Question about Microsoft LifeCam VX-1000 Webcam
When I place a ?video call? to someone, they can see me but, can?t hear me. I can see them and the audio brakes in and out or gets stuck in a loop. When I simple ?call? their computer (no video), we can hear each other just fine. We both have the same camera. can you help
When I set up my webcam had same problem until I changed the preset audio hookup/setup from the prefilled option to the Lifecam one. You need to click on it & it will appear as a dropdown option, then click on it. The option appears when you go into the audio portion & the words appear asking you to speak until the yellow shows in the bar. I believe the option is just before or after that screen. Good luck.
Posted on Jan 07, 2009
Sony Amp STR-DN1030 stuck in network update loop
By the time you figure it out you will have more time in it then it is worth and the warranty has an expatriation date. If you fail to fix it you void the warranty as well.
Dec 13, 2014 | Sony Audio Players & Recorders
Cant get sound from my insigna 1080p lcd tv to go through my pioneer sx 315
I had to hookup a RCA Cable from the component audio on TV to component on receiver along with the HDMI cable to create a loop for the HDMI pass thru to work allowing audio.
Apr 08, 2013 | Audio Players & Recorders
I need to connect a mixer to a yamaha rx-aq1000, in order to be able to mix any signal going thru the unit, with guitar, microphones, and input it back to play. Since this unit does not have an adapter...
Finally someone who understands tape loops. But, alas, I don't see how you can mix and monitor simultaneously on this receiver. The AV Out is the best bet for getting analog audio out but there's no way to get it back without de-selecting whatever source you're using. Bummer.
Sep 04, 2011 | Yamaha RXA1000 Receiver
Why does the Brunei Darussalam's Patriotic Song (Berkibar Bendera) in the the form of audio only? No button to click to replay?
I also went there to see what was going on for the life of me I could not get it to play video as well. I could hear audio this is not on your end it has to do with video quality of the upload or if it was in audio format or MP3 I even checked other placed to find this and they all went YouTube. Thanks for using FixYa! It is not on your end it just is what it is. Try to do a search that has a video not using YouTube I did not find any. Sorry maybe someone else knows where to go with this. John
Feb 19, 2011 | YouTube Videos
I have curtis htib 1000 and it make a buzzing and humming sound and i wanted if someone can repair it for me
There are a few things that can cause this but two in particular are the most common. One is a ground loop. If you have multiple pcs of equipment hooked up a ground loop can be created. Ground loops are basically different grounds that are not held at the same potential. The second could be a power supply filter cap is going bad or possibly not in the circuit. Capacitors filter out the 60Hz noise after the AC is rectified. Any 60 hz getting into your amp will cause it to hum.
Feb 07, 2010 | Audio Players & Recorders
Loud Bass Test Like Sound when selecting any source execpt stndby
i had the same problem make sure you ground the indash unit well and brain and i had to get a ground isolator loop from the car audio place cost 20 bucks and works great
Apr 20, 2009 | Kenwood KVT-715DVD Car DVD Player
EliteGroup G31T-M initial boot stops
Remove the CMOS battery for a few hours then place it back in. I bet it sound like the CMOS is stuck in a loop.
Dec 30, 2008 | EliteGroup ECS G31T-M Motherboard - Quad...
No video when placing DVDin the DVD-Rom drive
Try updating the video drivers, or reloading your DVD decoding software.
Jun 16, 2008 | Toshiba Satellite A215-S7422 Notebook
Compaq presario 2500
is the lcd lighting up? can you hear the fan running?
Jun 02, 2008 | Compaq Presario 2100U Notebook
Hum niose in my onkyo tx-sr804
Hi there, sounds like you have a ground loop happening there. Check out ground loops in google to get some tips. What you should try is use one wall plug for everything (with an adapter on it) and check that none of your other cables are damaged. try find new cables and put them in place of the old seemingly fine cables.
Sep 23, 2007 | Onkyo TX-SR803 Receiver
Microsoft LifeCam VX-1000 Webcam Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
