Question about Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
Wireless internet to pc
I recently was trying to secure my wireless router to keep outsiders out. i changed the channel, and changed other features, which caused the "security" light to come on. i changed some of the damage done but i cant hook to the internet without an ethernet cable. none of the laptops or pc can hook up through wireless, but can through ethernet cable. so internet is there but not through wireless, my question is, how can i get the wireless to work, and how to properly secure my wireless router?
    President:
  • 2,961 Answers
If you have secured the router you should have used atleast either wep or wpa, changing the channel is just for interference problems. when you use wep encryption for example you will need to type in a pasword and the router will generate a pass phrase which will be a hex 8 digit and letter mixture which is the code that you will have to enter into each pc's wireless network card. If you are using windows wireless zero configuration (WZC) a selection of wireless connections will appear within your range and then when you connect to your network a window will pop up and ask you to enter the numbers and letters that the router generated, this will have to be re entered and the wireless connection will connect. If you are using the software that came with the wireless cards this will be a similair proceedure but will probably use their own wizard. Your wired connection will work without you needing a password because it's not wireless and therefore has no need for a security password.
Posted on May 21, 2007
Randomly disconect wireless internet
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 27, 2012 | Gateway M-7315U Notebook
Error code 209600
f you are attempting to connect your Wii console online using a wireless router and you receive this error :
Ensure you are using a broadband or high speed internet connection such as cable, DSL, or fiber optics. Slower connections, such as dial up, may cause issues with the Wii or may not work properly.
Ensure there is no interfering devices by shutting off microwaves, cordless phones, wireless keyboards, and wireless mice.
Diable your firewall settings, as it may be causing a connection problem.
Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds. Be sure to test both channels to see which works better or faster.
If you are using a Netgear wireless router, disable the SPI firewall setting which is usually found under the WAN Settings of your wireless router.
If you are attempting to connect your Wii console online using the Nintendo Wireless (Wi-Fi) USB Connector and you receive this error :
If your PC is using security features or programs such as a firewall, antivirus, or antispyware, check all settings of these security features or programs to allow a successful connection.
You may try adding the following programs to your firewall list of "Trusted" applications
  • Nintendo Wi-Fi Connector USB (NintendoWFCReg.exe)
  • Setup.exe (when installing the USB Connector)
  • SoftAPInstDrv.bin
  • mdriver.exe
Temporarily disable your router's firewall which may allow the Wii console to connect online to recieve a system update. After, you may turn your firewall back on.
Jul 19, 2011 | Nintendo Wii Console
I INSTALLED THE SOFTWARE AND THE INTERNET IS CONNECTED BUT I AM TRYING TO HAVE IT WIRELESS,. WHAT SHOULD I DO? THANK YOU
WIRELESS SECURITY ISSUES
UNINSTALL THE BELKIN SETUP and router monitor from the control panel -> ADD OR REMOVE PROGRAMS (XP) PROGRAMS AND FEATURES (Vista and Win 7 )
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 01, 2010 | Belkin Basic Wireless Router
Belkin 54g router I am trying to use the wireless featur of the router but when connecting I kepp getting the message limited or no connectivitythe network is security-enabled and the password is correct...
Jun 28, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I have BELKIN G PLUS MIMO and wireless dont work,what is the problem,and i whant fixed that problem,help.
Wireless feature of the router works all the time. If it doesn't work, the router is defective. I believe you just need to configure the wireless settings of the router manually. The router has a setup page where you can change a lot of wireless settings to synchronize to your wireless computers. You can open it through http://192.168.2.1 using your Internet Explorer. Try to customize the channel to 11, change the Network Name and enable wireless security as well.
Oct 23, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cant get internet connection on my laptop
You need to change the wireless channel on your wireless router. Using your wired computer, open the router's setup page by going to internet explorer and type http://192.168.2.1 and press enter. It will prompt you for username and password. By default the username is admin and leave the password blank. Look for wireless tab and look for wireless channel. Change it to channel 11. Make sure to take note of the Wireless Security key as well under wireless security tab. Save the settings after changing the wireless channel. On you laptop, make sure to disable any firewall then try to reconnect to the wireles network.
Apr 25, 2009 | Belkin (F5D7231-4) Wireless Router
I just bought a belkin wireless router. it is a wireless G MIMO Router. i have set it up, but the number i have to type in on the address bar, it comes up 'nothing to display' i have no idea what else i...
gunja
Rank:wizard_s.gif Wiz
Rating: 85%, 88 votes hi,
Open the router page 192.168.1.1 >> type this in the internet explorer address bar.
1. the Home Page is displayed. Click Wireless from the left menu
2.The settings to Wireless section of Router appear.Click Channel and SSID.
3.Changing the Wireless Network Name (SSID)
To identify your wireless network, a name called the SSID is used. The SSID is your network name. The default network name of the Router is Belkin N1 Wireless followed by six digits that are unique to your Router. Your network name will look something like Belkin_N1_Wireless_123456.
You can change this to anything you choose, or you can leave it unchanged. Keep in mind, if you decide to change your wireless network name, and there are other wireless networks operating in your area, your network name needs to be different from other wireless networks that may be operating in your area. To change the SSID, type in the SSID that you want to use in the SSID field and click Apply Changes.
The change is immediate. If you make a change to the SSID, your wireless-equipped computers may also need to be reconfigured to connect to your new network name. Refer to the documentation of your wireless network adapter for information on making this change.
4.Changing the Wireless Channel
There are a number of operating channels from which you can choose—in the United States, there are 11 and in the United Kingdom (and most of Europe), there are 13.
In a small number of other countries, there are other channel requirements. Your Router is configured to operate on the proper channels for the country in which you reside. The channel can be changed if needed. If there are other wireless networks operating in your area, your network should be set to operate on a channel that is different than the other wireless networks.
Select channel from Wireless Channel drop-down menu. Click Apply Changes.
5.Using the Wireless Mode Switch
This switch allows you to set the Router’s wireless modes. There are several modes. Note: Some modes may require firmware updates to be enabled.
1) 802.11g only
Setting the Router to this mode will allow only 802.11g-compliant devices to join the network, keeping out any slower 802.11b devices.
2) 802.11g & 802.11b
Setting the Router to this mode will let 802.11g- and 802.11b-compliant devices to join the network.
3) 802.11n & 802.11g
Setting the Router to this mode will allow N1/draft 802.11n- and 802.11g-compliant devices to join the network, keeping out any slower 802.11b devices.
4) 802.11n only
Setting the Router to this mode will allow only N1/draft 802.11n-compliant devices to join the network, keeping out 802.11g and 802.11b devices.
5) Off
This mode will turn OFF the Router’s access point, so no wireless devices can join the network. Turning off the wireless function of your Router is a great way to secure your network when you are away from home for a long period of time, or don’t want to use the wireless feature of the Router at a certain time.
Select wireless mode from Wireless Mode drop-down menu. Click Apply Changes.
6. Using the Broadcast SSID Feature
Note: This advanced feature should be employed by advanced users only. For security, you can choose not to broadcast your network’s SSID. Doing so will keep your network name hidden from computers that are scanning for the presence of wireless networks. To turn off the broadcast of the SSID, remove the check mark from the box next to Broadcast SSID, and then click Apply Changes.
The change is immediate. Each computer now needs to be set to connect to your specific SSID; an SSID of ANY will no longer be accepted. Refer to the documentation of your wireless network adapter for information on making this change
sahil101
Rank:nonexpert_s.gif Apprentice
Rating: 92%, 6 votes open the the console page of the wireless router by typing this ip address on the address bar in the internet explorer.
192.168.1.1
it will open the console page of the router.on the left hand side
u will see an option which says wireless settings.click on
wireless settings.then u need to look for the option which says
wpa security passphrase,just put the passphrase there n
click on apply,ur wireless connx will be secured. Selah :-)
Sep 14, 2008 | Computers & Internet
I have recently bought a Belkin 54G Mod Router so that I could use my laptop with wireless connection in another room while my PC remained wire connected. I have installed it as directed but I keep losing...
a couple of question for you, is your wireless secure or did you enable security features like wep or wpa, how many people authorise people are on your network. if not secure, secure your wireless network, hackers like to kick people off their own system, upgrade the firm ware on your router, for the latest compatibility it will fix issues that arise and finally do a bios upgrade on your laptop.
May 26, 2008 | Belkin Computers & Internet
Need To Secue Network
hello!
there are so many way you can secure your wireless network.
CHANGE THE SSID AND CHANNEL
1: Open the router page 192.168.1.1 >> type this in the internet explorer address bar.
2: Click Wireless from the left menu
3: The settings to Wireless section of Router appear.Click Channel and SSID.
4: Change the Wireless Network Name (SSID) To identify your wireless network. To change the SSID, type in the SSID that you want to use in the SSID field and click Apply Changes.
5: Change the Wireless Channel to 1, 6 or 11. If there are other wireless networks operating in your area, your network should be set to operate on a channel that is different than the other wireless networks. Select channel from Wireless Channel drop-down menu. Click Apply Changes.
CHANGE THE WIRELESS MODE
Using the Wireless Mode Switch. This switch allows you to set the Router’s wireless modes. There are several modes. Note: Some modes may require firmware updates to be enabled. Select wireless mode from Wireless Mode drop-down menu. Click Apply Changes.
a) 802.11g only - this mode will allow only 802.11g-compliant devices to join the network, keeping out any slower 802.11b devices.
b) 802.11g & 802.11b - this mode will let 802.11g- and 802.11b-compliant devices to join the network.
c) 802.11n & 802.11g - this mode will allow N1/draft 802.11n- and 802.11g-compliant devices to join the network, keeping out any slower 802.11b devices.
d) 802.11n only - this mode will allow only N1/draft 802.11n-compliant devices to join the network, keeping out 802.11g and 802.11b devices.
e) Off - This mode will turn OFF the Router’s access point, so no wireless devices can join the network. Turning off the wireless function of your Router is a great way to secure your network when you are away from home for a long period of time, or don’t want to use the wireless feature of the Router at a certain time.
DISABLE SSID BROADCAST
This advanced feature will not broadcast your network’s SSID. Doing so will keep your network name hidden from computers that are scanning for the presence of wireless networks. To turn off the broadcast of the SSID, remove the check mark from the box next to Broadcast SSID, and then click Apply Changes.
ENABLE WIRELESS SECURITY
To access the security settings, click Security.
Setting WPA Security
Note: To use WPA security, your wireless network cards must be equipped with software that supports WPA. WPA-PSK uses what is known as a pre-shared key as the security key. A pre-shared key is basically a password that is between eight and 39 characters long. It can be a combination of letters, numbers, or characters.
a) From the Security Mode drop-down menu, select WPA-PSK (no server).
b) For Encryption Technique, select TKIP or AES. This setting will have to be identical on the clients that you set up.
c) Enter your pre-shared key. This can be from eight to 39 characters and can be letters, numbers, or symbols. This same key must be used on all of the clients that you set up.
d) Click Apply Changes to finish. You must now set all clients to match these settings.
ENABLE WIRELESS MAC ADDRESS FILTERING
The MAC address filter is a powerful security feature that allows you to specify which computers are allowed on the wireless network. This list applies only to wireless computers. This list can be configured so any computer attempting to access the wireless network that is not specified in the filter list will be denied access. When you enable this feature, you must enter the MAC address of each client (computer) to which you want to allow network access. The Block feature lets you turn on and off access to the network easily for any computer without having to add and remove the computer’s MAC address from the list.
Setting up an Allow Access List
1. Click MAC Access Control.
2. Select the Allow radio button to begin setting up a list of computers allowed to connect to the wireless network.
3. Next, in the MAC Address field that is blank, type in the MAC address of the wireless computer you want to be able to access the wireless network, then click Add.
4. Continue to do this until all of the computers you want to add have been entered.
May 08, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Internet connection keeps dropping
Two possible reasons
If you have hidden your network name (SSID) in the wireless configuration in the router and use WEP or WPA security there may be a bug that can result in extended disconnect periods. Recommended solution unhide the SSID and keep the WEP or WPA security.
Second there are numerous wireless devices in use. Keep your wireless phone base station away from your wireless router. Try changing the channel your router's radio uses to transmit -- Channels 1, 6 and 11 are preferred. Try one you are not using, if that does not work try the other. (If you can see the surrounding channels in you connection wizard you may want to start with one no one else is using)
Dec 01, 2007 | D-Link AirPlus G DWL-G122 802.11g/b...
Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
