Question about Kenwood (KVT-729DVD) Car Video Player
Hi. i have a kenwood ddx7032, monitor with dvd receiver and navi system. the issue, there are 4 white lines across the middle section of the screen. any thoughts?
4 Suggested Answers
hogan doan
  • 227 Answers
SOURCE: kenwood car dvd
With Pioneer system that problem is common because of the ribbon cable defect, but I dont know about Kenwood. Have you contact Kenwood and express the problem?
Posted on Mar 05, 2008
SOURCE: kenwood
I bought the Kenwwod DNX7120 today 11/24/2008 All I did got a 12gauge or smaller grade about 6" long took the parking brake female out ( the plastic thing that connects to the side prong place on the pedal strip both sides of cable, one side obout 1/2 inch and put into the female plastic casing and plug it back in, took the other side strip it 2 iiches and loop it around the metal holder of the switch an put some tape. So you can press the parking pedal if needed and everything stays in place no dangling wiere. Very easy. you can watch video or use the phone book and make a call. wiout having to press the parking brake. WARNING!!!! DRIVE SAFE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Nov 26, 2008
rulds2008
  • 3866 Answers
SOURCE: my kenwood kvt 729 dvd monitor is not working. The
Thanks for posting your question, I am here to help!
If you hear sound but no video chances are the screen is indeed the issue now here is what you can do.
  • Check for a replacement screen and put it in yourself.
  • Take the unit to a factory authorized repair center.
  • if there are A/V outputs you can hook up a external screen (most models have this)
The screen is bad because of the following issues:
The back light witch is the white background you see is firing (not a back light issue)
There is a bar running across the screen meaning the LCD is damaged or defective.
Now in rare cases you can go in and check and see if the Ribbon cable is dislodged from the main board, do not shoot the messenger but it happens. Other then that I feel you need a new lcd screen for this unit based on what you told me.
I apologize in advance if I was not clear on my answer to you.
Thanks for using fixya.com
Sincerely
Ed aka rulds2008
Posted on Nov 27, 2010
White line in middle of screen on a cx32h60 toshiba tv
The vertical sweep output is absent. Check its vertical output section circuit for the fault. Check all the solder terminals of that section, and resolder them by applying a little more solder. Take special care to the solder terminals of the vertical output IC. If these do not help you, check and replace the vertical output IC.
Jul 07, 2012 | Toshiba CX32H60 TV
My lg m2762d lcd tv has a half millimeter white line across the screen can you tell me whats wrong?
makes a difference where this line is... very top, top, middle, bottom, very bottom? also, is this set new to you, or has it been fine for a while, and just started doing this? does the line stay there when you switch to other inputs? (like a dvd player or a gaming console)? this kinda stuff will help you get an answer that makes sense - good luck
Dec 11, 2010 | LG W2753V PF Flat Panel 27" LCD monitor
My kenwood kvt 729 dvd monitor is not working. The screen remains white with a thin blue line across the screen when powered up. i have reset the unit and checked all wiring. i have audio but no video.is...
Sincerely
Ed aka rulds2008
Nov 27, 2010 | Kenwood (KVT-729DVD) Car Video Player
My ViewSonic monitor is having an issue with blurring lines. Anything on the left or middle of the screen blurs to the right in a faded color, extremely noticable when I open MS Paint and fill the left...
This is a tipical flyback defect circuit, the lines can 1st appear on top/bottom of screen, then can increase to center. Send monitor to repair center, for check and repair. You can test with a tv test signal.
Dec 11, 2009 | Computers & Internet
My toshiba laptop has a thick white line down the screen
The normal cause of lines across the LCD of a laptop is a damaged video cable. The unusual cause would be the video card itself.
To determine which item is at fault, you need only attach an external monitor to your laptop's video-out, and then swap your monitor view to 'both' or mirrored (usually just the function key (FN), plus one of the Fkeys...look for an off-blue picture of a monitor on the Fkeys).
If the lines across the screen also appear on an external monitor, then the video card is damaged.
If the lines only appear on the laptop's LCD, but not the external monitor, then just the laptop's internal video cable is damaged.
Hope this helps.
Aug 21, 2009 | Toshiba Satellite p105-S6114 Notebook
Black Screen with white line across the
the vertical IC most likely has failed
Jul 19, 2009 | Televison & Video
Line across screen
scane for virus and reinstall the operating system
May 30, 2009 | Computers & Internet
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Kenwood car dvd
Nov 30, 2007 | Kenwood KVT-717DVD Car DVD Player
Horizontal Bright White Line in Middle of Screen.... and thats it.
by the sounds of it the mon is in a word goosed
but please dont open it up to try and tinker with it !
as they hold a charge for a while beware !
Nov 10, 2007 | Compaq FS 7550 17" CRT Monitor
Kenwood (KVT-729DVD) Car Video Player Logo
54 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
