I have 3 to 4 months old canon Imagerunner 2420L Printer *** photostat without duplex or any network /scanning facility.The Printout coming very faded, if I print on the backside of the printout . Eve
The dealer has tested HVT, Power supply, replaced toner completely and even replaced the drum. The shortcoming has not been removed completely. I used to get printouts on the backside as demanded by the various customers. I have noted that printout is not coming on the heated page. If I place the page in the side for a few minutes, then the printout will be alright! Strange
  • Lebanon Raingam
    Lebanon Raingam Feb 21, 2013
    Hi! Have you somehow solved this problem? I have the exact problem with my Canon IR 2420L. Have replaced and checked whatever you've tried. As David Spicer suggested, I wanna try with the sensor in the Developer Unit, but I couldn't find the sensor in Service Manual or on any other sources. Please share what you've got to fix this. Thanking.
  • 3 Answers
Hi my immage scanner ir2420 display says front left side is open /close but i close evry thing steel the same falts so may be power suply problem how can i get diyagram of power supply plz
Posted on Apr 13, 2014
Gunslinger
  • 62 Answers
SOURCE: Light and broken printout and black mark on the backside
Have the service people set the machine to add toner(per pixelcount) and test run it for a day or two. If this works it means the sensor in the developer unit that tells the machine to add toner from the cartridge is bad. If that is the case replace the sensor. It sounds like the machine is not adding toner to itself. Have them also test the toner motor.
Posted on Oct 21, 2007
keithd2704
  • 56 Answers
SOURCE: Dirty Background on Printouts
The most likely problem is not with the drum unit but rather with the developer unit and there is a leakage current within the unit causing the 'ghosting' on the printed images.
I would suggest that you replace the developer unit within the system. It is quite possible that the waste toner blade is contaminated with debris from using non-OEM toner within the unit. Therefore leaving residual toner particles on the surface of the drum.
Try this solution and see if that corrects your problem. This solution can be applied to virtually any laser printer, copier or MFP device in the industry. The problem is nearly 99% of the time related to CHEAP toner cartridges that are refilled or refurbished and the company doing the work does NOT replace the cleaning blades within the units, and they use a generic polyester-resin toner that does not conform to manufacturer standards.
I worked as a Design Engineer for Kyocera-Mita America for nearly 6 years and have seen this problem many times in the industry. The price you save on using recycled cartridges ends up costing you more when you have to replace a developer or drum unit.
Hope this information helps you out.
Cheers,
Keith
Posted on Oct 23, 2008
Benimur
  • 6966 Answers
SOURCE: empty ms word printout
Hi, You can try: 1. go to Start, Printer and Faxes, right click on your 3745, click on Properties, Printing Preference; 2. Check to see if you have any Advanced tab or button; 3. Check if you can set the printer to text only; 4. Check if you can set the printer to use black ink only. 5. In MS Word, verify through the use of Print Preview that your document is as you would want to be printed; 6. In some instances you may have to set manually text color in MS Word. While your document is open, click Ctrl + A to select all, then choose font color to "Black". Alternately, in your MS Word, you can click on "Format", "Font", "Font Color" set to "Black" rather than "Automatic" and set this as the "Default" setting. Hope this be of some help/idea. Post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Sep 29, 2007
Cogz
  • 1326 Answers
SOURCE: Kyocera CS 3232 copier
What is a print out grid??? Need to know what you need to print?? Did you try graph paper???
Posted on May 14, 2008
SOURCE: Shared HP 1020 Printing problem
Your question is not clear.
Please give some configuration info. e.g
Operating system?
Explorer Version?
Posted on Aug 25, 2008
E000007 ir 2420l
problem with fixing assy
Feb 06, 2014 | Canon imageRUNNER 2200
In my canon xerox imagerunner 2420L displays error massege
i have canon image runner 2420l copier and it show the error message restart the machine if problem persists, call service rep. **E000007-0000 how can i solve the problem/ and fix the machine
Nov 04, 2012 | Office Equipment & Supplies
How to change paper size from computer & not have to physically go to printer
when you are printing something get to the print area and before pressing the print button click on printer properties and then select the paper size from the list available
save then press the print button
it is only good for the job you are printing as the next job , it will revert to the default setting
Apr 14, 2017 | Canon ImageRunner 1025IF Copier with DOC...
No need how to copy on both sides at once
copiers that have that facility has got the DUPLEX as an addition facility.
Your copier if it does not have that facility then it can not copy on both sides at once.
next time when buying a copier ask for one that has a DUPLEX.
Jul 14, 2011 | Canon imageRUNNER 1630 Copier
How to set ip address in canon ir 2830 i want network scan in this machine and send me complete information about net work scan
I need fax facility of my canon ir2830 network machine. pl let me know how to setup for fax in my canon ir2830
Dec 31, 2010 | Canon imageRUNNER 400S Copier
How do I scan on the Canon imageRUNNER 3300
instalation of photocopier/scanner with pc model no IR-3300. Kindly tell me the procedure to install it and make it functioning...
Mar 26, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
How to find the IP Address canon IR3570
you should be able to go through the print menu on the printer and look for something that says information or configuration and look for network settings and print this page.
ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS
Nov 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Canon ImageRunner 2016 - scanner Not working properly
Ir 2016, can be onlly pull scanner, so that means that you must have installed scan gear, selected in scan gear, and over microsoft word or similar insert scan ( INSERT PICTURE FROM SCANNER OR CAMERA ), but the machine must be in scan mode, put original on platen or dadf, and then "pull it"from PC.
Hope that helped
pls.rate
Sep 30, 2009 | Canon imageRUNNER 2016 All-In-One Laser...
Unable to scan document
try to add your printer so that you can scan, just click start of your computer then go to all program the add printer or scansoft then restart your pc to take effect
Jun 30, 2009 | Canon (6981A002AA) for imagerunner 2200,...
654 people viewed this question
jasbo
jasbo
