Question about Zenith A27A23W 27" TV
I cant get a pic w my satelite
Does it go on video or cable or ant
    Top Expert:
  • Zenith Master
  • 14,553 Answers
Should go to coax fitting depending on output from sat---if there on catv and usually channel 3 or 4 whatever sat is set to out.
Via the audio/video out to the same in on the set it goes to video.
Posted on Nov 05, 2012
Can you recording satelite tv with external tv tuner thru s-video cable?
It is possible to record but it recommends more time.
So its helpful that you record via only satelite tv .and then transfer to your pc.
Feb 07, 2012 | Leadtek WinFast A6200 TDH GeForce 6200A...
I have a wd-62525 dlp i have pic and sound through ant. and hdmi but on component and video inputs i only get sound no pic
Hello
It seems to be some fault with its HDMI cable you connect to this device from the source. As you get sound by HDMI, and no picture at all, this indicates the fault with cable itself. There is a cution notice says that " To assure continued FCC compliance, the user must use a shielded video interface cable
with bonded ferrite cores at both ends, when using the PC or HDMI input."
Cheang the cable and check.
Oct 10, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
I just bought a new vizio 32in and cant get the pic adjusted right. Settings to choose from are normal,wide panaramic,wide zoom1 and zoom2. The pic looks the best in normal but I have black lines on the...
If you are using a cabe or satelite box these units also have picture format button, if so then consider setting the televisions remote screen format to normal, and us the box's remote to change formats especially if you are watching in HD.
Dec 04, 2009 | Televison & Video
Would like to get basic channels for television without cable or satelite
Run autoprogram on ANT mode instead of cable. As long as you're not in an area in which they shut down the NTSC early, rabbit ears or extenders should improve reception. If you are in an NTSC-early-shutdown area, you must buy a digital converter box. dtv.gov for more details.
May 30, 2008 | Toshiba Televison & Video
Suround sound
Hi mich11
Right firstly you will have to check how many inputs you have on your Projector and then also how many inputs you've got and then work from there.
Typically it would be like this :
1.) S-Video cable running from your DVD player to your Projector. S-video - S-video points - both males.
2.) RG59 ( video cable ) running from your sky/satelite decoder to your Projector - once again 2 RCA points - both male.
I'll quickly browse through some of our installation pics and post you a couple.
May 05, 2008 | Toshiba TDP-S20U Multimedia Projector
Cant set up anyhting to my cable box/ dvdr /tv
buy a new rca cable or RF cable for you're cable box ,then connect the output of dvd red/white/yellow to the tv video input red/white/ yellow and for you're cable box connect the RF cable to tv ant.
Mar 23, 2008 | Cyberhome DVR 1600 DVD Recorder
Help with tv
does your tv make noise the bearing usually go out on those color wheel sets so do the lamps on that model if you are confident go for a repair at home here is a shortcut http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ if this is the year click the link above
Feb 16, 2008 | Televison & Video
RCA F36676ETFM2
it sounds me that it is due to cable wire connection where it is connected is probably might be loose or if you have cable box there is some loose connection.
Oct 05, 2007 | RCA F31672ET TV
Televison & Video Logo
22 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
