Question about Home Security
Have a kidde carbon monoxide alarm reading 888 on test and L6 on peak level.
oldnovii
  • 667 Answers
SOURCE: kidde Carbon Monoxide Alarms
YES!!!! If this unit is working properly you should not be in the house. Maximum allowable safety level for an 8 hour period is 50! If you think it's working properly call the fire department! This will cause dizziness,nausea,etc. Let your fire department find the problem! If you don't believe me follow this link to owner's manual but do it quickly: http://www.kiddeus.com/utcfs/ws-384/Assets/KN-COB-B(9CO5)en.pdf
Posted on Mar 13, 2008
  • 3 Answers
SOURCE: what does an err code E03 mean?
Correct. Intermittent beeping is a sign of "component failure". Time for a new one.
Posted on Dec 25, 2008
szanti
  • 36 Answers
SOURCE: kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Posted on Sep 28, 2009
TeaCii
  • 90 Answers
SOURCE: My Kidde carbon monoxide alarm beeps once every 35
1. Change batteries.
2. Clean it.
3. Swap it with another location if you can.
If it still does not work properly consult the local fire dept. for free.
You may have to take it in repairs if all fails.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Posted on Apr 23, 2010
getyourfix
  • 43 Answers
SOURCE: Nighthawk Combo Gas/co Detector: is 218 a high read of carbon monoxide levels in a ...
A reading of 218 should be treated as an emergency. When a Carbon Monoxide level reaches over 70 ppm, you should have a professional inspect and repair the appliance that is causing this issue.
Carbon monoxide levels above 70 ppm will cause headache, fatigue and nausea. Levels above 150 ppm can cause serious injury or death.
Read section 5 US Consumer Product Safety Commission.
Posted on Jul 29, 2010
My night hawk carbon monoxide reads L6. Then Err.
Lb (rather than L6) indicates a low battery. You need to replace the 9V battery in the carbon monoxide detector. The Err suggests an internal error but could just be due to the low battery.
If the Err persists after you replace the battery, press the peak level button (the right hand button) and check for an additional error code. If the Err message continues, replace the Night Hawk unit. If the unit is still under warranty, contact the manufacturer. Most of these units have a 10 year warranty. There are several models available from Kidde. The manual is available on the product site. For the KN-COPP-3 Night Hawk carbon monoxide detector, the documentation is available here: http://www.kidde.com/home-safety/en/us/products/fire-safety/co-alarms/kn-copp-3/ . Click on the Documents tab. The manual for the KN-COPP-3 999-0100 is here: http://www.utcccs-cdn.com/hvac/docs/2001/Public/06/User_Guide_KN-COPP-3_900-0100.pdf .
I hope this helps.
Dec 12, 2016 | Night Home Security
What dose the numbers on a carbon alarm mean after it goes off. we think for no reason we only have a gas water heater and that only a year old. Thank u
The numbers on my CO detector indicate the concentration of Carbon Monoxide in the room. The manual for most Kidde Alarms are here: https://portalgb.knowledgebase.net/display/4/kb/browse/cat.aspx?cid=88327&kb=16372&L1cid=88309&L2cid=88327&level=3&r=0.06986403&tab=browse . For some models, it will display the peak CO detected (if the peak level button is pressed).
Do not assume that the alarm is in error. Please have the exhaust vent, pipe and intake (for some tankless water heaters) checked for blockages or disconnected pieces. (You can check some of the vents pipe yourself - like the connection from the water heater to the pipe. Depending on your building, you may need a professional to check the vent on the roof and the pipe from there.) Also check the flame color of the water heater. For natural gas, you should see a blue flame. LP usually has a little bit of yellow in the flame tips. CO is the result of incomplete combustion. See this page for an idea of the flame color: http://www.appliance411.com/faq/gas_range_flames.shtml . If the flame is the wrong color, get the unit fixed.
I hope this helps.
(who has had the CO detector indicate a major problem. Fortunately it was easy to fix. I hope yours is also simple.)
Jun 11, 2011 | Kidde Carbon Monoxide (KNCOBB) and Smoke...
Good Morning, My nighthawk CO detector went off with a loud continuous alarm this morning while all were sleeping. I reset it and it is not alarming now. I pushed the peak button and it reads 19. The...
When a carbon monoxide detector sends an alarm, there is cause for concern. You mentioned that the other CO detector did not go off, but maybe it is too far away to monitor the carbon monoxide levels that was in this area.
The instructions in your manual would direct you to evacuate the house immediately and ventilate. Your next step is to get a professional to inspect what may have caused the carbon monoxide leak.
A reading of 19 indicates that there is carbon monoxide in that area of your house, unless your CO detector is not working properly. Your local fire department will give you the best advice for what action to take when a carbon monoxide detector sends an alarm.
Be safe, don't assume a carbon monoxide alarm is cause by a defective CO detector, have it inspected.
Jul 30, 2010 | Kidde Nighthawk Combo Gas/co Detector
My Kidde Model # KN-COEG-3 keeps going off and lists 217 now 205 now again 217 and this is with the door open and fresh air coming into my place ??
I took the following from the Kidde website. They only answer the phone Mon-Fri, from 8-5, EST. I checked it out because my almost new Kidde CO detector is showing an Error code.
The next time your carbon monoxide alarm has ERR on the display, push and hold the Peak Level button.You will see an E and an O followed by a number.Contact our hotline at 1-800-880-6788 and provide us the error code, along with the model number, assembly number and date of manufacture from the back of your unit.If your unit is under warranty, a replacement will be mailed to you.
Nov 21, 2009 | Kidde Nighthawk Combo Gas/co Detector
Error code with a beeping-- reading 172 flashes
Call Kidde during business hours at the following number. I took the next paragraph off their website.
"The next time your carbon monoxide alarm has ERR on the display, push and hold the Peak Level button.You will see an E and an O followed by a number.Contact our hotline at 1-800-880-6788 and provide us the error code, along with the model number, assembly number and date of manufacture from the back of your unit.If your unit is under warranty, a replacement will be mailed to you."
Nov 18, 2009 | Kidde Nighthawk Combo Gas/co Detector
Carbon monoxide is on
When a Carbon Monoxide Detector alarm goes off, you should follow the procedures that came with the manufacturer manual. Even when the alarm sounds, you cannot smell, taste, or see this dangerous silent killer known as Carbon Monoxide.
Have your house checked by your local fire department for possible levels of CO gas readings. If this all checks out, you can go online to Kidde Nighthawk website and find the manual for your Carbon Monoxide detector model.
Hopefully, you found your solution since you posted this question back in Dec, 2008. Go to my website to read industry information and to view most Brands and Models of Carbon Monoxide Detectors.
Dec 16, 2008 | Kidde Nighthawk Combo Gas/co Detector
What does an err code E03 mean?
the sense is bad, unfoturally the unit need to be replaced.
Nov 24, 2008 | Kidde Nighthawk Combo Gas/co Detector
Kidde Carbon Monoxide Alarms
Feb 27, 2008 | Kidde Nighthawk Combo Gas/co Detector
Home Security Logo
161 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
