Won't show up a letter for the drive on my computer for this drive. Why?
I forgot to disconnect the drive from my computer when I upgraded to the latest Windows software.
    Top Expert:
  • 9,472 Answers
What OS are you running?
Posted on Nov 06, 2012
4 Suggested Answers
  • 175 Answers
SOURCE: My Avastor HDX Portable HD
Hi!
i dont know if your drive is dead , but try to connected to an Other Pc with different System (windows Xp Or 7 ) and see if it work try to formate it , but if he didn't work that's mean is dead ,
good Luck
Posted on May 23, 2011
consaka
  • 661 Answers
SOURCE: Windows Vista does not show drive letter.
If this is a NEW drive you will have to set it up first to be used.
Under control panel you will find an icon called "Administrative tools" Under that you will find another option called "computer management", Here you will find another option called, "Disk Management"
This is where you should be able to see the drive. You will need to partition it and format it.. Once you do that it will automatically be assigned a drive letter.
Just right click on it for the partition and format options. Keep the default size options unless you really want them to be different.
Posted on Mar 12, 2010
  • 69 Answers
SOURCE: The drive letter for my external USB hard drive
Its seems that the PC is not detecting the drive, Try connecting the drive to any other PC. That will help you find out if the drive is bad, You can try changing the connectin cable too.
regards
Sandeep
Posted on Oct 25, 2009
External hard drive won't show up on my computer
Enable Drive Letter View b> Click the "Start" button and choose "Control Panel" from the start menu. Click "Folder Options" and navigate to the "View" tab. Scroll down and place a mark next to "Show drive letters," then click "OK." b> Configuring Drive Manager b> Click the "Start" button to launch the start menu. Right-click "Computer" and choose "Manage" from the menu. Click "Storage" in the menu on the right side to extend the section. Click "Disk Management" under the "Storage" header. This will show you a list of drives and removable storage on your computer. It will also report the status of the drives, such as "Healthy." If the removable storage does not have a drive letter or has a drive letter in conflict with another drive, you can assign it a new letter. Right-click the icon of your removable storage drive and click "Change Drive Letter and Paths." Click the "Change" button, then choose a drive letter from the drop-down menu. Select a letter that is near to the end of the alphabet to prevent drive overlap issues. Click "OK" to allow the changes to take place. You should now see the removable storage listed with your other drives on the "My Computer" screen.
Dec 29, 2012 | Imation Apollo Expert D200 1. 0 Tb...
Dane elec portable hard drive not recognised by win 7 pc
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use.
If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted.
If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off."
Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive.
Connect the cord directly into an outlet and power up the drive.
If the drive is powered and still not working, check the data cable.
Power down the hard drive and disconnect the data cable from the computer.
Wait 30 seconds to one minute.
Reconnect the data cable and power up the drive.
If the drive is not detected, power down the hard drive and connect the cable to a different port.
Power up the drive.
If the drive is detected but not working, check for a missing driver.
Click on the "Start" button, right-click "Computer" and select "Manage."
Enter your administrator password if requested.
Select "Device Manager" and double-click "Disk Drives."
Right-click the yellow exclamation point and install the missing driver. Close the Device Manager.
If the drive is detected but not working check to ensure it has an assigned drive letter.
Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer.
Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested.
Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add."
Assign a drive letter.
Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window.
If the drive is detected but not working, check whether the drive is in sleep mode.
Click the "Start" button, right-click "Computer" and select "Manage."
Select "Device Manager" and double-click "Universal Serial Bus Controllers."
Double-click the first instance of "USB Root Hub" or "Root Hub."
Check for the hard drive.
If the drive is not visible, move to the next instance of "USB Root Hub."
Continue checking each instance until the hard drive is located.
Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager.
Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected.
Hope this helps
Nov 01, 2012 | Dane Elec DANE-ELEC SoMobile 500GB USB 2.0...
How can i get my Nikon Coolpix L14 to show up as a drive letter?
The camera is not a full card reader. You can use it to copy pictures, but it won't let you recover files. You need to use a separate card reader, either built-in to your computer or attached to a USB port.
May 14, 2012 | Nikon Coolpix L14 Digital Camera
Cd/dvd drive does not show up in my computer. immediately opens when i close it. does not read discs
Go to my computer icon, right click manage, go to near the bottom look for disk manager, if u dont see ur CD drive then try connecting and disconnecting it. u can also try go to start> run. click run then in the text box type cmd then press ok. in command promp, type 'x:\' x is ur drive letter, so if ur drive letter is d type 'd:\', if nothing shows then there might be a problem but its unlikely that its a hardware issue.
thanks and Regards
Trinoj
Aug 05, 2011 | HP Pavilion a6603w PC Desktop
My HP DV9740US laptop will only recognize one external hard drive at a time. When i plug in another external hard drive it'll make the sound that it's recognized but won't show up in My...
you may have to assign a letter to the unseen drive manually: goto start menu and right click on my computer/ select manage/ select storage/ select disk management/ right click on the drive in question and select change drive letter and paths/ then give it an unassigned letter and that should do it. hope this helps:)
Jul 28, 2011 | HP Pavilion DV9740US Laptop
Hard drive needs to show as f instead of g on computer when plugged into usb
Connect your harddrive to computer then when you power up the computer press F8 key then enter in safe mode.
Then it fix messup .
If still not show as G then right click on my computer icon then click on manage.
Then click on storage->removable storage or disk management there you can see your drive icon right click on it then change drive letter.
Nov 17, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I can't access my drive, even though all my tests say it's fine.
Right click on my computer and click manage then click on disk management. Find your drive and give it a drive letter. It probably just needs a drive letter so you can recognize it in my computer,,,Good Luck and let me know if this works...Darren
Oct 11, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
DSC-F505 does not show as a disk drive
dmangadu
It sounds like the drive letter that the camera wants is already assigned to another device. The link below will help you change the drive letter.
http://www.fixya.com/support/r4183994-change_drive_letter_in_windows_xp
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Feb 15, 2008 | Sony Cyber-Shot DSC-F505 Digital Camera
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
David Payne
David Payne
