Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Mitsubishi 52725 caps issue
Have tv apart. I am going to replace electro caps. Which surface mount caps need to be replaced on the FMT brd.
thanks,
jason
email: j.knouse@comcast.net
  • 179 Answers
All 47uf, all 220 uf, all 100uf, probably most if not all of the 10uf, and 4.7 uf. it is a pain. they are all surface mount caps and very close to feed thru's. I repair these for a living and have specialized de-soldering equipment just for these. since you have it apart why not check out www.tv-techs.com. it might be easier.
Posted on Jan 07, 2009
Model: 52725 we hooked an xbox to this thing and it wont give us a clean picture, rather black and white fuzzies and has green lines shooting across the screen, sometimes purple going across the screen...
There are small surface mounted capacitors on the dm Board and the fmt board that have gone bad. They need to be replaced. Most tv techs will charge about $400 to do this.
Mar 16, 2011 | Mitsubishi WD-52725 52". Rear Projection...
I have a Misubishi DLP wd 52825. The timer light keeps blinking and I have no picture or sound. I cannot turn the power on. How can this be repaired? Or what is wrong with it? I have unplugged the TV for...
Most likely the issue is bad capacitors. You need to check for bad 1000uf 16v caps on the dm board and the fmt board. Be sure to checked surface mount fuses on DM and FMT board after you replace the capacitors.
Not to easy of a job due to how much dis-assembly needs to be done. Instructions can be found online on how to do this.
Mar 08, 2011 | Mitsubishi WD-52825 52" Rear Projection...
Blinking light with no picture or sound
If you have a green blinking light,
Most likely issue is with bad capacitors on the DM an FMT boards.
1) Look for bad 1000uf 16v caps on the dm board and the fmt board.
2) checked surface mount fuses (small white boxes) on DM and FMT board
Look carefully for other bad capacitors in the general area.
Start here and let me know the results.
Note, there is a lot of disassembly to get to these boards. Not a fun project.
Feb 20, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Green diagonal lines
the FMT caps have most likely failed. You can get the V26 FMT repair kit from www.tvrepairworld.com which also contains instructions.
Aug 08, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Horizontal Lines in Picture, Picture Possibly Dimmer
The dimming is usually caused by the mirror needing polishing. The lines floating across the screen is usually caused by failed caps on the FMT board you can get the V26 FMT repair kit from
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-fmt-pwb-repair-kit/cName/repair-kits
Jul 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Green light after Capacitor kit replacement WD-62725
I just repaired two Mit WD-62725 sets in the last two weeks.
The first one had bad caps on the power board and the FMT board. The scond one had bad caps on four out of the five boards.
Also, on the FMT board, there was a blown surface-mount fuse.
I advise checking all of the boards for bad caps. If you fine a bad 1000uf cap, replace all of the 1000uf's on the board.
Hop this helps,
Dan
Sep 03, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Vertical Lines on my 3 year old WD-52725
I believe the format, or FMT board is going bad. this is not a do it yourselfer type repair, unless you have extensive electronics background - I have one myself with the same problem. I am waiting to get a new FMT board for mine.
Dec 17, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Need DM or FMT PC board
If the front light of the TV is blinking green suspect caps are bad and change them yourself, google for cap locations
Nov 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Blue Flickering Screen - Which Repair Kit?
yes they provide a free service manual with their kits. the symptom of the blue screen could either be the signal or the FMT as they can both cause those symptoms, My professional guess would be the signal board as the FMT will cause distortion lines across the screen with no picture.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen with flickering horizontal lines
Sounds like the 1000uf capacitors on the FMT board need replacing. This is a common symptom with that chassis. There are three 1000uf caps that fail on that PC Board
May 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
97 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
