Question about Dynex DX-L32-10A 32" LCD HDTV
Dx l-32 main problems
Won't power up
    Top Expert:
  • Dynex Master
  • 14,553 Answers
I see so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo. dx l-32 main problems - 11_5_2012_6_10_47_pm.jpg
Posted on Nov 05, 2012
Sansui tv won't turn on
Check its main power supply regulator section circuit for defects. Check and replace damaged component/s.
Jan 10, 2013 | Sansui 32" TV
Tv won't turn on
The main power regulator section circuit should be troubleshooted
Dec 02, 2012 | JVC AV-32432 32" TV
Dynex dx l-32 won't power up
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo. 11_5_2012_6_10_04_pm.jpg
Nov 05, 2012 | Televison & Video
My TV won't come on
Hello Linda,
The set will need to be diagnosed to find the problem. There could be an issue with the power supply or main board but get it checked out.
Sep 23, 2012 | Vizio L32 32 in. LCD HDTV
Jvc lcd picutre won't show
as you said jvc lcd tv won"t show. if lcd tv have good power supply & main board. that will be inverter board gone in. replace it will be solve you problem. good luck!
Sep 03, 2012 | JVC LT-42X579 42 in. LCD TV
I hae a vizio E320VL, i have replace main board and the power suplly, and it still won't stay on.
hi. you sure your replacement -- power supply & main board in good condition???? lcd present 5v , 12v, &24 v ??? if no you need going back power supply. if yes. you need to replace inverter board as possible. good luck!
Sep 01, 2012 | Vizio L32 32 in. LCD HDTV
Won't stay on
Power supply or whatever controls the set--main board.
Power supply should be carefully checked including looking at the filter caps on it.
Jun 11, 2012 | ViewSonic N3252WS 32 in. LCD TV
Dynex DX-24L150A11 won't turn on LED light is not on either
Sounds like you are missing your 5VDC standby voltage from the power supply. You either have a blown fuse or a defective power supply. Did this happen out of the blue or after a T-storm???
May 11, 2012 | Dynex DX-L42-10A 42 in. LCD TV
My MW511 won't start
Check the input power is coming or not. Check fuse inside control board & wiring too. If everything ok then it's problem of control board
Oct 14, 2017 | Washing Machines
Screen won't light up when you turn it on.
Possible that the main power supply has failed. so the main SMPS must be checked.
Please check this link:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Aug 30, 2011 | Proscan 32LA25Q 32 in. LCD TV
Dynex DX-L32-10A 32" LCD HDTV Logo
112 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
