Question about Dishwashers
We just moved into our home and the previous owner left the dishwasher. We have a Maytag MDB5130AWW Jet Clean Quiet Pack without the auto start button. I lock the door and press normal wash and accu/temp. The machine turns on but no water is entering it. The hose under the sink is connected, so I don't understand why the water is not flowing into it. She did not have the owners manual. Leslie
  • Dishwashers Master
  • 8,404 Answers
Look for a shutoff valve
Posted on Nov 05, 2012
catriver
  • 878 Answers
SOURCE: Dishwasher won't start
Kaclf, If you have no lights at all, dishwasher unresponsive, it's probably one of two things. First check the junction box where the cord hooks up to the dishwasher. Sometimes I find a bad connection in the wire-nut. Second, there is a thermal fuse that sits on the control board. You will have to remove the inside panel. You want to see if it's blown. It will be sitting on the top side of the board, two wires going to it. Catriver
Posted on Dec 30, 2007
Master_Tech
  • 770 Answers
SOURCE: How do you "undo" the aqua stop?
create an inverted trap in ther dishwasher drain line so the water cant back feed
Posted on Jul 09, 2008
SOURCE: Maytag Dishwasher model # MDB5130AWW
I had a similar issue with my MDB5130AWW. The Wash was interupted and wouldn't come back on. Not knowing where to start I read some other solutions on this site and started by opening the bottom cover. Thats where I found a 4 page diagnostic / Electrical Schematic. Start with the Sales Demo mode of pressing the Rinse button 5 times within 5 seconds. I had to do it twice before the washer came "alive". I was estatic after reading about the $100 mainboard cost and maybe more for other parts. The document has other test and what different keypads mean when flashing. Thankfully I didn't have to go that far.
Posted on Aug 27, 2008
StarGGundam2
  • 24 Answers
SOURCE: Maytag Quiet Series dishwasher won't start
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
Posted on Oct 12, 2009
SOURCE: Tecnik Built In Dishwasher SE6TIE1GB/17
You can try reseting the machine buy holging down outside two cycle buttons for 3 seconds, then release. After a minute the end light should come on. Then use as normal. If this fails pull the unit out, then take of the side panels (screws to the front in the seal) & check the red anti-flood float on the left side of the machine, to make sure it is not up activating the cut out switch. This may be due to the machine leaking somewhere and the float raises and activates the switch, or as in my case a build up of limscale has raised it up enough to activate it.
Hope this helps
Posted on Nov 25, 2009
Users manual showing how to operate maytag jet clean dishwasher quiet plus
Good Morning Marion!
You can find installation and user guides for the Maytag Jetclean here
Maytag Jetclean Dishwasher (it's the Maytag site, and the page has several links to PDF files. The specific owners manual is at
http://www.maytag.com/digitalassets/MDB5000AWB/Use%20and%20Care_EN.pdf
Hope this helps, and good luck!
D
Nov 19, 2015 | Maytag Dishwashers
I have an older Maytag DW model #MDB5130AWW I've
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101'
May 31, 2011 | Maytag MDB8551 Built-in Dishwasher
My model # is mdb 5100 aww. Cannot find one. Built in, Maytag Jet clean (Quiet pack) Serial 10071560YY Motor 5.5a 120v 60hz heater 6.0 a Just quit working. Now no power at all
Most likley you have a bad control board. Can you give me anymore details of what exactly is going on with it?
Did you check the breaker and make sure there is power going to it.
Aug 22, 2010 | Maytag Dishwashers
I have a MDB5130AWW model dishwasher and it has worked extremely well up until a week ago. Now there is water sitting at the bottom of the dishwasher, and the "Clean" and "Rinse Only" buttons are blinking....
You may have a seized/stuck motor. Turn the electricity off and remove the lower panels. Take a flat head screw driver and carefully attempt to move the motor impellers. If the impellers feel hard to turn continue to try and free the impellers. If they loosen, reactivate the power and start the appliance. Good luck!
Feb 24, 2010 | Maytag Dishwashers
I have a Maytag Quiet Series 400 and I can't get it to run on Normal,lite or other. I get a code 82 that appears. What does this mean?
My Maytag quiet 400 series is doing the same thing-buttons aren't responding or working. And now a second problem...it has become very loud and sounds like it is chewing up all the dishes.
PattyQ
Jan 10, 2010 | Maytag Dishwashers
May 22, 2008 | Dishwashers
Maytag quiet series 300 - sandy residue
the buttons to start the cycle auto clean or heavy wash does not light up and therefore is not cleaning my disches please advise to
Carol @ killday@irtc.net
Apr 06, 2008 | Maytag 24 in. MDB9750AW Dishwasher
Maytag dishwasher latch
If it like mine, the latch is out of adjustment and you need to give it a whack with your hip to start it. If I adjust the latch looser, it leaks.
Oct 24, 2007 | Maytag 24 in. MDB8600AW Jetclean II...
Jet dry not draining no clog as far as i know
i needed all your all your serial num its important 17
Nov 30, 2006 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
90 people viewed this question
Top Dishwashers Experts
