Question about Refrigerators
There is an al02 fault code on my fridge but it is working normally. why is that?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
Usually means water supply failure. Do you have an ice maker on the fridge that you are not using because the water line is not hooked up to it or is turned off?
Posted on Nov 05, 2012
  • vasso3131
    vasso3131 Nov 05, 2012
    my fridge does not have an ice maker
Error message al02
Al02 is inlet solenoid faulty heater open circuit check all connections first
Nov 25, 2012 | Hotpoint-Ariston SDW80G Dishwasher
Can you tell me what the al 02 code means for a fridge whirlpool ARC6706/IX
AL02 refers to Utility Voltage either over or under frequency
Nov 05, 2012 | Refrigerators
Hi I have a Hotpoint fdw80 witch is displaying an error code AL10. Please can you tell me what this means so I can decide a course of action. Many Thank's Amanda
I found these error codes for the hotpoint fdw80
AL01 - Anti flood switch operated
AL02 - Valve or connections
AL03 - Time out - drain
AL04 - Thermistor (module)
AL05 - Circulation pump
AL06 - Time out - fill
AL07 - Not used
AL08 - Time out - heat
AL09 - Software recogntion error
AL10 - Heating circuit
AL99 - Communications error - connectors, cables etc.
H20 - Time out - fill (taps)
Now looking at AL10 error. Most often it is the heater element which is not effective due to scale formation. Make a solution of white vinegar and water (50:50) pour it onto the base of the dishwasher. Leave overnight and run dishwasher as normal. Somehow the vineger has to reach the heating element which is an inline heater. I am assuming normally you would use the hotwater connection from the kitchen tap.
If this does not help - depends how soon into the cycle you get the error you will have to replace the heater. I think it would look like this.
Feb 01, 2011 | Dishwashers
My refridgerator is making a buzzing sound with a click at the end every 2-3 minutes. The buzzing lasts about 5-7 seconds with a single clock at the end. When this sound is made the lights in the fridge...
Possible this can be a faulty thermostat sensor action tripping the relay which is clicking. You must remove and check the backside relay if the fridge is old for a wearing off.
Also a fault in the circuit of the auto defrost can cause the compressor to shut and start.
Since the fridge works well the fault can be related only to a erratic connection or failing component.
Jan 31, 2011 | KitchenAid KBRP20EMSS Bottom Freezer...
My fridge trips the breaker when you try to turn it on
I have a couple of things for you to check or rule out. Today, a refrigerator is required by electrical code to be connected to a dedicated, 15 amp outlet because the newer fridges are more efficient and use less than 12 amps. Not long ago, a dedicated 20 amp outlet was required because the older fridges were rated to use 12 amps or more (but less than 16 amps) and needed the larger size circuit. A 20 amp circuit breaker or fuse should not open for any standard residential fridge under normal operating conditions. A 15 amp circuit breaker or fuse _MAY_ open if an older fridge (needs 12 amps of more) is connected. Make sure that if a circuit is opening at the fuse or breaker, it is not because there are several appliances or devices in use and on the same circuit as the fridge.
The same holds true for "ground fault" and "arc fault" type circuits. If an older fridge is connected to such a circuit - nuisance tripping may result. Most newer fridges however shouldn't cause a problem on these circuits. Ground fault circuits have a "test" button on the circuit breaker or, "test" and "reset" buttons on an outlet providing this protection. Arc fault circuit protection is available only in circuit breakers (as of this time - but may become available as outlets some time in the future).
If you need to to try to isolate the problem on a 20 amp circuit, disconnect all other appliances on the other 20 amp circuits in the kitchen and dining room, then see if the fridge stays running. Alternatively, you could use a heavy duty extension cord to connect the fridge to a known isolated 20 amp circuit to see if the fridge runs. This is meant only to troubleshoot - the fridge should not be left connected via extension cord for normal operation.
If you still have tripping, you might need to have the fridge professionally serviced, as a ground fault could be a dangerous condition left unchecked.
Please rate this replay id found to be helpful - good luck!
Jul 07, 2010 | Frigidaire Refrigerators
Miele KFN8462S fridge freezer is displaying an F2 fault code.
F2 Is fridge evaporator sensor faulty it will require new sensor part no.7323301
Apr 01, 2009 | Miele KFN8462S Bottom Freezer Refrigerator
I have a samsung RS21DCNS fridge but i have jus had apower cut for 10mins and now the fridge is not working. the lights are coming on inside but there is nothing on the contol panel and none of the buttons...
unitl you either cleanr the code or repair the fault that is what you see.the fault is the ice maker sensor is not reading correctly. check the plug connections for the sensor. if you would like you can contact me and i will help you with this problem.
Jan 17, 2009 | Samsung RS2630SH Side by Side Refrigerator
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
Refrigerators Logo
176 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
