Question about Homelite Mighty Lite Lawn Trimmer
What size fuel hose on a homelite hld26edn - Homelite Mighty Lite Lawn Trimmer
Homelite whipper snipper amnyal needed. I need to know the size of the cutting cord or citting line size and the fuel mix for the homlite whipper snipper model HBC265JSNB SN1008015039 LwA N197 are all...
This Homelite gas trimmer runs on a 50:1 mix of unleaded automobile gasoline and two-cycle engine oil. That is equivalent to 2.6 fluid ounces (80 ml.) of oil to one gallon of gasoline or 4 tsp. (20 ml.) of oil per quart of gas, or 2 tsp. (10 ml.) of oil per pint of gas. Don't use automotive motor oil or two-cycle outboard motor oil in your Homelite gas trimmer; they contain additives detrimental to trimmer performance. Use mixed fuel within 30 days.
Feb 07, 2018 | Garden
My 46cc Homelite will start & idle with the choke on, as soon as I push in the choke it reves up by itself then cuts off
This is fuel starvation, start by removing and replacing the fuel filter in the fuel tank, check the fuel hose up to the carb foe signs of leakage, replace hose if required.
Aug 21, 2011 | Homelite FactoryReconditioned ZR10522...
My Homelite XH2XS-0254RA Trimmer gas lines have broken off inside the gas tank, can replacement parts be obtained
Hi carlfreeland...
Yes, your fuel lines can be replaced, be sure to get the right size to fit your machine.
Go to your parts supplier with the model/serial number and manufacturer of your weedeater.
Most of the time there will be two size fuel lines, the bigger one is the one the fuel filter inside your tank is connected to.
Please take time to rate me
Jul 03, 2011 | Homelite Expand - It Brushcutter...
I have a homelite grass trimmer. Two short rubber hoses enter/depart from the plastic gas tank. One of the hoses is cracked, creating a fuel leak. The other is probably close to being the same. Where can I...
Rubber hoses should be available from AutoZone or NAPA or any other reputable vehicle parts dealer, or online. Check the size of the hoses before you shop, to make sure you're getting the right diameter. Replacement would probably require draining the fuel from the tank and depending on the exact layout, you might have to take out a couple of bolts to find both ends of the hoses. Make sure the hose clamps or fixtures on both ends are tight and not in need of replacement as well. Unless it's a complicated internal layout, I see no reason replacement would require a shop!
Tools you'll need: Sharp scissors or knife to cut rubber to length, rubber hoses, gloves, wrench or screwdriver?
May 19, 2011 | Garden
My Homelite Mighty Lite has developed perished fuel lines. (12 months after purchase!!!!!!) Is it possible to obtain spare fuel line.... preferably attached to a new fuel tank as well. It looks like a...
The fuel lines can be purchased separately usually by the foot from any outdoor power equipment dealer. They can be easily installed by cutting one end at an angle and "feeding" it through holes. Homelite fuel lines are of a different OD than most so make sure you get the proper size. The most popular size for Homelite is OD .203 ID .04.
Feb 12, 2011 | Homelite Mighty Lite Lawn Trimmer
Hello i have a question on changing th fuel
how to change fuel filter in gas tank remove line from carb pull line through the fill hole in gas tank remove filter replace & pull hose back up reconnect to carb & your done
Jun 27, 2010 | Homelite Mighty Lite Lawn Trimmer
Cracked fuel line
you can get many sizes of hose at the home depot
May 16, 2010 | Homelite Mighty Lite Lawn Trimmer
I need the fuel line size on Homelite gas blower. Is the fuel filter a washable/cleanable filter?
i think they are 1/8 in hoses on them and if it is a foam filter they are washable,mild soap and then a light coating of oil
Dec 24, 2009 | Homelite 'Yard Broom' Leaf Blower
How do you replace the fuel filter on a homelite st 145? the hose snapped and the filter fell into the fuel tank. Thanks
Take the old piece of fuel line and have the vendor match the size. Buy 1 ft. so that you have a little extra to work with. Cut fuel line at an angle. This will allow for easier insertion into the hole in the gas tank. Feed the line through until you can pull it out of the opening where the gas cap is. Cut the line off square. Attach the fuel filter. Pull the line back through until it rests comfortably on the bottom of the tank. Assemble the trimmer. You will then get a more accurate measurement to the carburetor.
Jim
Jun 10, 2009 | Homelite Garden
Homelite Mighty Lite Lawn Trimmer  Logo
183 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
