Question about Home
Schwab concealed cistern - Home
4 Suggested Answers
bloues
  • 56 Answers
SOURCE: I have a concealed cistern that no longer flushes,
Consealed cysterns are always a bit hard to exsplian, so i segest u get a plumber, bt not an idoit cas u can fix it without breaking the wall. u take off actuater plate and undo the flush cover plate. then inside u must turn that device left to get it out, its tricky , the device splits in 2 peases. get new one and install it same way. bt 1st chek stuff like is the flush arm ect installed rite befor u replace it. might wane call a plumber i cant say serten here cos every 1 differs
Posted on Jul 19, 2010
  • 67 Answers
SOURCE: What are the disadvantages of Concealed Cistern
The biggest disadvantage is that they are more complex than the standard gravity fed toilets. More parts, more things that can go wrong. However, they generally operate just as trouble free as any other fixture.
Posted on Aug 03, 2010
  • 15273 Answers
SOURCE: Schwab concealed cistern water running into toilet how to clean limescale off fill valve? Model UP187.12
there are products such as clr limeaway ect that can be applied if to far gone will probable need to replace the valve unit
Posted on May 02, 2018
May 02, 2018 | Home
I have a leak coming through my ceiling from the ensuite toilet above. It is an ideal standard wall hung with concealed cistern behind tiles. There is no obvious access panel. The tiled wall is flush.
The flush control panel normally comes off. You can then hopefully see inside. You won't be able to see much though as the cistern will be in the way...
Places to look for leaks are:
Soil pipe to pan
Cistern to flush pipe
Flush pipe to pan
Cistern overflow.
Apr 17, 2017 | Home
Hissing concealed cistern
The float valve needs adjusted or replaced.
Nov 30, 2014 | Kohler Home
Caroma toilet 12years old, concealed cistern. Water leaking around base when toilet is flushed. water level maintained when not flushing, so the leak must be between the cistern and the bowl. Had a plumber...
Fixing a leaky toilet is actually rather simple, requiring few tools and just a little time and effort. In looking at Caroma toilets on Google, they appear to be just a standard type of unit, and should present few if any problems for yourself or any handyman of modest skill.
If it is leaking around the base of the toilet - where the toilet sits on the floor, the repair item is a simple wax seal. Here is a tutorial to effect this repair: Replace Toilet Wax Ring. The wax ring is very inexpensive, usually $5 to $10 USD.
If the water is leaking from between the tank (cistern) and the toilet bowl, the job is even easier, as it does not require lifting and moving the entire toilet. A good tutorial for that repair is here: How to Replace Tank to Bowl Gasket . The gaskets, new nuts, bolts and rubber seals come in a kit and also cost only $5 to $10 USD.
I am sorry to hear your Plumber insisted you buy an entire new toilet, but do remember he is in the business of making money!
Jan 28, 2014 | Home
Tavistock Vortex White Slimline Concealed Cistern | VOR790
the clear and the blue pipes control half and full flush. They should both be connected to the main cistern. The small button should give a half flush.
Mar 26, 2012 | Home
Push button not operating fully/correctly. cistern flushes sometimes, but not always and is only two years old. It's a Grohe concealed cistern.
hey,
Check your button/s panel, check that the hoses are connected firmly.
Disconnect the hose and blow air through it, does it work now?
If it works ok, you need a new buttons panel. (or fix it).
If problem remains, you need to disassemble the pneumatic valve and check / clean/ repair it.
Look at this guide that might help you. though it is not the exact model, principle is the same.
Have fun
Avi
Grohe GD2 flush system concealed cistern repair fix and disassembly...
Nov 23, 2009 | Grohe Home
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
