Question about Insignia IS-DVD1001 DVD Recorder/VCR
DOES NOT INITIALIZE BLANK DVD
I INSERT A BLANK DVD+R AND THE PLAYER DOES NOT INITIALIZE THE DISK. IT READS AS UNKNOWN AND THE DRAWER REOPENS THE SET UP MENU FOR THIS IS IN FADED LETTERS AND UNAVAILABLE FOR ACCESS.
  • 3 more comments
  • mkayn Jan 07, 2009
    insignia dvd vhs recorder is-dvd100121
    insert blank dvd+r the recorder does not initialize the blank disk for recording
    i did read the manual / the problem is in the recorder / it does not give an option to intitialize a blank dvd
    i found that it does not recognize a playable dvd but will recognize and play a photo cd
    have used several dvd's but not a different brand it used to recognize the brand that i am using at one time
    if it was a lens problem then it would not read a cd either i would think
    Genius:
  • 1,550 Answers
It is a mechanically problem in your player .
You need to open the player and check whether the rubber thread connected to the motor inside the DVD player has moved from its place. If yes then you need to place the rubber thread to proper place.
Also there is chance that the belt is slipping, the mech never gets the "drawer closed" signal, and the disk will not spin. So your dvd is not recognized .
Posted on Jan 07, 2009
  • 163 Answers
Hi!!! i know what call this guy and tell him to bringt he old rubbing alcohol ,that unit is dirty..clean the laser lens....DOES NOT INITIALIZE BLANK DVD - eaee73e.jpg
  • 916 Answers
If this problem is happening with several different types of disks and several different types of media then it is a hardware issue. Which means the dvd mechanism will need to be replaced in order to recover from these errors.
    Genius:
  • 1,199 Answers
At this point your only fix is to replace kens pickup!
  • Insignia Master
  • 19,396 Answers
Try using a DVD -R or a different brand DVD, often this units do not read well all DVDs brands, or work better with + or - R format.
If the Unit gives the same problem on all DVDs , and you hear the motor spinning, trying to engage DVD to read tracks, then it is a lens problem.
Try cleaning the lens with a claner kit, try a good one with cleaning solution, see here.
If it still does not work, then you need to access the lens and clean it or replace the lens pickup, to do this the unit must be taken apart, and the job must be done by a technician.
Try using different DVDs and eventually a lens cleaner, that often can fix the problem.
  • Insignia Master
  • 6,487 Answers
Try using another DVD+R if possible a different brand to check if this is not a problem with the disc that you're using.....
  • Mark Gil
    Mark Gil Jan 07, 2009
    If that is the case the problem here is in burning to DVD+R only and its a sign that its going bad already and you may need to check from manufacturer to check for any firmware update....
  • 728 Answers
Try using a blank dvd of a different kind and see if it works with it. The one you are trying to use may not be able to be burned with that burner because it might not be in a format that the player can read or burn on to. When you get a blank dvd into the player that works with it, then you will be able to get to the menu and operate it. If you still can not find a dvd that works with it, then you may need the burner laser replaced for it to work. Try playing a disc and see if the disc plays. If it does not play, then you may need the laser replaced.
  • 565 Answers
Read the manual - http://www.insignia-products.com/skins/skin_1/Topics/Documents/IS-DVD1001_Manual.pdf. maybe its better if u use dvd-r discs
  • 837 Answers
I put in a blank or recorded disk ,and the screen message is " unknown disk", and ejects the disk. I have used different blank disks,with the same result. Seems it is not " reading" the disk. Probable...
are you sure the drive is a read-writer? some optical drives are read only. If its not a writer and you put a blank in, that is what it would do.
If you put a real and recorded disk in(not a copy) and it says unknown disk, the eye is dirty. Cleaning the drive will be the next step.
Feb 02, 2018 | Televison & Video
When I insert a blank DVD+R to copy a VHS, It reads the disk, says "Unknown Disk" and ejects it. How do I record if I can't keep a disk in the machine?
some discs don't work in some recorders. I always use verbatim, ritek or tdk discs and have very few problems. if the recorder suddenly dislikes a batch of one brand, I'll use one of the others.
Jan 29, 2015 | GoVideo VR3930 DVD Player/VCR
When I insert a blank DVD to copy a VHS, It reads the disk, says "Unknown Disk" and ejects it. How do I record if I can't keep a disk in the machine?
I've just answered this. please don't post the same question more than once, it doesn't help. I've just wasted time answering this instead of someone who needs help.
What speed of disk did you use? On my older machine if I use faster than 4X it will not accept the disk. Check out your disk an see if the record speed is to fast for the machine.
A dvd is stuck in my player on my tv and the screen reads no signal. What's happened?
Can't help you on what is wrong with the player but to get the dvd out, look for a small hole near the dvd drawer opening. Use a straightened paper clip or a straight pin and insert into opening. This should release the drawer to eject the dvd.
Feb 27, 2013 | Memorex Televison & Video
Dvd drawer wont stay closed
take it back to the store or repair shop. Same thing happened to a friend and because it was new, the machine was exchanged.
Jan 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
My DVD writer reads but does not write.
DVD discs have to be formatted before they can be recorded on.
Jan 02, 2018 | ASUS DRW-1814BL Internal DVD Drive
Go video vr3840 dvd/vcr player recorder combo
HELLO. IT SOUND'S LIKE YOU NEED TO CLEAN YOU RECORD & YOUR PLAYER TO ME . "GOOD LUCK"
Jul 23, 2008 | GoVideo Go Video DVD/VCR Combo
Koss KD365 DVD - Says No Disc
Make sure the disc is spinning. This might sound crazy but try turning the whole player upside down and see if it plays.
Jan 02, 2008 | Koss KD365 DVD Player
"Unknown disK"
Our LG disk recorde thing does exactly the same!
Nov 04, 2007 | Televison & Video
Insignia IS-DVD1001 DVD Recorder/VCR Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
