Question about HP LE1901w Monitor
The screen is green instead blue - HP LE1901w Monitor
I have a PHILLIPS DV3 47 inch smart TV. But I cannot hook up to my dvd recorder
The blue/red/green aren't a component signal which is why they don't match and are causing the no signal message. The dvd recorder is most likely only giving out RGB which you need to plug into those RCA sockets or SCART/Peritel connector if you have that.
Sep 30, 2014 | Televison & Video
Toshiba 150r6f color blue is missing
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
The transistor that your friend told you, can be located at the CRT base card [Video Output] itself.
Mar 01, 2014 | Televison & Video
I have an LG Rear projection TV Model No. MW-60SZ12, it has patches of blue tinge through the bottom of the screen, i have replaced the globe and the picture has improved but i still have these blue...
your optic engine is stuffed! the blue ,green & red optics are glued into place instead of screwed.after time this glue fails and the colours fade onto the screen. very common problem with this model.
Jul 20, 2010 | LG Televison & Video
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
Projector lamp shows blue on white screen
the red is cutting out. white=blue+green+red. without red, you get blu+green, or cyan. if this was an lcd projector, i'd say it's a burnt light filter, the red lcd, or the lcd has come unplugged. but since this is a dlp projector, you have either a dmd board issue or a main board issue. either way, it'll be pricey.
Feb 18, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Laptop screen has been invaded by green and red/purple germlins
haveyou tried shutting it down and restarting it? it may just be the screen going bad
Jan 26, 2009 | JVC AV-48WP30 48" Rear Projection...
Green Screen instead of Blue
Check the picture settings on the tv, if that is not the problem, then check all of your connections (RGB cables+RW Audio) that is HD component, if you have both HDMI and HD component then try one of them, or it may be a switch in the back of the DVD player or TV
Jan 11, 2009 | Miller TELEVIDEO 995 TERMINAL W/ GREEN...
One day it worked the next it didn't
These TV's are prone to power supply failure. I can fix the power supply on this TV for approx $100 +s/h.... Contact me and all you have to do is remove the power supply and send it to me and I will repair it with high quality parts. Reinstall and you TV will be good as new...
Jan 25, 2008 | Akai LCT2715 27 in. LCD Television
Tv Screen Problems
as you see green screen with lines through it
lines you are seeing is called retrace lines.
the problem is due to green video output section failure
please check the followings as given
  • supply to green video output & video output itself
  • components in green video output circuit
  • crt base loose.
  • connector loose in video ckt.
  • signal from signal processor to  green video section is absent.
hope this will help.
good luck.
Oct 15, 2007 | Televison & Video
Swapped colors in the monitor...
Sounds like you have swapped pins 2 & 3 in your VGA plug.
Sep 01, 2006 | SAMTRON 55V 15" CRT Monitor
HP LE1901w Monitor Logo
22 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
