Question about JBL Encounter 2.1 Computer Speakers
Low Audio on my encounters and I can't change the volume
Alright, so I pulled my speakers out of storage, I just moved and got set back up. I hooked them up to my new laptop. when the laptop speakers run the volume is controllable however the speakers nifty volume controller is not working for me. I hope its not my speakers. But being as I'm no computer dummy the only other thing I could think of is maybe a conflict with the drivers and windows vista but I don't think it could be that...
  • 3 more comments
  • Joe Munn May 21, 2007
    Okay, so I just tried my girlfriends laptop it is a problem with either the drivers or vista, this is wierd..
  • tomkell Nov 12, 2007
    Hi ,
    Same problem with encounter , running windows xp and have tried to find a driver with no luck . the speakers voloume is very low even with the computer volume at max . they worked before on the same computer . i am totally baffled .
    please help
  • dead-dread Apr 08, 2008
    I'm running the speakers with a macbook, they've been fine for nearly a year..plug in plug out.. no probs. Been away for a few days though and plugged the mac back in.. Now even with full volume they are very quiet. Also when pressing the touch controls i get a buzzing noise...? When i went away for three weeks they were fine.. I've tried everything except kicking it.. WTF?
    wow, just cured it... took the phono cable and touched it on the touch volume control (+) ...big buzz but now works fine again.. i'm no electrician so am at a loss to explain.. hope this helps anyone else with the same problem...
  • Anonymous Apr 02, 2009
    exactly the same with mine - not used for a while and now the sound is very quiet and not adjustable. I'm lost. Help?
    P.S. will try that cable trick tonight..
    Genius:
  • 2,985 Answers
Vista is now known to have driver acceptance problems and the manufacturers of peripherals are getting bolshy at hiving to provide answers- there is a war breaking out between uncle Bill and the rest of the trade. But try on line with the Sound system providers you may get lucky
Posted on May 21, 2007
Low volume nsm firebird jukebox
restore your Phone Settings
Aug 08, 2012 | Cell Phones
Rca tv ..how to hook up to home speakers
Unless the set has actual audio outputs it should not be done.
The set will have a very low audio output not intended for external systems--if you hook to wrong impedance speakers volume either will not work, be very low or even damage the audio circuit in the set
Mar 28, 2012 | RCA 27V530T 27" TV
I can not increase or decrease volume on my JBL encounter speaker system
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
Apr 11, 2011 | JBL Encounter 2.1 Computer Speakers
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
How to increase speaker volume on Dell Vostro 2510? Everything is set to maximum, but volume is still low !
it might having a problem with your speakers,change it...or change audio cable pin or check it by moving it or by inserting it correctly in audio panel
Dec 12, 2009 | Dell Sound Blaster Card
My speakers seem to be stuck on a very low volume
I have speaker problem no sound but I know its there because when I turn on volume can hear it turn on it was working before my computer is hooked up to magicjack for my telephone different area code then where I live and the other day when I picked up reciver to make a call could hear my speakers on my phone assastance asap PLEASE
THANKS
Marie
Jun 02, 2009 | Logitech X-240 Computer Speakers
Standard speakers to the computer , low volume
You are getting low volume because there is no amplifier in those speakers. Computer speaker sets are powered -- there is an amp in one of them them which drives both speakers -- a computer audio output without an amplifier will only satisfactorily drive headphones.
May 11, 2009 | HP Compaq JBL Pro (401508-001) Computer...
Max. VOLUME on Samsung TVs Too Low
Some models have a volume limit setting, check the MENU and look at the audio settings.
If this has external speakers use other speakers. If it has audio output connect them to a external amp and useing the remote adjust the volume. Check if audio settings are set to internal, external and fixed or vairable output.
Jan 09, 2009 | Samsung LN19A451C LCD TV
12w3v2 Started making distorted bass noise at low volume
Connect each speaker coil one at a time to a square 9 volt battery and watch for the cone to move.
Also try hooking another speaker to your amp just to make sure the noise isn't in the amp.
You can use a 9 volt battery to test wire polarity also. Hook up the + wire of the speaker to the + terminal of the battery and the - speaker to the - battery terminal. If the speaker moved UP or OUT then the wiring is correct. If it moved IN or DOWN then the + and - wires are backwards on the speaker.
Also if you have two or more speakers hooked together test all the same way while they are hooked to each other. ALL of the speakers need to move in the same direction at the same time.
Clipping causes more speaker damage than anything. "Dirty Power" can happen in good quality amps too. The gain control is to match the voltage between the headunit and the amp. It is NOT a volume or boost knob. If you overdrive the first stage of the amp and then clip it damage will occur to the amp and speakers at some point.
Hope this helps.
Jan 04, 2008 | Jl Audio 12W3 Car Subwoofer
TDA7564
internal amplifier.. I have the same problem. When you set the volume in 0 much time, trend to happen it.
Jun 05, 2007 | Alpine TDA-7563 Cassette Player
JBL Encounter 2.1 Computer Speakers Logo
541 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
