Question about SanDisk 1GB microSD Memory Card
Memory card 1GB volume label - SanDisk 1GB microSD Memory Card
  • kakima Nov 05, 2012
    What about the volume label?
  • SanDisk Master
  • 2,878 Answers
My Computer. Right click Format > Volume Label.
My Computer. Right click Properties > Volume Label.
Start > Run / Search. Type cmd ENTER. Type label x: [name] x being the drive letter.
Posted on Nov 06, 2012
    New Friend:
1 gb micro sd card formate system
Posted on Mar 25, 2014
HOW I SET VOLUME LABEL TO FORMAT MEMORY CARD
Dnt worry, what you need to do is to right click- run .exe file as a administrator. It will ask you for new volume set it and quickly format afterwards remove memory card , again plugin and check again for the changes you have done.
Sep 11, 2014 | SanDisk Electronics - Others
Volume label
Right click the drive in My Computer, select Properties and use the "General" tab to change the volume name. Click <OK> and you should be all set.
Jan 23, 2014 | Kingston 4GB Secure Digital High Capacity...
Volume label
If you have not Formatted the device first, you cannot use it until you do so. You did not give sufficient information as to what device you are trying to apply a Volume label to...so we cannot help you fully with your problem.
Dec 24, 2013 | Electronics - Others
Volume label
I'm not format my memory card sd
Nov 02, 2013 | SanDisk 2GB microSD Memory Card
Every Time I Insert My Sd Card It Comes Up Error Volume Label Syntax And I Cant Get My Pictures On To My Computer Wat Can I Do To Get It Working Again??? Please Help Me Straight Away. Thank You xxxx
Some times Memory cards need to be reformated by the operating system you are using, so it will put a volume label when you format it, that way you won't get a syntax error.
When you plug in your memory card when your computer should recognize the Memory card just like a hard disk. That is when you need to re-format the memory card just like a hard disk. then try taking pictures then try transfering to your computer.
Dec 06, 2010 | SanDisk 4GB microSD High Capacity Memory...
Just installed 2 2GB cards (Corsair VS2GB800D2) to replace the 1 1GB card in my emachines EL1200 series. Computer will not boot. replaced the old card and it booted right up.
Will it boot with only ONE of the 2GB memory-sticks installed?
Will it boot with ONE of the 2GB memory-sticks AND one of the 1GB memory-sticks?
Look closely at the 1GB memory-sticks.
Does the label show 'DDR266' or 'DDR333' or 'DDR400' or 'PC2100' or 'PC2700' or 'PC3200' ?
Do the 2GB memory-sticks have _identical_ information?
It's definitely _not_ acceptable to have "slower" RAM (smaller numbers) in the new RAM,
but it _might_ be acceptable to have "faster" RAM (larger numbers).
Nov 12, 2010 | E-Machines eMachines Desktop PC
The problem is with my 1GB memory stick. I don't
Check your computer
with antivirus and antispyware program and format 1GB memory stick.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format 1GB memory stick
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jan 21, 2010 | Electronics - Others
Memory card decreased memory
you have either formatted it as 2 disks or the card is developing faults. Check the number of disk volumes in Computer Management. If only 1, throw the card away. (Make sure it is formatted as NTFS, or FAT32 NOT FAT.)
May 26, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Memory stick card reader won't read
have you installed the driver for the 5-in-1 card reader?
check hp for your model.
Jan 23, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Samsung D600 memory card format
When i insert memory card it says not allowed
Mar 03, 2008 | Samsung SGH-D600 Cellular Phone
SanDisk 1GB microSD Memory Card Logo
472 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
