Question about Hotpoint RB757 Electric Kitchen Range
Shorted out oven light while replaceing bulb.
Failed to unplug range when working on broken oven bulb. Sparked,shorted out. Replaced bulb and will not work now,
  • 135 Answers
Try resetting the house breaker.
Posted on Jan 05, 2009
I shorted out the counter lights on my frigidair microwave. The microwave works but not the lights. I've replaced the bulbs. What next?
The metal base may have fused together from electrical arcing when the old bulb was removed. The entire bulb receptacle (socket) will have to replaced. If you cannot do that yourself, the cost would be excessive. Just live without the light as long as the microwave gets the job done.
Dec 10, 2014 | Frigidaire FMV157GB Over-the-Range 1.5 Cu....
Evalschmeer@gmail.com
Hi, If you have fuses on the stove have them checked and/or replaced with new ones.
You may have shorted out something when you made it wet.
Also check main power breaker if tripped. 115/230 volt breaker.
Hope that helps.
Mar 17, 2014 | Kitchen Ranges
Clock on control panel works, control panel counts down when start is pushed, light inside doesn't work nor fan or light under unit. I replaced fuse but wasn't the problem. Any ideas? I first noticed...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Dec 02, 2010 | Whirlpool MH1150XM Convection/Microwave...
I tried to change the light bulb in the oven, thought I had the power turned off, I did not. The bulb socket sparked, nothing seemed to happen but now my controls on top of my kitchen aid KESC300 electric...
Hello- Glass bulbs don't make very good handles, do they? Find a good tech to check wiring behind bulb socket. May have burned a connection, and or grounded a wire somewhere. Electric ranges have two 110v circuits that work in combination. One is out. Let me know if info helps- have more if needed- Thanks- ED
Mar 04, 2010 | KitchenAid KESC300 Electric Kitchen Range
Light will not shut off
The only thing thing it can be is the light switch, as this is what gives the power to the light bulb.
It sounds like the switch contacts have shorted, thus giving a constant feed to the bulb, If it were me,I would fit a new switch, but to be sure, pull the leads of the switch, and the light should not work.
MAKE SURE POWER IS OFF FIRST!!!!!.
Feb 08, 2010 | Amana AOCS3040SS Electric Single Oven
Whirlpool microwave model #MH1140XMQ-1. I needed to change the light bulb on the bottom of the microwave that shines on the stove below. I started to turn the light bulb and the bulb seperated from the...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
Or if you prefer, you can order a new control circuit board for it here for $140.10 plus shipping. (Just enter the model number as MH1140XMQ-1 without the dash).
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 04, 2009 | Whirlpool MH7140XF Microwave Oven
Ge microwave jvm1320 light & fan no longer operate
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
Oct 20, 2008 | GE JVM1320 Microwave Oven
Short circuited Whirlpool MH1150XM while changing the bulb underneath. Need help to fix it, thanks :)
We replaced the board behind the control panel. $130.00. If you do this make sure you can put the wires back the right way. My husband finally got it and our micro is working like brand newThanks to all who tried to help.
Sep 29, 2008 | Whirlpool MH1150XM Convection/Microwave...
Cook Top Light
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 18, 2007 | Whirlpool MH1150XMQ Microwave Oven
Kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
Oct 13, 2007 | Kenmore 62622 Microwave Oven
Hotpoint RB757 Electric Kitchen Range Logo
192 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
