Question about Optoma GT700 Projector
Bulb blows on gt700
I am now on my 3 bulb in 3 months on my Optoma GT700 projector. Is there a known problem with this projector?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
Possibly a bad ballast or power supply going to it causing it to either kill the bulb or your old bulb may still be good. Did you rest the counter in the menu for the bulb life after replacing?
Posted on Nov 05, 2012
  • Greg Winters Nov 05, 2012
    Yes, I have reset the counter every time I replace the bulb
SOURCE: dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Posted on Nov 03, 2008
SOURCE: Short picture time when starting Optoma HD72 projector
Mine did the same thing. The bulb is used up...replace the bulb. That fixed mine, working great again.
Posted on Jan 01, 2009
SOURCE: No Power
The problem with the bulb cover interlock(safety switch) tab is that it is molded with the plastic cover. When these projectors are ceiling mounted upside down, the heat from the bulb melts the interlock tab and causes it not to actuate the interlock switch. 5e5b596.jpg If you push the switch arm in you can hear the switch click. The fix I did on my projector was to bend the switch arm so that it stays actuated. You can use a small set of needle nose pliers or two small screwdrivers. be careful to only bend the arm in the middle, if you break the arm from the switch, you will have to go in and bypass the switch.... Just be carefull...
c0cb930.jpg After you bend the switch arm try to press it in, if you did it right you won't hear the click. install the lamp, cover, and your done.
Posted on Apr 14, 2009
  • 6 Answers
SOURCE: optoma hd70 blowing lamps
Hi, My name is Doug Stanko.
I had the same issue and fixed the problem.
All you have to do is take a few screws out..... and blow out the inside VERY well with pressurized air. I have a compressor... and I set the regulator to 50 psi. But the KEY IS TO have the covers off so you can get between the circuit cards and blow them out. They were incredibly dusty. Even after I blew through the side vents.
I agree with all of you that say it is overheating. You are right. There was so much dust on the fan blades them selves... I'm suprised they were still spinning at all.
((And I would not be suprised if your fan is no longer spinning at all. Try this fix... but if you do not hear the fan blowing air through your unit after you have cleaned it out... get a new fan... very cheap part... and you will know how to take it apart after you read the rest. Good Luck.))
And like most of you... first I bought the $300 dollar bulb... put it in and 10 minutes later it was doing the same thing flashing through the colors. So trust me.
There are 4 screws on the back. Take these out.
There are 2 small nuts on the back around the VGA input. Take these out.
There are about 5 screws on the underside (think one was on the bulb changeout portion). These have long copper colored bars that go all the way from top to bottom.
All these have to be removed. Then you can take it apart. AND I PROMISE YOU WILL SEE TONS OF DUST ALL OVER.
Make sure you blow out the parts between the circiut boards AND the fan unit.
Put it back together... and remember to make sure that little latch on the bulb change cover makes the click sound ( it is a switch that must close or the unit will not power back up )..... and it will work great again.
No need for a huge fan next to it. Although I will admit that is an excellent idea.
I did this 3 weeks ago and have been watching it with no issues.
If you do not feel comfortable taking the screws out yourself..... I would take it to your local TV repair store and just ask them to take the covers off and blow out all the dust... and give it back to you. No troubleshooting... no repairs... no replacements... just blow it out.
I was an electronic technician in the US Navy for 10 years... Now I work at a nuclear power plant in Illinois. BUT I PROMISE with a good phillips head screw driver and a small crescent wrench you can do this yourself.
Good luck and you are welcome. I know how frustrating this issue is. But this is the fix.
Doug
Posted on May 13, 2009
SOURCE: OPTOMA HD70 projector turns off in a few seconds
my 3m projector turns off as soon as it is turned on
Posted on Mar 29, 2010
How to fix
what's problem now?
you had better have a service manual
Jul 27, 2014 | Optoma GT700 Projector
Optoma MovieTime: The Lamp that Won't stay on
its definitly a cooling issue.the temp sensor is working because it shuts the unit down.when a lamp goes it goes just like a light bulb.you can open up the unit and locate the fan take it out and go to a radio shack a match it up to a universal fan.
Aug 22, 2007 | Optoma MovieTime DV10 Multimedia Projector
White dots on gt700
DMD chip needs replacement
get it replaced from technician
Jan 18, 2013 | Optoma GT700 Projector
My Optoma HD72 projector operates for about 1 minute and then shuts off. I kept my old bulb around "just in case", I've replaced the bulb with the old one and have the same problem.
The problem is not over-heating. The Optoma HD72 has a known problem that Optoma won't advertise. The lamp driver is faulty. They simply have to replace the lamp driver. I purchased a spare lamp with my original purchase. I had the exact same experience as you at around 1200 hours on the lamp in ECO mode. I used the spare lamp. Same thing happened at about 1200 hours. I had a friend at Optoma. he confided to me the problem. I sent it in and they replaced the lamp driver at no charge. I got another 800 hours out of the first lamp and am now using my second lamp and have about 600 hours on it. The pic quality is so good with this projector (used Digital Video Essentials to calibrate) that I'll just order a bare lamp or two and use the existing lamp housings when I need a new bulb.
Apr 12, 2010 | Optoma H30 Multimedia Projector
Pwering up and then turns off.
I have a similar issue. It might be overheating. Did you try cleaning it, using a duster? Let me know if you found a solution.
Mar 20, 2010 | Optoma HD80 Projector
Optoma hd70 starts flashing colors
I removed the front cover and top panel, Using the Radio Shack dust removing spray, removed all dust from interior including circuit boards, color wheel ect, now it,s operating like a new projector.
Dec 21, 2009 | Optoma HD70 DLP Projector
Optoma HD65 bulb only 108 hrs old having difficulty starting up
Use the warranty! since you anly had it for 8 weeks, and the waaranty last for one year, go back with it and get it repaired or get a new bulb. A buld last at least 2500 hours, in eco mode it last for over 3000 hours.
Good luck to you
Dec 17, 2008 | Optoma H30 Multimedia Projector
Blub out again
Hi there
Keep in mind that this is only a estimate - not true hours at all.
Does your Projector go in for a service every 3 months ?
If I were you I would take back the Projector to the dealer you purchased it from and ask them to test your Ballast ( lamp's powersupply)
Did they tell you to run in your new lamp for 12 hours straight ?
Feb 13, 2008 | Optoma H30 Multimedia Projector
Optoma hd72 bulb turning off
This is NOT a bulb problem unless your "lamp" LED is lit, which you say it is not. Many people have reported this problem with the Optoma 72. You can send it in for warranty service (it has a 2-year warranty) to get the lamp controller chip replaced, but the problem may recur. Optoma does not appear to have a permanent solution to this problem. My projector has broken exactly like yours TWICE in a year. I haven't even needed to replace the original bulb yet. :(
Nov 05, 2006 | Optoma HD72 Multimedia Projector
Optoma GT700 Projector Logo
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
