Circuit diagram for sanyo dp26647
Power Supply Card Bunt by Lizards.
4 Suggested Answers
  • 8457 Answers
SOURCE: SANYO DP26647 blank screen, please help
U have LED front power tv light come on and bliking?Than ur power suply it dead.Power supply board must be replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Posted on Feb 10, 2010
schadwick85
  • 11 Answers
SOURCE: steady vertical lines in picture
I have a Sanyo DP42746 model, 42". From my research I believe the lines in the picture are letting you know your Buffer Board is about to go out. Mine recently cut out, and it caused horizontal lines to appear. Hope this helps : /
Posted on Jan 05, 2011
I have a sanyo dp42848 turns on perfect picture then goes black you can see picture with flashlight voltage from power supply is present visual inspection of all boards and caps look good inverts ?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 24, 2016 | Sanyo Televison & Video
We hit the menu butten in the wrong way on our sanyo dp26647 NO picture.. We have sound
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 17, 2016 | Sanyo DP26647 26 in. LCD TV
Is there a reset button on the tv, I have power but get no picture, not even snow
Seems to me that one if your transistors or resistors popped inside. Try turn it on and off to see if anything happens.
Nov 02, 2014 | Sanyo DP26647 26 in. LCD TV
Sound ok no picture
Check that the power board has any blown caps, and replace them if needed. Another possibility is that the tuner board is fried and the CPU does not process the picture signal any more.
Aug 22, 2014 | Sanyo Televison & Video
The HDMI ports on my Sanyo DP26647 wil not work correctly
Sounds like your hdmi jacks are ( pardin the pun ) jacked up. Shine a flashlight in the jacks to see if the pins look loose or if the jack has been widened at all.
Mar 20, 2013 | Sanyo DP26647 26 in. LCD TV
My 42 inch sanyo wont turn on, the power to the outlet works
Hello jboogie3945,
Welcome, and thanks for using FixYa!
To answer your questions: Since you have tested the outlet this set plugs in too, and it is ok, then we can turn our attentions to the Power Supply Board.
With confidence, we can say this board will need to be checked for a blown fuse or the entire board will need to be replaced. I have included the link below, so that you can see what the board looks like, and in the event you need/want to replace it.
Power Supply Board
http://www.ebay.com/itm/SANYO-DP26647-DPS-161AP-1-/360367778759?pt=LH_DefaultDomain_0&hash=item53e797ebc7
Have a great day!
Sep 12, 2011 | Sanyo Vizon LCD-15A2 Television
My 26 inch sanyo tv does not want to turn onm
First place to look will be the power supply module, please read my guide so you will understand how LCD TV works and know what to look for.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 10, 2010 | Sanyo DP26647 26 in. LCD TV
Sep 21, 2009 | Sanyo DP26647 26 in. LCD TV
Sanyo DP26647 Black no sound I have pressed the reset button 2 times but nothing happens.
Hello tyarbrough,
This might be an indication of a power supply problem. Since the TV appears to be completly dead. This might be a problem with the power supply board or the boards that attach to the power supply board. I would suggest that you have a qualified TV technician check your TV since the procedure requires knowledge of electronics.
I hope this helps,
Thank you,
Shuttle83
May 31, 2008 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
