Question about Dell Dimension 3000 PC Desktop
I HAVE WINDOWS VISTA BUT MY ACTIVATION TIME EXPIRE AND I HAVE NO PRODUCT KEY SO I TRY TO REINSTALL BACK MY WINDOWS XP AND IT WONT COME UP I WENT TO MY BIOS TO MAKE SURE MY FIRST BOOT WAS THE CD ROM BUT STILL NOTHING SOMEBODY PLEASE HELP THANKS
  • 805 Answers
I think this not your bios or rom problem this may be for your dvd rom and also dvd/cd. So first check both of them then try it, you will success
Posted on Nov 05, 2012
5 Suggested Answers
  • 341 Answers
SOURCE: dell xps 600 windows booting problem
You would probably do right to reinstall Windows. The bios handed off to Windows long before the splash screen comes up. It is probably a faulty driver or corrupt registry entry. If it was me I would reload Windows
Posted on Dec 01, 2008
2dcapcom
  • 51 Answers
SOURCE: my dell optiplex gx200 bios can't boot
maybe try taking out the cmos battery located in your case, looks like a small watch battery, that will clear bios settings and start from scratch, if there is no battery then there is a jumper sequence to do this
Posted on Feb 17, 2009
atulbamne
  • 33 Answers
SOURCE: my dell desktop doesn't start or boot from cd rom
Basically you need to go to Bios to change your "Boot device pripority". Please follow these steps to do this.
Please follow these steps to install XP on your PC.
1. Please start your PC with power button. At the very first screen, at the left down corner, you will see the button to be pressed to go to Setup i.e. Bios of the PC. For most of the PCs , it is delete button. For some of them, it is F2 also. So, after starting the PC press Del to go into setup.
2. After you enter setup of the PC, please go to Advance bios setup.
3. There you select Boot device priority.
4. here the first boot device priority should be CD ROM, then the HDD. Please see the instructions given at right down corner and select this priority.
5. After you rightly selected boot device priority as given above, Press F10 to save the changes and then press F12 to exit.
6. Now the PC will restart again, but be sure that you put win XP cd in the drive before it restarts.
7. Now you will see a note that : press any key to boot from CD ROM, so please press any key.
8. The PC will boot from the CD ROM now , now you can follow the instructions given on the screen.
Posted on May 08, 2009
crapiemael
  • 241 Answers
SOURCE: Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
Posted on May 28, 2009
This computer use to have windowsxp it was upgrade to windows vista but do not have a product key can i install the windowxp the key no#for windows xp is in the back of the computer or how to buy a key no.
You have to enter a new Vista product id to upgrade from Windows XP to Windows Vista. The Windows XP product id will not work for Windows Vista. If you bought the Vista from an authorized retailer of Microsoft products then the serial number would be on the back of the software pack.
If you want to you can buy an activation code from Microsoft. Having an activation code means you don't need a product id and that your right to use the software is recognized by Microsoft.
I am not sure if you also have a problem with Microsoft Office because your question says "problem with Microsoft Office Professional 2007...". If you do then the same thing applies. an activation code is even stronger than a product id for both Windows and Office because a product id only gives you permission to install and use the software offline for a short time and it still needs to be activated by Microsoft before you can use it fully or longer. An activation code allows you to use the software without any limitations online or offline and also to get updates and upgrades for them from Microsoft.
If you cannot afford genuine Office software or a Microsoft Office activation code then you can download free software called Open Office which is almost as good as Microsoft Office and can even be used to open and edit Microsoft Office documents.
It is always better to have the genuine activated version.
Here are the sites you need:
www.microsoft.com
www.openoffice.org
Nov 08, 2011 | Microsoft Office Professional 2007 Full...
My operation system expire
Sounds like you need to activate your Windows operating system by entering your Windows Vista product key and activating online or by calling Microsoft's activation hotline. Once the genuine Microsoft operating system is activated, it will never expire.
Oct 08, 2011 | Microsoft Windows Vista Home Premium...
I hav windows vista operating system in my laptop. windows activation will expire with in 3 days so i need a new key for full verion
You can get a full version key from Microsoft online store or any Microsoft Authorised dealer near you. However I will advise you move up to windows 7 you will love it. It is lighter than windows Vista and more enhanced features than windows XP. Moreso, Support for windows Vista is at the end of life.
Nov 06, 2010 | Microsoft Windows Vista Home Basic for PC
My windows vista home basic producy key expire. please help for new product key for activisation. my key was MCPK9-DJVT6-QKCJR-67FX7-VQW6M
You will need to contact Microsoft directly to see why it has expired. Operating system keys do not expire unless they are illegal. They will assist you further as to why the key was blacklisted.
Sep 16, 2010 | Microsoft Windows Vista Home Basic Edition
I have windows vista home basic and my product id is 89572-OEM-7300981-88914 i m not having the windows activation key and need it in 2 days otherwise windows may stop working
you can do it by phone . Call microsoft and they will give you the activation key.
check this :
You can determine how to contact the appropriate regional Microsoft Product Activation Center by selecting the Activate by Telephone option in the Product Activation Wizard when you install a Microsoft product that requires activation. When you select your country or your region, the appropriate telephone number will be displayed. uparrow.gifBack to the top How to access the Product Activation Wizard loadTOCNode(2, 'moreinformation'); If the Product Activation Wizard is not open, follow these steps to start the wizard: Windows Vista loadTOCNode(3, 'moreinformation');
  1. Click Start Collapse this imageExpand this imagevistastartbutton.jpg.
  2. Right-click Computer.
  3. Select Properties.
  4. Click Activate Windows.
Windows XP loadTOCNode(3, 'moreinformation');
  1. Click Start.
  2. Point to All Programs.
  3. Point to Accessories.
  4. Point to System Tools.
  5. Click Activate Windows.
Sep 24, 2009 | Microsoft Windows Vista Home Basic Edition
Windows Xp activation
Just call and activate by phone with the phone number provided.But if you just want to run pirated software,Your on the wrong site.
May 31, 2009 | Microsoft Windows XP Home Edition
Windows Vista Bootup problems
Did you (sorry for the underline....not sure how it got here) call Microsoft to have them give you another product key? This is the new procedure now. If you do a reinstall with your Windows Operating System, you have to call in to receive a new product key. This should fix it.
Nov 18, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Dell Dimension 3000 PC Desktop Logo
Alun Cox
