Question about Vacuums
Show me the motor of hoover cleaner u5750-911
  • eman bajes Nov 07, 2012
    I need to reach the hoover U5750-911 motor as I smelled some smoke coming out of the vacuum.
Where is the thermal protector sensor on hoover vac.
On most vacuum cleaner models it is built into the motor and cannot be changed without replacing the motor. In my experience the reset switch goes bad more often than the motor does which is why I recommend vacuum cleaners that have an external reset switch.
Jan 05, 2017 | Hoover Vacuums
How to open Hoover S3825
Hi there! We recommend taking your cleaner in to a Hoover authorized service center to have the motor replaced or repaired. I have included a link to the service center locator if needed. Hope this helps!
Service Center Locator
Oct 05, 2014 | Hoover Elite Cyclonic Canister Vacuum with...
How to relpace motor on hoover vacuum cleaner?
Hi! We recommend taking your vacuum to a Hoover authorized service center to have the motor repaired or replaced. I have included a link where you may find the closest service center to you. Thanks! Service Center Locator
Jul 18, 2014 | Hoover Vacuums
How do I change the belt for the Hoover Elite
Follow this link to a website that will show how to change belt (it aslo has illustrations). Click first link listed on page.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps.
Jan 26, 2010 | Hoover Elite Rewind Bagless Upright...
How to replace belt on Hoover U6626-900 Wind Tunnel bagless.
Click this to go to a site that will show you (complete with illustrations) how to change belt.
I hope this helps.
Jan 19, 2010 | Hoover U6630-900 WindTunnel Bagless...
Bearing screeching?
Yes, it could be a motor bearing. Another possibility is the fan could be broken. Remove the bottom plate from vacuum. Spin the belt motor pulley slowly and view the fan. You may have a plastic fan that has broken or something is keeping the fan from spinning. Here are links with illustrations to an online guide. (the links will say "belts" but it will show how to get to the fan). Click the one that best matches your vacuum.
Hope this helps.
Aug 21, 2009 | Kirby G6 Bagged Upright Vacuum
My Hoover carpet cleaner is approx. 7 yrs. old....husband believes motor is shot? Smells burnt when running....fix or buy new???
you are correct, the motor is shot. if you like the machine replace the motor. i would get an est. on the machine from your local vac shop and the go price them. in some cases its better just to get another machine.
Jul 28, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
New main belt alignment for Hoover Windtunnel Mach 6.1. Belt moves 1/4 inch towards of vacuum cleaner and will not stay aligned on the V convex guide pulley
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=853508
Generic problem for all Vacuums
Posted by donlee300 on July 29, 2008
Belt moves 1/4 inch towards of vacuum cleaner and will not stay aligned on the V convex guide pulley.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It is possible that you may have a broken or cracked motor mount and the motor has shifted and that could be the reason that the belt is not running straight and aligned properly – if you have the vacuum less than one year – something like this would be covered under the Hoover factory warranty and to contact an authorized Hoover vacuum cleaner dealer in your area or to call the Hoover factory cust serv @ the phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 29, 2008 | Vacuums
Hoover Elite Rewind Vacuum, smells like a burning motor and is not sucking anymore! Help!!
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=749037
Posted by suzipea on Jul 06, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. If the motor has a burning smell, it could be the belt but in most cases it would be the motor and that would be in need of replacement. You can try to replace it yourself but there would not a warranty for self installation. If you have an authorized vacuum cleaner dealer do the install then it would be warranted for one year. You can check with the Hoover manufacturer if you like. If you have further questions please feel free to contact your local vacuum cleaner dealer in your area, or contact the Hoover website and or the cust serv phone # @ Hoover listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 06, 2008 | Vacuums
HOOVER 6430-900
Hoover Fined for Failing to Report Vacuum Cleaner Fire Hazard
(function(){ var e9 =new expo9_ad(); e9.size ="160x600,120x600"; e9.showAd(); })(); _qoptions = { tags:"ADSDAQ.LAWPOLITICS,501500," }; _qacct="p-01-0VIaSjnOLg";setTimeout("quantserve()",3000);
January 16, 2007
Hoover
hoover.jpgHoover Fined for Failing to Report Vacuum Cleaner Fire Hazard
Whirlpool Spins Off Hoover
Hoover Recalls Self-Propelled Vacuum Cleaners
Consumer Complaints
Hoover Company Inc. has agreed to pay a $750,000 civil penalty to settle allegations that it failed to report to the U.S. Consumer Product Safety Commission (CPSC) the sale of vacuum cleaners with defective on-off switches that can overheat and cause the vacuum cleaner to catch fire.
In April 2005, Hoover conducted a recall of 636,000 Hoover Self-Propelled Upright Vacuum Cleaners because of defective on-off switches.
In June 2004, after CPSC received notice of several vacuum cleaner incidents, the Commission staff requested Hoover provide a full report of incident information. In July 2004, when Hoover submitted a full report, it had notice of 260 consumer incidents, of which 141 involved reports of fire. Additionally, there was one report of a minor burn injury.
Hoover first learned of a vacuum cleaner switch on one of these units overheating and melting in April 1999.
Federal law requires firms to report to CPSC immediately (within 24 hours) after obtaining information reasonably supporting the conclusion that a product contains a defect which could create a substantial risk of injury to the public, presents an unreasonable risk of serious injury or death, or violates a federal safety standard.
These Hoover Self-Propelled Upright Vacuum Cleaners are plastic, upright vacuums with the brand name �Hoover� and words "Self Propelled" printed on the front of the product.
Only those Hoover Self-Propelled Upright Vacuum Cleaners manufactured between May 1998 and November 1999 are included in the recall that is the subject of this penalty.
Jun 11, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
24 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
