How to reset the transfer belt unit message - bizhub c 353 ?
Reset transfer belt
  • 214 Answers
SOURCE: transfer unit on bizhub C250
its not so hard, open side door, remove 2 screws, and pull out the transfer unit gently. and reinstall new TBU. BE VERY CAREFUL WITH NEW UNIT, DO NOT DAMAGE IT.
Posted on Jun 19, 2008
SOURCE: Transfer unit Bizhub C250
reset life of actual transfer
Posted on Feb 14, 2009
  • 12 Answers
SOURCE: how do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
Posted on Mar 20, 2009
SOURCE: Bizhub C450: After replacing the image transfer roller & ozone
In Service Mode -> Counter -> Life -> Select the one you want to reset and press 'C'
Posted on Aug 23, 2009
Bizhubman
  • 108 Answers
SOURCE: how to reset the transfer unit (fuse?), do you
Hope this helps. Make sure you remove the waste tank prior to taking out the transfer belt. Belt is removed by two screws inside right door and sliding the unit out.
Posted on May 17, 2010
What is the cause of errors code p 27 for Konica bizhub 353
Check the 2nd transfer roller (the sponge looking one on the right side of the machine, across from the Transfer belt the shineey looking thing inside the machine.
Apr 05, 2016 | Konica Office Equipment & Supplies
Konica minolta bizhub c253
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Aug 21, 2014 | Konica Minolta Minolta Bizhub C253 Copier
After BizHub C450 copier has stopped and said replace Transfer Belt, is there anyway to get back up running until new belt shows up
Remove the transfer belt unit and change the chip fuse on transfer unit.The fuse is or a little green pieces or glass fuses ,the value 0,065mA/250V rapid fuse.After change the fuse pull on the unit and turn ON the copier.Before change the fuse reset the transfer belt counter in the Present parts life mode.
Mar 29, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
C13c8
C13C8 A new installation is not detected when a new Transfer Cleaner Unit (Image Transfer Belt Unit) is installed.
When a new transfer belt unit is installed in a machine an internal component on the transfer belt unit changes state; this now indicates that the transfer belt unit is used
http://kmcopierservice.blogspot.com/2011/02/how-to-reset-transfer-belt-bizhub-c203.html
Apr 10, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Machine status P-9 what is this message?
Black Imaging Unit failure
• All density readings taken from the density pattern produced
on the Transfer Belt are 0.5 g/m2 (IDC Sensor
photoreceiver output) or less during max. density
adjustment (Vg/Vdc adjustment).
on the Transfer Belt are 4.5 g/m2 (IDC Sensor
Photoreceiver output) or more during max. density
adjustment (Vg/Vdc adjustment.)
Remove and reset the Black Image Unit. If this doesn't help the Image Unit may need to be replaced.
May 25, 2010 | Konica Minolta bizhub C250 All-In-One...
How to reset the transfer unit (fuse?), do you
May 15, 2010 | Konica Minolta bizhub C250 All-In-One...
Where can I get instructions on how to replace the transfer unit of my Bizhub C252?
Please visit the site http://www.resetkit.eu
There you can find how to reset your fusing unit and transfer kit unit for almost all Konica Minolta MFP's and printers, Bizhub C252 included.
You don't need to replace it, you can just reset it and save a lot of money.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
Oct 22, 2009 | Konica Minolta bizhub C250 All-In-One...
How do you reset the life of the transfer unit on the Bizhub C250
Yes,
Bye.
Feb 14, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
I have a C6500 and it has a 2220 code
C-2220 When the transfer belt motor
(M18) was ON, M18 abnormality
detection signal was continuously
detected for the specified
time.
solution
Printer control board (PRCB)
Transfer belt motor (M18)
Dec 19, 2008 | Konica Minolta bizhub C250 All-In-One...
397 people viewed this question
jasbo
jasbo
