Question about Sony LBT-ZX6 Shelf System
My buttons on my Sony LBT-ZX6 are locked I can use the power button to turn the system on but not off and all the other buttons are locked any solutions to this problem
  • 3 Answers
Most likely that any one of the buttons is stuck on possibly even on the remote(common due to liquid spill,dog chewed etc) try taking the batteries out to isolate rc. If not lightly try each button and feel if one is slightly sticking or softer touch likely to be the offender Sadly if multiple operation does not clear then unless proficient I suggest you do not try to strip down
Posted on Nov 21, 2016
  • 436 Answers
SOURCE: sony lbt-x5g500
Power protect tends to mean the main power amp chip has "blown" and needs to be replaced. It only costs about 20 dollars (10GBP). If you are handy with a soldering iron it is easy to do (after you get the thing to bits !) It is the big black thing on the big heatsink inside. The Sony part number is STK442 - 130. Seems a waste to throw the whole thing away for the sake of 10 pounds !. Hope this helps. Nik Howell (nh@totalise.co.uk)
Posted on Jun 16, 2007
SOURCE: Sony LBT W5000
when the hi-fi is off and there is the sony demo push "display" on your remote.. yep yep. peace
Posted on Oct 30, 2008
nuwan chinth
  • 111 Answers
SOURCE: pushed power protect
speaker protection turned on.it can be happend because of bad power amlifire section.can you remoove the powe ramp board with large heatsink.its very easy to repair.and i can help.
nuwan
Posted on Jan 12, 2009
According to Page 46 of the LBT-W5000 Operating Instructions:
"The display stars flashing as soon as you plug in the power cord even though you haven't turned on the system (demonstration mode).
Press DISPLAY (for LBT-W5000 / W300 / XB700 / XB500) or DEMO (STANDBY) (for other models) while the system is off. If the system is in the Power Saving mode, press POWER SAVE / DEMO (STANDBY) (for LBT-W5000 / W300 / XB700 / XB500). The demonstration appears automatically the first time you plug in the power cord, or if there is a power outage lasting longer than half a day."
I tested this today, as my LBT-W5000 was in Demonstration Mode. It definitely works. The only catch is (at least on the W5000), and it's a minor one, you have to reset your clock afterwards.
Posted on Aug 05, 2009
SOURCE: Sony MHC-57AV - System shuts down "Push power protect button"
this problem is audeio out put is sort .pls ching out put STK .Any Q - My ID uttamkholiya@yahoo.com
any sony music system problem
Posted on Nov 07, 2009
Tip
My sony 3 disc ex-change/mini hifi component system mhc-rg66 it keeps flashing...
First things first. The unit doesn't switch on.
- Is it plugged in?
- Is the fuse blown?
- Does it look like it's suffered damage?
It switches on, but won't play anything / the lights come on, but no sound.
- We'll start at connections. Is your MP3 player/ iPod/ CD player/ record deck plugged in correctly?
- Are the speakers plugged in correctly/ at all?
- Is it in protection mode - this is a pretty standard thing now, where the amplifier tries to deliver more than it's rated current (ie, into a short circuit), and it cuts out. The only way to fix this is to take it to a local hifi shop, who will reset it (there's usually a small fee involved). The unit will be fine after that.
------- There is no bass. ----------
A few causes for this, so there's a few solutions.
- The speakers are out of phase. This is where one speaker is wired normally, one is wired in reverse. The bass from each speaker is "opposite" and would cancel out. To solve this, Make sure the + on the speaker is connected to the + on the amplifier. There's usually a stripe on the cable to help you determine this.
Cause # 2
The eq settings on your ipod/ unit have been messed with.
Set all the equiliser settings to flat, then readjust them to taste.
Cause # 3 (nasty one)
You've blown a woofer. The explanation is this - the speakers have taken in too much power, the bass unit has got too hot and the glue holding the coil in place has melted. Usually, the woofer can't be physically pushed when this happens. To solve this, it's new speaker time. An alternative is to see if you can get a recone kit for said speaker, and try to fix the voicecoil yourself. This isn't recommended to those who are new to the idea.
I hope this helps the reader.
Chris
on Sep 27, 2010 | Sony LBT-ZX6 Shelf System
Stereo shuts down when i turn it on
Check the speaker wiring on the back to see if any are shorting, if okay! the problem is in one or two audio output ic's.
Apr 27, 2012 | Sony LBT-ZX6 Audio Shelf System
While playing my unit we had a brief power outage. When the power supply returned the " PROTECT PUSH POWER " message comes on. Is there a button that I can push to reset my unit-LBT-X50 .
Your sound system may have a circuit breaker.
Check the rear of the sound system for a circuit breaker that has popped out, Then push it back in.
It may be labelled.
  • circuit breaker
  • protect push power
Otherwise unplug your unit from the wall and wait 5min before you plug it back in, then press the power button on the front of your system and your remote control.
I hope this helps
MobileJB
Jul 13, 2011 | Sony LBT-LX50 CD Shelf System
Where is my output ic situated
the out put ic is situated inside right side wen the unit front is facing you ,you cant miss it its bolted on a alumium heatsink silver, it has a number stk 412 150 written on it,,,
Dec 27, 2010 | Sony LBT-ZX6 Shelf System
Good morning! I wish to plug our television into the LBT-ZX6 stereo, but the TV's output uses an optical audio cable. Is there an adapter of any sort that could convert the optical cable into the stereo...
You may be able to avoid messing with the optical output completely, if the TV has a headphone output, in which case, a phono-3.5mm jack adaptor will sort you out nicely.
If it has to be optical, I expect you can buy adaptors for this aswell, but I'd expect it to be more expensive.
Most local electronics stores will sell these. Radioshack is a good example. Also, you could look around on the internet.
Jan 25, 2010 | Sony LBT-ZX6 Shelf System
When you turn on the unit nothin happens but when you shut it off you can use the radio an other options
when the earphones are plug in the unit you can hear the music cd radio etc . the problem is when i take the head phones out of the unit you dont hear nothing please help.
Nov 22, 2009 | Sony LBT-ZX6 Shelf System
Sony LBT W5000
May 29, 2009 | Sony LBT-W5000 Shelf System
P-301 onkyo pre-amp
Hi juicer, If you use the switched outlet, then everything will be turned on/off when you operate the preamp power switch. Use the unswitched, then you have to turn off each unit separately. You choose which one you want. It wont matter.
What connection do you intend to use to connect the LBT zx6 to the Onkyo preamp??
Mar 20, 2008 | Audio Players & Recorders
Sony LBT W5000
Oct 06, 2007 | Sony LBT-W5000 Shelf System
Sony LBT-ZX6 Shelf System Logo
366 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
