Samsung crt tv blinking
My tv is blinking 5tyems gryin color but no disply teh voltag is evry plas is ok how to fix
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Have you tried to unplug the set from power for a while and then replug to see if it reboots?
Posted on Nov 05, 2012
4 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Sony KP65WS500 5 blinks
1st set Brightness and Contrast settings to 50% at tv menu.
You need to cover 2 CRTs with any thing like thick paper while adjusting 3rd CRT.
For example, lets adjust Red CRT G2 volts, Select audio-video input 1 and cover green and blue lens with paper note-book and rotate Screen control up to level where you see retrace lines on projection screen, now decrease screen volts (G2) so retrace lines disappear and projection screen should be blank.
Now do same process with green and blue adjustment while other lenses should be covered.
Im not sure I conveyed it to you properly or not because English is not my 1st language.
Thank you.
Posted on Sep 23, 2008
welcomejee
  • 10594 Answers
I think problem is in Protection circuit itself. Protection seems unstable in your tv that's why it doesn't give you chance to diagnose problem.
Try to isolate protection command and check tv.
Its an idea and hopefully it will work.
Posted on Sep 28, 2008
  • 133 Answers
SOURCE: Samsung HCJ552w CRT rear projection with a broken ASSY CRT-B.
not worth it, when you replace one, your saposed to replace all 3, otherwise the picture looks funny, probabily a 600 dollar repair
Posted on Jan 09, 2009
In Samsung tv complaint<br/>in first time tv working in normal and after sometime picture is blinking and slowly no pictre. that time sound is also ok.<br/>after that am am change the capa
Check its solder terminal at the CRT board [Filament voltage]. It sounds like the filament do not glow after some time due to a loose contact at the CRT base connector sockets. Check it.
If this does not help, check the ABL circuit for any open resistor.
Oct 25, 2014 | Televison & Video
Plic abut crt tv color blinking
can you please give brand and model and a description of what set is doing or not doing?
Nov 05, 2012 | Televison & Video
5 times green light blinking problem
full format find code on web for samsung put in phone or soft problems is higher service reflash
Nov 04, 2012 | Samsung Cell Phones
Whenever i start PC my 17" CRT monitor led blinks very fast and gives clicking sound but nothing displys . the blinking slower gradualy and after 25 minutes it displays menu. why it is take so long...
You can test it with another PC, if problem is the same, it might due to faulty components inside the CRT board. You have to justify whether to fix it or get a new LCD which is very cheap now.
Jan 03, 2011 | Samsung Computers & Internet
Replaced the lamp bulb on my samsung HLP5663. It went on right away. Though the problem was fixed. Turned the tv on a little while ago and the picture is gone. The timer light is blinking. Any ideas what's...
Now tv turn on.Hear alots of clicking or squiling,loud motor noises turn on?Alot of clicking,the Ballast board it dead,this board help ignite the projection lamp.Tv also have a colors wheels.The colors wheel is dead,if hear squiling noises,loud motor noises.
Jul 14, 2010 | Samsung DLP HL-P5663W 56" TV
My samsung 5067w dlp tv does not turn on, the timer, lamp and temp/standby lights keep blinking. Please help!! Thanks
First check the color to see if its spinning or not. Replace it if neccessary. If that's ok, replace lamp and ballast.
Dec 23, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
Aug 30, 2009 | Samsung DLP HL-P5663W 56" TV
Lost green color, lights blinks
Ur high voltage is dead,FBT,flyback transformer is dead,the big black block of plastice with a red wire with a cap hook to a CRT(tv tube).Resoder for lost green color,by the crt yoke RED GREEN YELLOW connection to the main PCB board.Might also have to resolder crt board connection pins socket.
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Samsung793s led blinking no disply
the vga card is not connected properly i think in cpu .. just reconnect it... and then have a try..... it should work...
Feb 13, 2008 | Samsung 793S 17" CRT Monitor
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
