does not open up
Hi manoj_clc,
The "other PC" needs to have the same application installed that created the files. It sounds likely that is the problem for the other PC. If the files are failing to open using the PC that originally copied the files, then try formatting the USB drive (formatting deletes all data). Before you copy the file again, make sure the same file opens from your computer prior to copying it. Now copy the file to it the USB drive again.
Kingston Tech Support
May 03, 2009 | Kingston 4GB Secure Digital High Capacity...
Kingston DataTraveler Mini Fun G2 4GB USB 2.0 Flash Drive Logo
1,337 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
