Question about Suunto Vector Wristwatch
Altimeter setting creeps up on Suunto Vector
I set the altimeter at 50 feet when I received the watch 10 days ago and it was at 480 feet today. I haven't left the local area.
Also, the baro pressure reads 29.95 but the local sources say it's actually 30.08. Is this an acceptable variation?
  • Martguz Feb 25, 2009
    I have a Suunto vector, it was working properly until it started to show very high "negative readings" in the altimeter function. The rest is ok. What can I do?
  • 2,334 Answers
It sounds like IC (integrated Circuit) in your watch is mulfunctioning, but can be something else. Can't say without inspection.None of the readings mentioned by you is acceptable.
As the watch is purely microelectronic, there is nothing you can do but to take it back to the retailer and ask for repair or replacement. If your watch is just 10 days old, this must be done under warranty and at no cost to you.
Don't forget to rate, please.
Posted on Jan 05, 2009
    Problem Solver:
  • 5 Answers
The reading of the altimeter will always change dramatically over time, even over a few hours. This is due to the fact that your altimeter uses barometric pressure to figure out altitude. Barometric pressure is continuously changing and so you need to frequently recalibrate you watch so that it can read accurately. I believe this is mentioned in the manual. It even recommends recalibrating altitude everytime you are at known height when on a day walk, so that you'll get the greatest accuracy. As for the barometric pressure not reading 100% accurate relative to the local forecast, it can depend completely on where the 'forecast' reading taken, unless it's at exactly the same altitude and within say a 5 mile radius of you location, then there is plenty of room for deviation. Having said, that barometric pressure you gave must be in imperial measurement and so I'm not sure how great a difference there is between 29.95 and 30.08. This can depend on what kind of area you're using it in- temperate climates and / or mountainous and coastal areas are much more subject to barometric pressure changes compared to say flat, dry, continental interior areas.
Posted on Jan 27, 2010
What is altimeter means
The altimeter records your elevation above sea level. Useful when mountain climbing, Tour De France cycle racing the mountain section or flying, which I am sure you do almost every day :>)
Mar 04, 2016 | Watches
How to switch altimeter indication from feet to meter
If you're using an altimeter, they're always in feet. Standard aeronautical practice.
Mar 14, 2015 | Casio Protrek Triple Sensor Prg 110T 7VDR...
The screen is swithing between compass - baro -
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
Feb 27, 2010 | Casio PAG40B-2V Wrist Watch
How does the altimeter function work? we can't find it on the enclosed instructions
Altimeters on watches are usually based on barometric pressure, since the pressure changes all the time you generally need to adjust the altimeter to a known altitude. You can look on USGS website to find the altitude of your area, or simply type in "altitude of city, state" in a search engine.
I hope I understood your question; if not, please reply.
Oct 17, 2009 | Timex Adventure Tech Altimeter 41501 Wrist...
Enter Altimeter Mode
Press and hold Adjust Button
Now press Baro Button
(It will off Auto Light Function)
Oct 25, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Tissot T-Touch Baro way too high
Try to recalibrate the Baro/Altimeter as below:
Certain functions need to be calibrated. The altimeter and the Meteo are tied together. When a customer gets the watch, they should calibrate to either the Meteo or Altimeter. The easiest way to find out the altitude of the nearest airport (you can usually get this on line) and then go to the airport and adjust the watch. This will also calibrate the Meteo.
To calibrate the Altimeter:
1. Activate Crystal
2. Press Altimeter
3. Press and hold top + button until the watch beeps and display flashes.
4. Use + and – buttons to adjust altitude
5. Press center of dial to lock in.
Aug 05, 2008 | Tissot T-Touch T33159851 Wrist Watch
Tissot T-Touch : Faulty reading on Thermo, no reading on Altimeter and meteo not working either
If it's under warranty by all means pursue a fix. You might have to send it to a warranty center instead of working with your local dealer.
"Water proof" and "water resistant" are very different. About 20 years ago all watch companies stopped promising waterproof and started using the term water resistant. It gives them wiggle room in the guarantee, unfortunately. I believe T-Touch is supposed to be water resistant to only a few meters.
Nov 21, 2007 | Tissot T-Touch T33159851 Wrist Watch
1. How do you know the meteo is wrong? Are you comparing against a known good measurement device?
2. The altimeter requires adjustment every few days or whenever there's a weather change. Select the altimeter, hold the upper or lower button until you have the correct altimeter reading for where you are and it will hold for a few days.
For example, I know my home is at 100m elevation (I checked on a topo map) so I reset it to 100m when I leave the house in the morning. It varies (in my case) by over 100m in either direction, depending on the weather.
Nov 03, 2007 | Tissot T-Touch T33159851 Wrist Watch
My old field watch is showing an err (error) and the internal klight wont work
I changed the battery in my PRT 50 but Alt and Baro still not working the light and Compass however is??
Oct 27, 2007 | Watches
Suunto Vector Wristwatch Logo
414 people viewed this question
Top Suunto Watches Experts
Ansel Alberto
Ansel Alberto
Andrew Taylor
Andrew Taylor
Are you a Suunto Watch Expert? Answer questions, earn points and help others
