Hp compaq 6737s not powering up
I have a hp Compaq 6737s its not display and coming up...when i plug the charger it shows the power light after some few seconds it turns off and does the same thing again constantly i dont know what to do i use an amd semprom processor....
    Novelist:
    Champion:
  • 233 Answers
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Posted on Nov 06, 2012
stif_NEC
  • 441 Answers
SOURCE: hp compaq nx7400 - battery died and power cord will not turn comp
If your system won't boot up with just the AC adapter connected, it means to say that there's a problem with the AC adapter or the motherboard of the computer. Basically, if the AC adapter or the motherboard is damaged, you won't get a charged battery. If there's another AC adapter that you can try your computer with then that will be great. If antoher AC adapter works, then you just have the AC adapter replaced. If a known AC adapter didn't work then you may need to consider replacing the motherboard of the computer.
Posted on May 07, 2009
  • 50 Answers
SOURCE: Compaq Presario F700 wont boot. Powers up then turns off again a
that means you might have a hardware failure. possible powersupply. check with local shop.
Posted on Jun 18, 2009
  • 59 Answers
SOURCE: Problem HP Compaq nx 7300 Yelllow light 8x
Have you had previous problems with your laptop power supply and battery? I have this same laptop and use it very regularly. I do have problems with battery life, but never actually powering on. I suspect the battery is not accepting a charge. My suggestion is to replace the battery and see how things go.
Posted on Oct 20, 2009
Testimonial: "I repclaced the charger...no is ok again...thx for the help :-)"
  • 26 Answers
SOURCE: i get a blinking power light on my compaq c500 if
have someone check your power supply or you have a bad motherboard
Posted on Oct 31, 2009
  • 37 Answers
SOURCE: hp compaq nx6310 wont turn on. When pressing power
it will either be the batery is no good, or adapter ot the port on your laptop
Posted on Feb 27, 2010
How can i fix my laptop doesnt charge
Try another power adapter/charger. These frequently go bad.
Jul 23, 2014 | HP Compaq 6730b Notebook
No power on 6715b notebook
check with alternate charger.
Feb 18, 2014 | HP Compaq 6715b Notebook
I am opening my pc and after 2 second it went off i have a blinking light like a orange flash light
I imagine the orange flashing light is over the battery? The compaq laptops have a little blue light that will typically light up when it's plugged into the wall. If it is plugged in ensure that the little blue light is on. If it isnt you may have a n issue with your power supply unit, or there may be an issue with the port where the plug is plugged in. Thus causing the battery to be dead and the computer not power on. If you have any other compaq computers you can also try plugging in that power adapter, or try picking up a universal or another hp/compaq charger from somewhere such as best buy to test it out.
Mar 07, 2011 | HP Compaq Presario C500t Notebook
I have a HP/Compaq 6510b laptop computer and it will not turn on...I have the charger plugged in and the only thing happening is the green light periodically flashes...Is the battery bad?
IF the battery is bad the charge lndicator on the laptop will flash (But not periodically) it will be a constant on-off-on-off..... Best check would be to remove the battery completely and use the adapter/charger power supply only. If it still does not turn on then you either have a bad power jack connection or a more serious motherboard problem. Also is the green light flashing on the adapter/charger or is it the charge/battery indicator on the laptop?
Feb 17, 2011 | HP Original HP COMPAQ 6510b 6515b 6710b AC...
My compaq v6000 will not power on. Power on light comes on for 3 seconds and then cuts off. Got another battery and still will not turn on. What can I do?
unplug the battery and charger hold your power button pressed for 1min then plug it back in and try to boot ,if no joy and stil under warrenty contact reseller ;)
Mar 11, 2010 | HP Compaq Presario V6000T 15.4" Notebook...
My Compaq Presario V3000 laptop will not power up.
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Dec 04, 2009 | HP Compaq Presario V3000T Notebook
Can someone please help me! when i try to power up my compaq 6702s it does not come on the power light comes on and you can here the fan for a few secconds and then it goes off,does not come on at all, the...
HELLO. IT SOUND'S LIKE YOU HAVE A BAD POWER RIBBON. . IT'S THE RIBBION THAT CONECKET'S FROM THE POWER BUTTON TO THE MOTHER BOARD. !!! IT A COMMEN PROBLUM. IN SOME LAP TOP'S . WELL HOPE THIS HELPS YOU . GOOD LUCK
Jun 06, 2009 | HP Compaq 6720s Notebook
Power Issues
Check you batter if it is not working it may be somthing wrong with the computer that a computer company needs to look at to get it fixed.
May 20, 2009 | HP 435768-001 - Compaq Presario C300...
My HP Compaq nx9030 wont turn on
try to remove your memory/ies. then plug it to ac power without battery, if it turns on try to unplug and put back the memory module (one by one if more than 1). plug and switch on if it works then put everything back if not, you ned to replacethe memory.
Hope this helps.
Please vote if it does.Thanks!
Apr 18, 2008 | HP Compaq nx9030 Notebook
Computers & Internet Logo
David Payne
David Payne
