Question about Samsung Lands Phones
Text messeging on my samsung instinct while texting a menu board came up that allowed for fixing mis-spelled words i didnt mean 2 cut it on i want 2 cut it off now but cant get back to that menu screen can u help
  • 45 Answers
Try to switch off the T9 dictionary off .thank you
Posted on Jan 05, 2009
Is the charge for texting the same for android phone as regular
no,
for android phones only 160 words per sms are allowed
that means if u type a message of 210 words it will be charges as 2 sms
Feb 24, 2014 | Samsung Cell Phones
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
How do you type things and use spell cheack?
i will give you instructions
Instructions
  1. Select the text you want to spell check, or place the cursor anywhere in the text to spell check the entire document.
  2. Go to the Tools menu.
  3. Select Spelling and Grammar. The Spelling and Grammar window opens, and Word begins spell checking.
  4. View any flagged words or phrases in the upper-left window. Just above this window, you will see the reason Word has flagged this text.
  5. Check the Suggestions window in the lower-left corner of the Spelling and Grammar window for correction suggestions.
  6. Click the Change button to make the suggested correction.
  7. Click Change All if you want all instances of this error corrected within the text that you are spell checking.
  8. Enter your own change if you disagree with the suggested correction (or if there is no suggestion) by placing your cursor in the flagged text window and correcting the text as you would in any Word document.
  9. Click the Change button to implement your correction.
  10. Click Ignore if no correction is needed; click Ignore All to skip all further occurrences of this "misspelling."
Nov 29, 2010 | HP Mini 1000 Netbook
How do I turn off text messages completely. Being spammed to death at 30 seconds per text. I can't keep paying for text messages . I don't even use this texting thing. I want it diabled completely
click REPLY to the SPAM TEXT MESSAGES. In your message type this word in all capital letters:: STOP
If that does not work, enter your LG phone menu, go to your messages, find MESSAGE SETTINGS, there you will be able to find options that will help you BLOCK RECEIVING TEXT MESSAGES. It may also be found in PHONE SETTINGS, in the SECURITY SECTION under RESTRICTIONS. There you are able to BLOCK INCOMING/OUTGOING PHONE CALLS AND TEXT MESSAGES AS WELL...
Nov 22, 2010 | LG Cell Phones
NEED MORE THAN 160 CHARACTERS FOR TEXTING WITH MY SAMSUNG INSTINCT S30. IS ANYTHING OUT THERE?
160 character limit is 1) a limit of SMS not the phone 2) Your phone should be able to send multiple texts or SMS messages if your character count goes over the 160 limit. I know my iPhone allows for it but my Blackberry Storm does not. You might think about using email to send larger messages as a whole.
Sep 30, 2010 | Samsung Instinct Cell Phone
How do i find spell check on printshop 2.0
If you will check the PS Help files, you'll see that those Help files say this about Spell Check:
To check the spelling in your whole project, make sure that none of the text boxes are selected. (Click anywhere off the edge of the project page.)
Tip: To check the spelling in only one text box, click that text box.
Choose Spell Check from the Tools menu.
If you have a misspelled word, the Check Spelling dialog box displays.
Aug 24, 2010 | Computers & Internet
How can I put a signature on my text messages?
  1. Step 1 Power on* Make sure your cell is on this is a no brainer but it needs to be on in order to send and recieve a text, so turn on that cell phone.
  2. Step 2 Menu* On my cell phone I go to the Menu in order to see my text messages what ever option you have go to where you recieve or make a text message. Also after I have gone to menu I see messaging hit that option next.
  3. Step 3 Settings* This is the next option that you will to in order to add a signature to all of your outgoing text messages. Next go to all messages here you will see several options, there should be a signature option this is where you want to be in order to add the signature to every text.
  4. Step 4 Turn it on* Most phones will not have the option on to add the signature this is something you must do on your own. For my phone it only allows 15 characters than you can add whatever saying you want. Mine says live&learn&luv. I try and live by this so I thought it would be a great signature to have for my text messages.
Jun 01, 2010 | Samsung FOR SAMSUNG INSTINCT S30 M810...
Open Office Writer spell check problem
Make sure it is the correct language: select the text, go to "format" > "character", select the "font" tab, and change the language appropriately.
Dec 31, 2008 | Computers & Internet
Sidekick lx spacebar
Go to:
http://www.fixmysidekick.com/sidekick-lx-or-sidekick-2008-space-bar-not-working/164/
Or just read this...:
sidekick2008spacebarpicture.jpgIs the space bar on your Sidekick LX not working when you are trying to text or in AIM? Do you have thesame space bar button problem on your T-mobile Sidekick 2008? Does the Sidekick spacebar work in other apps though?
If so then this fix is for you.
1. Open the AutoText & Spelling screen. From the Jump screen, press the MENU button, then select Settings > AutoText & Spelling.
2. Uncheck the following settings:
    • Highlight misspelled words
    • Auto correct spelling
3. Exit out of the settings screen and try it out.
Hopefully, this will have solved your issue.
How to check for misspelled words with these two options unchecked?
Run a manual spell check on T-mobile Sidekick: To run a spell check while in a text field from any Edit Text submenu, or by using the keyboard shortcut by pressing MENU +S.
Dec 19, 2008 | Sharp Sidekick LX Smartphone
Changing text messege ringtone!
Try to find Sound setting at your phone menu, and go to mesagge tone and try to change it with any tone that you like.
AFAIK, samsung only provide 10 different message tone.
Aug 05, 2008 | Samsung SCH-a670
Lands Phones Logo
76 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
