I m install window xp service pack 2 but create a problem one month trail after installation
  • 805 Answers
You can use activator if you haven't then you can contract me through my email then i will send to you. thanks
Posted on Nov 05, 2012
askanything
  • 151 Answers
SOURCE: how to create a bootable xp service pack 2 cd
To create bootable disk follow the steps: 1)Enter floppy disk or cd in your dvd/cd drive. 2)You can create boot disk by using Nero CD Burning software or other software with which you burn your cd or dvd. 3) to create with windows xp go to http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=FBE5E4FC-695F-43E5-AF05-719F45C382A4 Or carry out the following steps: Using Windows XP, place a blank floppy in drive A and format the disk. Navigate to the root folder of the system (in most cases this will be C:\) and copy the following files to the floppy disk. Boot.ini NTLDR Ntdetect.com If you can't see the files, click [Tools] and [Folder Options...] in the Menu Bar of Windows Explorer. Click the [View] tab and click the radio button next to [Show Hidden Files and Folders]. Remove the check mark next to [Hide Protected Operating System Files (Recommended)] then click [Apply] and [OK]. The files should now be visible in Windows Explorer. If the files still cannot be copied, right click each file, click [Properties] and remove the checkmark from the Read-Only attributes. Reset whatever attributes were unchecked after the copy procedure is completed. In addition to the files listed above, check the same directory for bootsect.dos and ntbootdd.sys files. If they are present on your system, copy them to the same floppy diskette. The disk is used as any other boot disk, inserting it into the floppy drive (A:\) and initiating a cold boot. Make sure the BIOS is set so that the A:\ drive is first in the boot sequence.
Posted on Sep 28, 2007
Jastababe
  • 117 Answers
SOURCE: windows vista
How To Make Vista Bootable DVD with WIM Downloaded Files If you have purchased Windows Vista online and taken the delivery of the latest operating system via web download from Windows Marketplace, you would ends up with a few downloads with .wim and .exe file extensions. Rather than paying additional shipping and handling charges, you can burn or create a bootable ISO DVD image from downloaded Vista files with the following trick, where the .iso image can subsequently write to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD that available in retail channel, and can be used to clean install.
How to make a bootable Windows Vista ISO DVD media
1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
3. Exit from the Install Windows screen.
4. Download CDimage 2.52
5. Extract CDimage from CDimage.zip to the C:\ root directory.
6. Open a command prompt shell, and run the following command:
cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK)
1. Complete step 1 - 3 as above.
2. In the command prompt window, run the following command:
oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
3. Burn the ISO image file by using last step above.
Posted on Mar 24, 2008
  • 2427 Answers
SOURCE: service pack 2 installation problem(product key) for windows 2003
Try reentering the product key
Call microsoft and verify that your version is authentic and not pirated...
I had this problem already and it turned out althoug i had an authentic version the key i was sold with the cd was not recgoinised by microsoft. After providing my proof of purchase microsoft gave me a new key
Posted on Jul 11, 2008
ginko
  • 19396 Answers
SOURCE: i can't install an operating system win xp sp2 in acer 4535
Open the links below and follow the instructions:
How to install or upgrade to Windows XP
How to Install Windows XP
Posted on Jun 01, 2009
SOURCE: Windows XP Service Pack 2 shows asms missing
My understanding of this problem is as follows: When you put the Windows XP CD into the drive and switch on the computer Windows starts from the CD. In order to access the CD it uses the BIOS. However, at a certain point it decides to use its own drivers instead of using the BIOS. Oops! it doesn't have the right driver because your CD drive is too new, so it can't read the CD, and thus can't continue the install. The solution then is to copy all the necessary files onto a place where Windows can read the files. Solution 1 Do you have another computer? Take the hard drive out of the machine you are installing and put it into the second machine as a secondary hard drive. Switch on the second machine and copy the i386 directory and all its files and subdirectories from the Windows install CD on to the secondary hard drive. Remove the hard drive and put it back into the machine you are installing and switch it on. When Windows then asks for the missing file you can direct it to the I386 directory on the hard drive. This should be C:\I386. It will ask for the location of about 10 files. Give the same answer each time. Solution 2 You will need a bootable CD such as Hiren's boot CD, and a second CD drive. Put Hiren's into the primary CD drive. Put the Windows CD into the second CD drive. Switch on, and choose the mini XP Copy the I386 directory and all its sub-directories onto the hard drive. Again, when Windows asks for the location of the files direct it to the appropriate directory on the hard drive.
Posted on Jun 06, 2009
How to setup a new xp windows
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
if your installation disk is only a service pack 1 or 2 you might need to create an xp sp3 disk
http://windows.microsoft.com/en-US/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
if you have a copy of windows service pack there is a program that allows you add service pack 3 to it so you have a copy of xp sp3
http://www.nliteos.com/changelog.html
hope this helps
Oct 12, 2012 | Fujitsu Computers & Internet
Tip
What Does It Mean When Support for My Operating System Ends?
Microsoft Support for Windows Vista (with no service packs installed) ended on April 13, 2010, while support for Windows XP (without Service Pack 3 installed) ended on July 13, 2010. Windows 2000 support ended on July 13, 2010 as well.
There is no Service Pack 3 for the 64-bit version of Windows XP. If you're running the 64-bit version of Windows XP with SP2, you have the latest service pack and will continue to be eligible for support and receive updates until April 8, 2014.
If you are still running a version of Windows where support has ended, it means that version of Windows will no longer receive any updates from the Windows Update or Microsoft Update site. These updates are generally provided for security reasons to help protect the PC from harmful viruses, spyware, malware, and other malicious software. Windows Update also provides new drivers for your hardware that can improve the reliability of Windows.
Hackers love to take a security vulnerability in Windows and exploit it to their advantage. So, if a vulnerability is found in Windows XP or Windows Vista and you are not running the latest service pack, you will not be protected and will be at risk.
How Can I Tell What Service Pack is Installed?
Follow these steps to discover what Service Pack is installed:
1) Click on the Start Button
2) Right-click on either My Computer or Computer (depending on your Windows version)
3) Click on Properties
On this window, it should tell you which version of Windows along with which service pack is installed). It should also tell you whether you are running a 32 bit or 64 bit version of Windows.
Where can I download the latest Service Pack for Windows?
For Windows XP, click on the following link to download Service Pack 3
For Windows XP Service Pack 3 info, click below :-
http://windows.microsoft.com/en-us/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
For Windows XP Service Pack 3 download, click below :-
http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4
For Windows Vista, click on the following link to download Service Pack 2
Windows Vista Service Pack 2 info, click below :-
http://windows.microsoft.com/en-us/windows-vista/Learn-how-to-install-Windows-Vista-Service-Pack-2-SP2
Windows Vista Service Pack 2 download, click below :-
http://support.microsoft.com/kb/935791
on Oct 04, 2010 | Computers & Internet
Tip
Upgrading Windows XP
Most users of Windows XP are using Windows XP service pack 2.
You can upgrade Windows XP service pack 2 by installing plain service pack 3.
This will upgrade and improve functionality to your current installation to Windows XP.
There are alot of versions of Windows XP Service pack 3 but i recommend downloading an official version from Microsoft's downloads center through the link below.
To after download is complete, install the file. Installation takes about 10 to 30 minutes depending on your system specifications.
If your current installation of Windows XP has too many errors, installation of service pack 3 may not be successful.
The solution to this is to reinstall your Operating System (OS) using your OS installation CD, then install Service pack 3.
How ever, OS re installation will erase all your data in your system partition so back up all your data.
To download an official copy of Windows XP service pack 3, follow this link:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en
on Jan 07, 2010 | Computers & Internet
What is the installing code of Microsoft windows Xp service pack -2?
If you have a "valid" (not a "bootleg") copy of Windows XP, then there is *NO* "code" required to install XP Service Pack 2.
However, as of this month, Microsoft no longer supports XP Service Pack 2 -- you need to download/install XP Service Pack 3, in order to be supported.
Aug 04, 2010 | Computers & Internet
Keep getting stack overload. line 0
Your browser is corrupted, reinstall it.
Jul 11, 2010 | Dell Inspiron 1720 PC Notebook
Installed Windows Vista Service Pack 2 - now windows won't boot
first boot from the windows xp cd....
delete the existing partition in which windows was installed...create a new partition
do a fresh install of windows .....
this will solve all your problems
Dec 19, 2009 | Microsoft Windows Vista Home Premium with...
My pc has complete his formating in sixteen hours hp compaq d6120 microtower pc
DO YOU HAVE XP Booting CD service pack 2
insert XP BOOTING CD and delete the partition and create it again and then format it and install Windows XP service pack 2...
Thanks
ehsan
Jun 15, 2009 | HP Computers & Internet
Service packs not cleaning up properly
(sited from http://www.winxptutor.com/randomfolders.htm)
When you install Windows XP SP1, SP1a or SP2, this temporary folder is created on the volume that has the most free space. The folder name contains random characters, and is not always created on the same volume as the Windows folder. For example, this temporary folder may have the following random names:
9470bb12e8a4f3447657236478e41c5
or similar.
352b81d1c4bf3810e28482d9979
This folder is automatically deleted by Windows XP after you install the service pack. However, if the folder is not automatically deleted by Windows XP, you can safely delete this folder.
Please Note:
In most cases, you will receive an Access denied message while accessing or deleting this folder. First, you'll need to Take Ownership of the folder and then delete it safely.
May 21, 2009 | Microsoft Windows XP Professional With...
SP3 nightmare install
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07159&lc=en&dlc=en&cc=us&product=1127351&rule=24868&lang=en#
This should help you also
On March 6, 2008 Microsoft released Service Pack 3 (SP3) for Windows XP. Service Pack 3 contains all of the important Windows updates from previous service packs as well as additional updates that were released after Service Pack 2. To install Windows XP Service Pack 3 from the Internet on a home desktop computer use the Windows Update feature. CAUTION: If you have an HP Pavilion, HP Media Center or Compaq Presario desktop computer that has an AMD processor, your PC might encounter a startup problem after installing SP3 (or SP3 will not download from Windows Update). Before attempting to install SP3, install sp37394 - Microsoft Windows XP SP3 Upgrade Utility for systems with AMD processors . For more information, the following support articles from the Microsoft Web site can help: 322389 - How to obtain the latest Windows XP service pack (in English) 936929 - Release notes for Windows XP Service Pack 3 (in English) NOTE: One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside of the HP Web site.
Jan 25, 2009 | HP Compaq Presario SR1620NX...
HELP ME
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
Burn
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
Computers & Internet Logo
281 people viewed this question
David Payne
David Payne
