Question about Aquatemp Products Pool & Spa
Aquatemp heat pump for swimming pool showing ( or ) fault
The X5 controller is showing OR fault
  • 2712 Answers
SOURCE: How to Clean Pump Strainer basket
Turn the swimming pool pump off and wait for the water to drain from the strainer basket. You want to make sure that the pump is completely off before you proceed. Remove the screws or any items securing the lid of the strainer basket. Open the lid and pull out the strainer basket. Vacuum the strainer basket or scoop out any debris. You may want to run clear water through the basket to ensure you removed all debris. Feel toward the impeller and remove any clogs or obstructions preventing the impeller from working properly. Check the o-ring under the cover of the pump strainer housing. You may need to use a silicon lubricant to ensure a water-tight seal. Put the strainer basket back into the pump strainer housing and pour some water into the basket. Replace the lid and secure it in place. Turn the swimming pool pump on and check for proper pressure. If your pressure doesn't register, you may need to troubleshoot to find the problem.
Posted on Aug 27, 2008
  • 2712 Answers
SOURCE: outdoor pool temperature
We usually heat ours to around 85?F. In fact, in the summer, we consider our pool cool if it stays below 90?F (where we live a 115?F is normal).
  • 11 Answers
SOURCE: Swimming pool cleaning robot doesn't move
Sound like your filter is dirty. Try backwashing if you have a sand filter, or clean your cartridges if that's what you have. A dirty filter will reduce water flow, which in turn affects the Nav.
Posted on Jan 02, 2009
SOURCE: Need help installing filter pump model 635 for my swimming pool
Just go to the Intex Corp link below. Choose the appropriate pool and/or pump. At the bottom of the page you will see a link for instructional manuals and videos. Hope that helps.
http://www.intexstore.com/ProductList.aspx?categoryID=30
Oh yeah, by the way...you may want to start looking around for another pump for that pool if you plan on using it more than a year. I have had mine for 3 years and I spend more time in the pool vacumming than I do in the house!! The 635 pump is not strong enough for the 18x52 pool nor does it filter out fine silt and sand...it sucks it up and spits it right back into the pool thru the return. Good luck to you
Posted on May 22, 2009
lonewolf1996
  • 142 Answers
SOURCE: Intex Easy Set 530 Gallon swimming pool filter
You will need to go to the manufacturing web site and get a new seal for the pump.They cost some where around $1.00 to $2.00.
Posted on Jul 03, 2009
Air coming out of return holes in pool
You have a leak in one of your suction lines allowing air into the returns. Swim Time
Feb 24, 2014 | Solar Heating System For Swimming Pools
BLOWING FUSE IN CONTROL PANEL
if not ignitor shorted maybe blower motor bad
Jun 10, 2012 | Hayward Heatpro 81k Btu Swimming Pool Heat...
What does roof censor O/C mean on a sunlover pool solar heating SL2 controller?
If showing O/C then pool sensor is Open Circuit (cable may be broken) or unplugged.
If showing S/C then cable is Short-Circuited or may have been disconnected from the plug and then reconnected in reverse.
Damage to roof cables often occurs if buried in trench and not in conduit. Swap the pool sensor with the roof sensor to prove that the
fault indication also swaps. This proves that it is a sensor fault and not the unit. The Manual for the SL2 Controller is on the Sunlover Website - www.sunloverheating.com.au under the Controllers tab. Sounds like youll need a new sensor - nice and simple - call Sunlover and they will post one out or you can collect one from their office.
Quality Swimming Pool Heating Melbourne Sydney Brisbane Perth
Jan 27, 2012 | Pool & Spa
Have a brand new AquaPro heat pump for our brand new swimming pool, It worked 3 days and quit. Is saying pool temp is 136 degrees
Thank youfor posting your question here on Fixya.com. It sounds like the water temperature sensor is faulty. I recommendyou call AquaPro Systems at 1-877-278-2797 and they should be able to help youfigure this issue out. I hope this helps.
Ifthis answer does not resolve your issue, please comment with additional informationbefore rating the answer. Positive feedback is especially appreciated once yourproblem is solved! Thank you.
Aug 24, 2011 | Aqua Pro Swimming Pool Heat Pump 125000...
HOW TO WINTERIZE AQUAMATE ABOVE GROUND SWIMMING POOL PUMP
Open the plugs on the bottom front of the pump pot and on the pump housing itself. These two plugs will do the pump and just the pump. You should have simmilar plugs on the filter, heater, chlorinator and any other equiptment on the system.
Oct 13, 2010 | Hayward Sp1580x15 Power Flo Lx 1.5hp...
LF READING ON PANEL
LF means "Low Flow". Remove the filters to see if the code goes away. If not, the pressure switch may be bad.
Feb 09, 2010 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
Have a supreme Solar - Solar conroller for swimming pool. Roof indicator light is flashing and system wont turn on, (not even in manual mode) Pump working OK though. What does this mean
it sounds like you have a problem with the air temperature sensor on the roof. either you have some damage to the wiring going to the sensor, or the sensor itself has gone bad. Also, check the wiring inside the control box, make sure the connections are tight. If possible, follow the wire from the control box all the way to the sensor. If the wire looks good and there is no damage at all, the sensor probably needs to be replaced.
Nov 08, 2009 | Solar Heating System For Swimming Pools
Pool and Spa Heaters pros and cons
An electric heat pump needs heat available to pump. If it is 30 degrees outside, heating a spa to 102 or so, may be impossible unless the heater has some type of alternative heat source. A properly sized, gas fired heater can take care of a larger range of heating needs. A combination heat pump and natural gas heater, probably with a controller, really makes the issue more difficult, expensive, and would require a lot of study for efficient, cost effective operation. Bottom line: In really mild climates a heat pump might do the job. In cooler climates the gas heater rules. And where a wide range of temperatures and high heat demand is wanted by the customer, a gas heater is the only way to go. A backup heat pump may take years to payout.
Aug 27, 2008 | Saunacore Special Edition Residential...
Pool & Spa Logo
80 people viewed this question
Top Aquatemp Products Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Aquatemp Products Pool and Spa Expert? Answer questions, earn points and help others
