Plic abut crt tv color blinking
5tyems blinking no disply dc voltag it is ok how can fix
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Can you please give brand and model and a description of what set is doing or not doing?
Posted on Nov 05, 2012
3 Suggested Answers
SOURCE: my tv sound ok, crt high voltage ok,channel number display ok
check for a resistor rated around 220kohms somewhere around the flyback area. i have never worked on this model tv before so i cant give you an exact part number on the board but had the same problem with sharp tvs
Posted on Nov 21, 2008
yammy_alf
  • 666 Answers
SOURCE: screen grid voltage on crt
voltage range from that pin is 300 to 350 v. dc.
Posted on Apr 03, 2010
Samsung crt tv blinking
Have you tried to unplug the set from power for a while and then replug to see if it reboots?
Nov 05, 2012 | Televison & Video
My Sony KDF-50WE655 does not turn on. Only the standby LED Flashes several times and then goes steady green, but the lamp light remains off.
Hello
You just count the number of blinks of the standby light before it goes out to green. In sony sets this blinking count ic critical for us to locate the faulty stage. You just count it after switch it Off by Power switch and Switch it On by the power switch at the front of the TV, for at least three or four times, and make sure abut the number of blinks, and report it to me. Ok
Nov 14, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Power button doesn't do anything, remote doesn't work, 4 blinking lights. Sony kv 36fs120.
you have power issue. short the prongs for a minute. then remove the short wire. then test. if not succesful go to your nearest service center.
Apr 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen grid voltage on crt
Sep 25, 2009 | Sony KV-29FX66 29" TV
Lost green color, lights blinks
Ur high voltage is dead,FBT,flyback transformer is dead,the big black block of plastice with a red wire with a cap hook to a CRT(tv tube).Resoder for lost green color,by the crt yoke RED GREEN YELLOW connection to the main PCB board.Might also have to resolder crt board connection pins socket.
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Bad Color after replacing Color Wheel, removing jumper wire did not fix it
after removing jumer, all is perfect.
jumper is inside an opening abut 3/4 inch under label, remove what looks lie rubber.
Oct 03, 2008 | Samsung HL-P6163W 61" TV
Won't turn on or off - red light blinking
This sounds like a power supply problem, visually check the fuses and if they look ok, and you have a backgroud in electronics test to see if the set is prducing Dc voltage, you will need a multimeter and a schematic to do this with. However, if you do not have a background in electronics please take the set to a qualifide TV repair shop to have the repairs done.
I hope this helps.
Thank you,
Shuttle83
Nov 14, 2007 | Toshiba 36A43 36" TV
Blurry Images
Hello paulaspec,
You have a problem with the three factors, and they are screen voltage, focus voltage, and control (focus 2) voltage. Basically these voltages have to be adjusted since the components in this section have aged some. These controls are usually located in the television on the IHVT (Integrated High Voltage Transformer) or as it is also called the flyback transformer. these controls must be adjusted together, along with the color controls. Here is how the adjustment is done (You will need a schematic diagram, a DC volt meter, and a color bar generator to do these measurments):
1) turn color and tint fully counter clockwise until you have a black and white picture.
2) connect the color bar generator to the TV (ch 3) and turn it on, you should see bars in various shades of gray
3) adjust as best as possible the color and tint controls to obtain the color bars on the screen Red Green Blue.
4) measure the voltages on the focus, screen and control grids of the CRT and match them to the schematic digram measurements.
5) adjust the focus screen and control grids to match the ones on the schematic diagram
6) once this is done then you adjust the color controls once again to obtain the red green and blue bars on the TV screen.
This should help if the CRT (picture tube) electron guns are still good and if the flyback transformer voltage supply is working.
However if you do not have a background in electronics please take the TV to a shop for repairs.
I hope this helps,
Thank you,
Shuttle83
Oct 16, 2007 | Sony KV-20M20 20" TV
Color flickers off and on
Most of the time TV problems arise by power supply noise. This noise in the supply is usually caused by Electrolytic Capacitor failure. If you are technical, you can get the schematic and look for the voltage regulator circuits. Measure the voltages with a DVM using both the DC and AC settings. If the DC setting is lower than normal, you will probably see about .5 to 1v of AC voltage on the line. Look for the large capacitor in the regulator circuit and replace them. Cost about  $.50 each. Get new caps with slightly higher voltage rating (if they will physically fit).
Good Luck
Oct 16, 2007 | Mitsubishi VS-45609 TV
Help....all the characters on tv are green
Hi. When TV has one color only, Unplug CRT Socket. if voltages for cathodes within 10% of each other, Problem is with CRT. check green video amp on crt socket, it may be shorted or leaky, if ok have crt checked for short involving the green cathode.
Mar 20, 2006 | Daewoo DTQ-25S3FC 25" TV
Televison & Video Logo
Top Televison & Video Experts
