LC-22DV510K (B) sound but no picture
Hi We bought this a few months ago and it it was very good, but suddenly we have no picture only sound. I have turned it off at the mains, unplugged, tried everything. This morning the picture came back for about 10 minutes, then disappeared again. I saw somewhere that it could be the 'inverter'? Guess this means a call-out since I'm not techie. Thanks for any help.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
LCD sets (most) use back lights for the light source--the inverter mentioned likely is for them----in a very dark room with set on and or with a flashlight look to see if you can see a FAINT image on the screen, if so backlights are either bad or no power reaching them.
Posted on Nov 05, 2012
  • 208 Answers
SOURCE: Sharp Aquos LC 37D6U
Please be aware that this a big problem on this unit. The insulator material used by sharp to between the IC's on the AV board both on top of the boards and underneath the the AV pcb is failing. This insulator is mounted to the IC and under the metal heat sinc. Remove the back and pull the AV Board out of the unit. Use zylene or alcohol and clean all of the grey insulator from between the pins on the ic and order the replacement insulators from Sharp. Most times this will correct the no sound problem. Sometimes this has also damaged the AV pcb and it will have to be replaced. The parts that should be replaced come in a kit with sharp part # PSPKIT663WHZZ. If the kit is not available the 2 parts needed are PSPAZA663WJKZ AND PRDARA216WJFW.
Posted on Feb 05, 2008
SOURCE: TV SCREEN GOES BLANK
Yes your inverter is bad, I have the same problem my set is about 1 and 1/4 years old. Because Olevia makes a terrible product there inverters are attached directly on to the panel, which means they will only sell the inverter along with the panel i.e $700+ to replace + $100 dollars labor if u don't know how to fix it ur self. I am currently searching to find the manufacture that makes the inverters because olevia will not disclose that information. I believe it is darfon, if so the inverter should cost about $150-200 depending. If you dont believe you can fix it ur self ur best bet is try and sell the set for scrap take ur $100 or so dollar and buy a quality product! Oh and dont call there support they will tell 10 different things before u find out this long for seen truth!
Posted on Jun 20, 2008
SOURCE: Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Posted on Nov 10, 2008
  • 8457 Answers
SOURCE: Sylvania LC320SS8 32 in. LCD Television - Will not turn on
U have power on 10 mins,than is not the power supply board.Ur Tuner board is dead replaced that board.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish tuner signal board.
Posted on Feb 09, 2010
  • 8457 Answers
SOURCE: turn on picture and sound are great. for about 60
The tv have a long board call a LCD inverter board.This long LCD inverter board is dead.That why,the tv have picture only flashes like a min. than,died and have sound left only.The LCD long inverter board help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Posted on Oct 16, 2010
Testimonial: "I will order this part and install it. Thank you mark"
Sharp lc-52d62u with sound and no picture. OPC and power lights blinking.
Sounds like lamp problem. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 01, 2015 | Sharp AQUOS LC-52D62U 52in Widescreen LCD...
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
How can I get my picture and sound back on PS2?
According to the symptom the lens need replacement with new one, Change the lens and it will work fine again.
Thanks for using fixya.
Jul 01, 2009 | Sony PlayStation 2 (PS2) Console
Sharp LC-32DA5U
sounds like youve had a pic tube go out,,probly just one and the other 2 are still good,,thats why it came bck on,,take it to a tv shop ,know ,,want be that much if its just one pic tube,,good luck
Oct 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
A White Screen!
I had the same problem a few months ago. Best bet is take it to get it fixed. If you still have a warrantey it won't cost you a thing. Good luck!
Feb 29, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
No Sound but see the picture
Have you check your jacks did you put them back in the correct audio/vidio outlet...Johnnie W.
Dec 31, 2007 | Sony RDR-GX300 DVD Recorder
Sharp Aquos 46 In TV Problems:
Sharp list no issues or service tips for this model but I am sure most freeze ups are and issue of weak cable signals or defective cable receivers. If this has truly been elimnated the main digital pcb in the TV could be issue or more likely the TV may need the latest software upgrade. This is most likely only able to be facilitated by a Sharp auth. service center.
Dec 11, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Blinking green light, no picture or sound
Hi, bought television only 2 months ago now blinking opc light and power lights with no picture or sound. Whats up with that?
Sep 13, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Sound on LC-20SH4U LCD TV takes 15 minutes to come on
Probably heat sink compound on the audio IC. Fixed them before. I would imagine under $100 depending where you live.
Good luck
Aug 01, 2007 | Goodmans W280NS Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
