I need the firing order to my distributor because it pops and doesnt turn on now tht i changed the distributor cap and rotor
If it's popping through the intake, you are dealing with a timing issue. I have been "twisting wrenches" for over 25 years and even though I don't know how I do it but once in a while I end up crossing spark plugs wires. Below is a picture of the correct firing order. If this is the same as you have done and since the vehicle is older it is possible that the distributer has been taken out in the past and it's possible that whoever did the work put the number 1 spot in a different position but I'm just kind of guessing.
SOURCE: Removed & replaced dist. cap and rotor on 1993 S10 Blazer 4.3 V-6
The firing order for a Chevy s10 depends on which engine you have. 1.9L engine the firing order is: 1-3-4-2 . Distributor rotates counterclockwise. 2.0L engine the firing order is: 1-3-4-2 . Distributor rotates clockwise. 2.5L engine the firing order is: 1-3-4-2 . Distributor rotates clockwise. 2.8L engine the firing order is: 1-2-3-4-5-6 . Distributor rotates clockwise. 4.3L engine the firing order is: 1-6-5-4-3-2 . Distributor rotates clockwise.
okay i put them all in order but why does it pop when i try turning it on?
