I have a byD:sign DVX 500 dvd player, can I convert vhs tapes to dvd discs by using this dvd device?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Not unless it is also a DVD recorder since player means it will play only.
Posted on Nov 05, 2012
Testimonial: "Thank you, you were very helpfull."
  • 4102 Answers
SOURCE: dvd player will not read disk
have you tried getting a lense cleaner as they sometimes get alot of dust and will stop signal from disk to the laser if this dont solve the prolbem then you are looking at replacing the laser unit itself if the cleaning dont work and you think you are capable of taking the casing off make sure you switch it off first this should send the laser to the center of the laser tray if you take the case off and it is not in the center it might just be that it has got jammed now sometimes gently pushing it back to the middle will get it working again if it is already in the middle then it could be that the laser needs replacing but if not in middle push gently dont gerk it it should be quite stiff to push any way when you push back to middle try a disk with the casing off but please make sure you dont touch anything whislt it is plugged in if nothing works then it probably is the laser but before you do anything as soon as you get the case off switch it on and put a dvd in and make sure the disk is spinning if not laser unit is nakered and need replacing let me know how you get on hope this is some help to you
Posted on Nov 26, 2007
ctf1800
  • 4402 Answers
SOURCE: Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Posted on Dec 04, 2007
SOURCE: VHS to DVD playback
The document for the XBR716 needs to be re-written and re-issued, because it is missing information on how to finalize the DVD.
Solution:
Press the HOME button, then go to Disc Manager.
Select the Finalize menu, Finalize and OK to start.
Posted on Jan 04, 2008
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Posted on Apr 05, 2008
  • 9 Answers
SOURCE: How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Posted on Jan 03, 2009
How to convert VCR to DVD
no easy way to do this unfortunately. You either need to connect your VCR to a DVD recorder and record it directly onto DVD or use a device such as this http://www.dx.com/p/easycap-usb-video-capture-adapter-5707 to connect your VCR to your computer and record it onto your computer that way.
Feb 23, 2015 | Zenith XBR616
How do I record a vhs onto a dvd on the combo?
I have researched the manual for this particular device and you will not be able to convert/record VHS tapes to DVD discs. You can however record content from a DVD to VHS tape as this model only has a readable disc player not a DVD burner. Sorry, but you may want to research DVD recorders that also have VHS playback.
May 02, 2011 | Insignia IS-DVD040924 DVD Player/VCR
My dad just purchased a 2004 memorex t.v. with built in dvd and vhs players. He wants to know if he could record a vhs to a dvd on t.v.
No,the DVD player build in tv can't record,only play DVD Disc only.Want to record personal VHS tapes only to DVD Discs,must have a seperate device unit VCR/DVD RECORDER device player not a device unit VCR/DVD PLAYER.Connected to the tv record VHS tapes to DVD Discs.
Mar 14, 2011 | Memorex Televison & Video
I want to trasfer my vhs tapes to a disc is this possible
You will need a VHS tape player, and a DVD recorder in order to transfer the content of your VHS tape to DVD. You can also use your computer to convert VHS to DVD. Here is an excellent site with in-depth information on converting VHS to DVD: http://www.vhstodvd.com/
Mar 09, 2011 | JVC Video Cameras
I cannot copy commercially recorded VHS tapes to DVD. Msg comes up saying it is COPY PROTECTED. Heard that if for personal use only I am permitted to copy tapes. Any way around this?
No,this can be done only copyright materials through the VHS box converter run through a computer with a programs call copy decoders programs.Than u can copy VHS copy protected matrials.Than u reburn it back to DVD disc.So this require alot of work,time and money so not worth it to copy commercially VHS tapes to DVD Disc.
Jan 19, 2011 | Samsung DVD-VR320 DVD Recorder/VCR
Daewoo VHS to DVD converter - disk only plays on the converter
The Disc needs to be finalised. Using the setup menu and disc info you select "finalize disc". I had the same problem.
Jan 12, 2009 | Daewoo DV-T8DN VHS VCR
Failure in tape to disc transfer
what kind of software are you using. I have had problems with this type of transfer and I had to use a special transfer device. If you want to know about the device write back and I will tell you how I did it.
Jan 07, 2009 | Lite On LVC9006 DVD Player/VCR
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Jan 20, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
DVD-VR357: Copy multiple vhs tapes to one DVD?
Try using DVD/RW disks with pausing the recording when you change VHS tapes.
Dec 22, 2007 | Samsung DVD-VR357
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
Electro Med Services...
