Question about Sony Cyber-Shot DSC-P10 Digital Camera
Flash don't work
It won't flash when i start to take a picture
Put in new starter in 2003 ford expodition and it still won't start what can my problem be won't even turn over?
Smart lock? do you have a picture of a red hand on instrument panel? With falcons quite common. Turn & hold key @ start posision, Hit dash upwards on left side of steering colum, If start = faulty smart lock module. I don't know if expodition has smart lock but probably does
Jun 15, 2012 | 2003 Ford Expedition
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
I have a 2001 Olds Intrigue that won't start every once in a while. When it won't start the security light flashes so GM told me it was the passcode and I would have to change the ignition switch...
you can not bypass the security in that car, it is built into the main computer, they have problems with the ignition switch screwing up and the only way to start it while the light flashes is to turn the key to ON but don't crank engine, leave on for 10 to 15 minutes until light goes out then start car.
Sep 21, 2011 | 1998 Oldsmobile Intrigue
Looking for a dodge caravan engine computer for sale
Don't think I have ever heard of that, ever
You think or were told to find a pcm & your
looking for a reasonable used one ,that hopefully
you won't have to have it flashed?
They don't fail often & I also have never heard of
one being replaced other than at a repair shop
or dealer.
Aug 04, 2011 | 1996 Dodge Caravan
My Nikon Coolpix s230 flash won't work. It just blinks red in the lower right hand corner. I've tried all the settings and they all won't flash.
If there is a problem with the flash itself or the mainboard connection to the flash it will not charge. If the flash won't charge then it won't go off when you take a picture. The only way to fix the problem is to replace the flash with a good used one and see if that fixes it. If not, then you need to replace the mainboard. Good used parts can usually be found online for cheap; that auction website doesn't pay me to type their name, so I don't, sorry. Hope this helps!
Thomas Drayton
Owner, www.darntoothysam.com
Affordable Digital Camera Repair
Jul 24, 2011 | Nikon COOLPIX S230 Digital Camera
We are having problems looking for the location of the shift solenoid on the 2002 ford explorer. could you email the picture or a diagram of the location of the shift solenoid
Put your trans model into your search engine
& find out where they are
May find a picture,may not
If you know nothing, there is plenty on all
transmissions made for fords for the last 70 years
YOU TUBE is always a good place to go
You can play with that & watch anything
I think you remove the pan to get to them
You don't go changing anything on a wish & hope,
push & poke theory
If you don't know what they do or how to test
them & you won't,go to a trans shop
Jun 12, 2011 | Ford Explorer Cars & Trucks
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
When transfering pictures from camera to PC EasyShare will not transfer some pictures. "picture already exists" in My Collection. These are all new pictures taken with blank memory card. This occurs even...
Scrap the camera! Kodak hasn't and won't address the problem. Most picture download software won't recognize the camera. The only solution is to remove the memory card from the camera, put it in USB adapter and treat it like a flash drive. Cumbersome. Awkward. Stupid. After you scrap the ****, tell your friends so they don't make the mistake of buying a Kodak.
Dec 26, 2009 | Kodak EASYSHARE M1063 Digital Camera
Sony Cyber-Shot DSC-P10 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
