Televison & Video Logo
Anonymous Posted on Nov 05, 2012
My son hit my 50 inch plasma with remote now it just stays on standbye
Stays on stand bye
Anonymous
Level 3:
Top Expert:
  • Master 14,553 Answers
  • Posted on Nov 05, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718121
Points
48227
If it struck the screen or near it the display panel (screen unit) may be damaged inside---fatal as the part alone costs more than a new set and if set was on or turned on after that damage may now extend to a board or boards inside the set.
5 Related Answers
A
Anonymous
  • Posted on Apr 12, 2007
SOURCE: LG plasma tv 42 and 50 inch
I have a 42inch LG plasma TV. It has a 4 inch wide stripe on the right side from the top to the bottom that is all different colors and goes from the topto the bottom.
Anonymous
  • Posted on Oct 24, 2008
SOURCE: we have samsung 50 inch plasma tv, we have only half a screen
I have a Phillips 50 inch Plasma. About two months out of warranty the top half of the screen would go black. Sometimes when we tapped on the back behind the upper right hand corner the picture would return. I did some research online and found that there is a Main Y sustain board (much like a mother board in a computer) and connected to that board is a upper Y Buffer board and a Lower Y buffer board. According to my research these boards seem to be the source of the problem. I am assuming that the upper buffer controls the top half of my screen and the lower controls the bottom. I removed the back of my TV (about 50 small screws) and searched for these parts by part number. Surprisingly all of the parts in my Phillips are made by Samsung. I found the parts on ebay at shopjimmy.com. I decided to try replacing the upper Y buffer first. I ordered it from shopjimmy for about 100.00. When I received the part I started to remove my upper Y buffer and realized that the new part was slightly different. The part number was the same but the REV. number was slightly different. The new part was missing a small white connector that connects the upper buffer to the lower buffer. I sent it back for an exchange for the right part with no problem. Ok so here is the interesting piece of this little adventure. When I started to remove my upper Y buffer I removed the screws and started to pull on it to loosen it. When I noticed that I had the wrong part I pushed it back into place and put the screws back . My TV has worked perfectly since I did that, with my original part. It has only been about two months, but if you are in the same situation it might be worth a try.
Anonymous
  • Posted on Mar 05, 2009
SOURCE: 50 inch plasma blank screen
I bought my Philips Magnavox 50" plasma in June of 2007. In february of 2009, I noticed increasingly longer delays in the video coming on after turning on the power and then the audio began to delay coming on. After a few weeks of this problem the audio and video then stopped coming on at all. However, there was power going to the unit because the green power light was working. I noticed over 50 other consumers on this website had the same problem. WITH THE HELP OF OTHERS ON THIS WEBSITE, I HAVE FIXED THE PROBLEM FOR $40. YES, FOR LESS THAN $100.00 I HAVE A WORKING HDTV AGAIN, BUT WITH NO THANKS TO PHILIPS - MAGNAVOX. THEY WERE USELESS.
HERE IS THE FIX:
1. Unplug your power supply cord.
2. Remove back panel on your HD.
3. Look for capacitors that have a bubbled or slightly raised and rounded top. This indicates the capacitors have overheated or leaked and need to be replaced. The normal look is a flat surface with no raised features at all. (I had two bad capacitors that were side-by-side and identical: 3300uf 10v. Also, they should be located on the power supply board. My power supply board is in the middle of my 50" plasma.)
4. Go to an electronics repair store or Radio Shack and see if they carry your capacitor type and size and replace them yourself if you are comfortable with removing the capacitors and soldering new ones to the power supply board. The capacitors will cost you $2.00 each or less.
5. I was not comfortable replacing the capacitors myself so I removed the power supply board by removing the screws and unplugging several wire connections. This was not difficult at all. I then brought the power supply board to a local electronics shop that did repairs on HDTVs and simply asked them to remove the bad capacitors and solder two new capacitors onto the power supply board. They did it for $40, which included cost for the 2 new capacitors, while I waited and it only took about 10 minutes.
6. I replaced the power supply board and back panel of TV and it worked!!!
Some people on this sight suggested replacing the capacitors with some that have higher temperature ratings. Based on that advice, I wanted to replace my two that were bad (3300uf 10v) with two rated at 4700uf 35v, but my electronics guy suggested against it. Instead, I replaced mine with 3300uf 50v, with the only difference from the original parts being the higher voltage (50v instead of 10v). I figure if the problem occurs again, I now know I can get it fixed for less than $50.00. Philips - Magnavox should be ashamed for such poor customer service and not telling people about this simple fix. When I called their customer service support number I was simply directed to a repair place --over two hours away!!!
Anonymous
  • Posted on Oct 03, 2009
SOURCE: I have a Philips 50 inch plasma tv. The light is
I have Philips 50 inch plasma TV purchased almost exactly 3 years ago. Completely out of warranty. Paid 1999 bucks for it new. Now Plasma TVs similar to this are 800 bucks. I figured the cost of a repair tech coming to the house would be around 500 bucks.. so I decided I could "do no harm" and look at the power supply. Sure enough, two 3300 uF caps were swollen.. I am far from a true electrical repair person, and if it were not for the caps being swollen, would have no idea that they were bad. I am however a little bit skilled in soldering. So I ordered replacements for about 8 bucks. The caps were actually only 1.50 ea. but the min order fee and shipping brought it to about 8 bucks.. I got them from studiosoundelectronics.com . They came in today and installed them... to my astonishment, my TV works as good as it did when it was new... I must say that I am dissapointed in Philips.. and will never buy another product from them. If it is out of warranty.. they will not even talk to you.. I don't think it is too much to ask when you spend 1999 bucks on a product from them.. I expected my TV to have more than 2.999 years in life in it. Thanks a million to this site for providing soulutions for folks..
Jeff
Florence AL
Chi Chu
  • 8457 Answers
  • Posted on Jan 08, 2010
SOURCE: my vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
2answers
REMOVEABLE BASE STAND
I think this aftermarket stand will work. The reviews mention a couple of people using this with heavier lcd/plasma screens with no problems. Hope this helps!
http://www.amazon.com/Universal-Stand-Base-Wall-Mount/dp/B00DZVPFGU/ref=sr_1_5?ie=UTF8&qid=1399529274&sr=8-5&keywords=50+inch+universal+tv+stand
I NEED A TABLE TOP STAND FOR 50 - 60 INCH PLASMA
I will suggest you check ebay.com or amazon.com for the table top for your 50-60 inch plasma. Any o the two sites will provide you what you need.
6helpful
5answers
LG 50 inch plasma has trouble powering up. have
Power supply board have dead capcitors.Know how to solders?These capacitors usally bulge or pop open,replaced these capacitors will solved this problem.Or tries websites Shopjimmy.com,Ebay.com to buy a Whole reburbish power supply board for the replacement.
1helpful
I need help networking a brother hl5250dn on a netgear router. It worked fine for me for about 1.5 years networked on a dlink router, and when I changed to this netgear, this feature started. After...
sounds like the printer is going on standbye mode is there setting in the options of your printer for standbye mode or is your central computer on stand bye mode to me sound like you need to check your setting in options of windows with the computer main.
1helpful
4answers
My vizio 50 inch plasma tv will not turn on. what
Everytime I turn my tv off and back on again it seems to go into standbye mode.Get flashing red light on front.It is the viera 50" plasma 1080P.Have to unplug and let it sit for a bit before I can turn it...
Check and change the capacitors in the stand by circuit parts.The problem is in the command parts 12V and 5V circiut.Check the active and the passive components.30% you need change the power supply board(Panasonic Viera).
My 50 inch plasma pioneer elite has a green color. I dont know how my son changed the color scheme on the tv but i cannot turn it back.
Check in your menu under video and see if there are 3 gamma settings for the Red, Blue and Green. Some plasma's have that feature, why, I don't know, they only cause issues with the consumer. They are listed in the service mode but if I were you I wouldn't go there and besides it's a million to one that your son happened to hit that lottery.
2answers
probably you switch was sticking causing it to behave that way.just monitor you tv if it happen once more then it will be time to call the tech.standby my brother.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
