Push power protect Sony mhc vz30av - Audio Players & Recorders
Luis2584
  • 7 Answers
SOURCE: protect push power
you have wires touching. did you drop anything in your radio? water, medal's?? etc..
Posted on Dec 19, 2008
SOURCE: sony mhc-7av push power protect
Maybe the audio amplifier IC damaged and need to be replaced good luck
Posted on Feb 11, 2009
  • 4 Answers
SOURCE: I cant turn volume up all the way on my Sony MHC NX 3av
Make sure your cables are not touching each other, and/ or that they have been inserted into the right terminals on the speakers. This should rectify the problem.
Posted on Aug 07, 2009
  • 4234 Answers
SOURCE: sony Mhc GS100 want power up
The unit is in protect mode because a problem was deteected in the final output stage of the amplifier. The pop in the speakers is a god indication that there is DC current in the output stage. This is not a good thing. This is a relatively common failure of all receivers and can easily be fixed by any shop that does audio repair. Expect a parts cost in teh $30-$40 range.
Dan
Posted on Aug 19, 2009
SOURCE: Sony MHC-57AV - System shuts down "Push power protect button"
this problem is audeio out put is sort .pls ching out put STK .Any Q - My ID uttamkholiya@yahoo.com
any sony music system problem
Posted on Nov 07, 2009
Sir my MHC-RV900D is disply shows push power protection again and again.plz solve my problem. thank u
There is most likely a short in the amplifier that will need to be repaired before the unit will power on normally.
Mar 12, 2013 | Sony MHC-GX40 CD Shelf System
How To Remove Push Power Protect To My Sony mhc-dp1000d?
You can't. There is a short in the amp that needs to be repaired before the unit will power on normally.
Mar 07, 2013 | Sony MHC-DP1000D System
MY SONY MHC-VZ30AV ERROR MESSAGE PUSH POWER PROTECT
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Thank you for using Fixya
Sep 06, 2011 | Audio Players & Recorders
Protect push power
audio amplifier IC fried need to be replaced
Jun 01, 2010 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Sony Mhc GS100 want power up
Dan
Aug 19, 2009 | Sony Audio Players & Recorders
Protect- push power
After installing the cd display shows the Push Power in the model of MHC-RV5
Jul 07, 2009 | Sony DVP-S330 DVD Player
Protect push power
Dec 19, 2008 | Sony MHC-RG30T Shelf System
Push protect problem/ sony MHC-VX33
push power protect is error signal shows problem in power amplifier board, mostly power amp out
IC STK402-100S found deceptive.
contact nearest Sony service center for proper repair.
Sep 29, 2008 | Sony MDS-JB940 Mini Disc Player
 Grubhead
Grubhead
